jeffwight Posted April 10, 2007 Report Share Posted April 10, 2007 I've looked through the posts in this forum, but can't find a direct answer to this question. I'm ordering the gear from Crutchfield. Even though they say this is a "no fit", I know it can be done. Is there a kit I should order from them that will be helpful? Thanks, -Jeff Quote Link to post Share on other sites
idbl_fanatic Posted April 10, 2007 Report Share Posted April 10, 2007 I have an 01 Expy that I am wondering the same thing Quote Link to post Share on other sites
brianas Posted April 10, 2007 Report Share Posted April 10, 2007 check here http://www.bestkits.com/SearchResults.a ... 20-%202004 i havent installed this kit myself--but it does list your application Josh Quote Link to post Share on other sites
qmfaradio Posted April 10, 2007 Report Share Posted April 10, 2007 My d3, xm with nav.traffic & backup camera was just delivered from crutchfield. I'm also looking for an mounting kit or pictures of a double din mounted in a 2000 f-250 with the dash removed. Quote Link to post Share on other sites
sportsfan21 Posted April 10, 2007 Report Share Posted April 10, 2007 My d3, xm with nav.traffic & backup camera was just delivered from crutchfield. I'm also looking for an mounting kit or pictures of a double din mounted in a 2000 f-250 with the dash removed. CF didn't give you a mounting kit and instructions on how to take your dash off? Quote Link to post Share on other sites
qmfaradio Posted April 10, 2007 Report Share Posted April 10, 2007 Crutchfield sent instructions for a single din kit. the dash is easy to remove, but i am looking for advice or pictures of the radio installed without the dash on there is no DD kit for a 2000 f-250. I did a search and all i could find were units that were already installed. I might try to modify the kit that is listed in the above post (best kit), but i am looking for other alternatives as well as pictures. Quote Link to post Share on other sites
MisFit Posted April 11, 2007 Report Share Posted April 11, 2007 there is no specific double din kit for those trucks. you have to use metra 99-5805 kit. pop rivet the trim ring to the radio opening in your dash and mount the side brackets to the radio and click it in to the trim ring from behind Quote Link to post Share on other sites
jeffwight Posted April 11, 2007 Author Report Share Posted April 11, 2007 there is no specific double din kit for those trucks. you have to use metra 99-5805 kit. pop rivet the trim ring to the radio opening in your dash and mount the side brackets to the radio and click it in to the trim ring from behind That was the info I was looking for. Thanks Misfit. Quote Link to post Share on other sites
cntrylvr79 Posted April 11, 2007 Report Share Posted April 11, 2007 there is no specific double din kit for those trucks. you have to use metra 99-5805 kit. pop rivet the trim ring to the radio opening in your dash and mount the side brackets to the radio and click it in to the trim ring from behind don't you ever get tired of typing the EXACT same thing over and over? Quote Link to post Share on other sites
MisFit Posted April 11, 2007 Report Share Posted April 11, 2007 a little bit Quote Link to post Share on other sites
medik13 Posted April 11, 2007 Report Share Posted April 11, 2007 I used the DD metra kit to fit my D2 in my 2006 F250. Fits like a glove. Got the kit off of ebay with a harness adapter as well. Quote Link to post Share on other sites
MisFit Posted April 11, 2007 Report Share Posted April 11, 2007 I used the DD metra kit to fit my D2 in my 2006 F250. Fits like a glove. Got the kit off of ebay with a harness adapter as well. congratulations, the 2006 is a completely different dash than the 2000, but thanks for your input Quote Link to post Share on other sites
jeffwight Posted April 11, 2007 Author Report Share Posted April 11, 2007 don't you ever get tired of typing the EXACT same thing over and over? I've seen Misfit's posts about using this kit for econlines, explorers, and f-150's, but I didn't think the dash was the same in the f250/350/etc. I didn't find it in my search of this site, so please point me to the post, I'd like to see if there are any good pictures of the final fit. Thanks, -Jeff Quote Link to post Share on other sites
norrin302 Posted April 11, 2007 Report Share Posted April 11, 2007 I used the Metra kit for my '00 Explorer. It didn't fit from teh start, but after some dremel work, it fits right in. Could be a better fit, but Ford could have hooked us up with a full double din instead of the 1.8 din crap. Russ Quote Link to post Share on other sites
qmfaradio Posted April 11, 2007 Report Share Posted April 11, 2007 I just bought the metra kit (99-5805) recommended by Misfit, installed speakers and started wiring the backup camera, i will install the unit in a couple days and try to post pictures. Thanks for the help and Try not to get tired of sharing info and tips, its what makes forums like this an invaluable asset to the non professional/novice installer Quote Link to post Share on other sites
