JUnverrich Posted May 14, 2007 Report Share Posted May 14, 2007 I installed my AVIC-D3 in my 2007 Honda Civic EX coupe but whenever i touch a button the the D3 its really loud and has static in the background. Same when the GPS voice talks. I turn down the voulme level in the settings and its still very loud even with it turned down all the way. Plus the static noise in the background. I had this in my last car and never did this. Plus, when i listen to my iPod or radio it sounds fine, no static. Just when the GPS talks and my D3 beeps when i hit a button. Whats going on with this? Thanks! Quote Link to post Share on other sites
JUnverrich Posted May 15, 2007 Author Report Share Posted May 15, 2007 does anyone know why this is? Please. Quote Link to post Share on other sites
idbl_fanatic Posted May 15, 2007 Report Share Posted May 15, 2007 Sounds like a bad ground Quote Link to post Share on other sites
JUnverrich Posted May 18, 2007 Author Report Share Posted May 18, 2007 i checked the ground and changed it, and still the same thing. Any ideas? Quote Link to post Share on other sites
idbl_fanatic Posted May 18, 2007 Report Share Posted May 18, 2007 maybe your pos wire then, it is SOMETHING with your wireing Quote Link to post Share on other sites
dusouth Posted May 18, 2007 Report Share Posted May 18, 2007 i have the same noise on mine but it's kinda faint. not to loud to bother me at all. Quote Link to post Share on other sites
slammnlex Posted May 19, 2007 Report Share Posted May 19, 2007 actually it sounds like u have the guidance voice turned down but the beep still on a level. and you have to make sure to turn the on and off button to off on that screen. Mine was doing that too then I turned everything off on that volume screen and it doesnt do it anymore. Hope for u thats the problem. Quote Link to post Share on other sites
cptmurphi Posted July 2, 2007 Report Share Posted July 2, 2007 I just got my d3 installed in my 07 civic si. There is a static noise that gets kind of annoying and is present whether the volume is turned down or up. When I first put my key in the ignition and turn one click, the unit powers up and there is no static whatsoever. When I turn the key one more click, that is when the static noise kicks in. The second click allows for the fan to blow and all of the dash lights to operate. I wonder if there is some kind of interference or something. Any ideas? Quote Link to post Share on other sites
rwburnett Posted July 10, 2007 Report Share Posted July 10, 2007 I'm installing this weekend in 07 civic sedan - any tips? Did you get the static to go away? Quote Link to post Share on other sites
cptmurphi Posted July 12, 2007 Report Share Posted July 12, 2007 I never did get the static to go away. Check out this link. This is how I had mine installed. It seems to be the preferred way. http://www.8thcivic.com/forums/showthread.php?t=36044 Quote Link to post Share on other sites
AwaySooner Posted July 18, 2007 Report Share Posted July 18, 2007 My D3 is having the exact same problem. Constant static noise, even when the AV is turned to off. I know it's not the amp because I unplug all RCA cables, and the D3 is still make noise at the rear speakers, which are powered by the HU directly. The ground is good, it's grounded to the chassis, and I have a uni-body subary forester. This is driving me nuts. Quote Link to post Share on other sites
