vexen1972 Posted September 29, 2012 Report Share Posted September 29, 2012 Just installed my AVIC 900BT in my 2010 chevy Tahoe using the PAC OS-4 Radio replacement Interface. Everything worked or seemed to work, here is my issue: when the vehicle is sitting still, it stats up fine, once the vehicle start moving forward, the radio is constantly rebooting until I come to a complete stop. Before I go tearing the whole system down, I would like to know where I went wrong with the installation. Quote Link to post Share on other sites
vexen1972 Posted September 29, 2012 Author Report Share Posted September 29, 2012 Just figured it out, it's my antenna...great, no GPS. Now to eBay I go to find a replacement antenna Quote Link to post Share on other sites
tail24 Posted September 29, 2012 Report Share Posted September 29, 2012 They are cheap bought one for like 25 a few years ago after I accidentally ripped mine out Quote Link to post Share on other sites
vexen1972 Posted September 29, 2012 Author Report Share Posted September 29, 2012 Yup, just bought one for 23.00, let's see what happens when it gets here Quote Link to post Share on other sites
vexen1972 Posted October 6, 2012 Author Report Share Posted October 6, 2012 Well my new antenna is installed and yet once I go over 15 mph , it starts to reboot........why,why, why ...any suggestions, could it be my vehicle speed sensor, I'm at a lost now... just checked my power harness, i don't have the Pink (CAR SPEED SIGNAL INPUT) could this be the issue? Quote Link to post Share on other sites
tail24 Posted October 6, 2012 Report Share Posted October 6, 2012 Did you run the reboot loop fix? Quote Link to post Share on other sites
vexen1972 Posted October 6, 2012 Author Report Share Posted October 6, 2012 No, not yet, downloading as I type, will do once complete...so will not having the Pink (CAR SPEED SIGNAL INPUT) cause any issues or is it not needed? Quote Link to post Share on other sites
tail24 Posted October 6, 2012 Report Share Posted October 6, 2012 Only issue it'll cause is slightly less accurate GPS Quote Link to post Share on other sites
w4rh4wk Posted October 7, 2012 Report Share Posted October 7, 2012 what firmware do you have on the F900BT? Mine use to do that with the v2.x. Quote Link to post Share on other sites
vexen1972 Posted October 8, 2012 Author Report Share Posted October 8, 2012 what firmware do you have on the F900BT? Mine use to do that with the v2.x. Â I have the v2.x..., still need to run the reboot loop fix though Quote Link to post Share on other sites
w4rh4wk Posted October 8, 2012 Report Share Posted October 8, 2012 I have the v2.x..., still need to run the reboot loop fix though If you upgrade it to version 3.X or higher it should go away (regardless of the "reboot loop fix"). If some strange reason it does continue to reboot after the upgrade, do complete wipe and restore of the unit (the step by step directions are on the forum). Quote Link to post Share on other sites
vexen1972 Posted October 9, 2012 Author Report Share Posted October 9, 2012 If you upgrade it to version 3.X or higher it should go away (regardless of the "reboot loop fix"). If some strange reason it does continue to reboot after the upgrade, do complete wipe and restore of the unit (the step by step directions are on the forum). Â Fixed the issue!!, using test mode, I went in a deleted all the gps files, so far so good, had the truck up to 70+ and no reboot...fingers and toes crossed Quote Link to post Share on other sites
tail24 Posted October 9, 2012 Report Share Posted October 9, 2012 excellent. mine as well update as well. Quote Link to post Share on other sites
w4rh4wk Posted October 9, 2012 Report Share Posted October 9, 2012 Fixed the issue!!, using test mode, I went in a deleted all the gps files, so far so good, had the truck up to 70+ and no reboot...fingers and toes crossed Good to hear! Quote Link to post Share on other sites
vexen1972 Posted October 11, 2012 Author Report Share Posted October 11, 2012 too bad I now have two GPS antenna, but it's still working like a champ, love this site..thanks all for the help Quote Link to post Share on other sites
