Striker317 Posted April 19, 2007 Report Share Posted April 19, 2007 Hi I was able to locate the VSS wire for the 2007 Camry SE, but I couldn't find the reverse wire. I currently don't have it connected, but since I'm going to go back into the car to clean up some loose ends this weekend, I figure I might as well attach it and do it right. Is it the same as the 2005 Camry (which someone posted the answer to below) or is it somewhere else? Also, what does DKP stand for? Thanks for any help you can provide Quote Link to post Share on other sites
05Stang-GT Posted April 19, 2007 Report Share Posted April 19, 2007 If you don't have a backup camera there isn't really any point in hooking up the reverse wire. Quote Link to post Share on other sites
vicn77 Posted April 19, 2007 Report Share Posted April 19, 2007 Reverse Light red + driver kick, 17 pin plug, pin 9 dkp = driver's kick panel Quote Link to post Share on other sites
Striker317 Posted April 19, 2007 Author Report Share Posted April 19, 2007 Hi vicn77 Thanks for your reply. Before you posted, I happened to find this doc re: the reverse wire. It says that it should be a grey coloured cable http://www.oemvalue.com/2007camry/2.jpg Just wanted to confirm which one is correct. Thanks again Quote Link to post Share on other sites
cntrylvr79 Posted April 19, 2007 Report Share Posted April 19, 2007 Both are right, you're talking about getting it on opposite sides of the vehicle Quote Link to post Share on other sites
Striker317 Posted April 22, 2007 Author Report Share Posted April 22, 2007 Thanks a lot. Found it successfully! Quote Link to post Share on other sites
supraholic Posted July 1, 2007 Report Share Posted July 1, 2007 Hi I was able to locate the VSS wire for the 2007 Camry SE, but I couldn't find the reverse wire. I currently don't have it connected, but since I'm going to go back into the car to clean up some loose ends this weekend, I figure I might as well attach it and do it right. /quote] I did some search in this forum, but where is the VSS wire for a 2007 camry ? Thanks for your help. Quote Link to post Share on other sites
