subie Posted August 7, 2007 Report Share Posted August 7, 2007 I installed the CD update no problem. I haven't done the wiring yet, however my XM stopped working. It worked before I ran the update. The XM menus work and everything seems normal, but there is no sound. Am I missing something? Thanks in advance for your help. Quote Link to post Share on other sites
whtcrxghst Posted August 7, 2007 Report Share Posted August 7, 2007 Make sure the P-bus cable is plugged in the correct hole Quote Link to post Share on other sites
subie Posted August 7, 2007 Author Report Share Posted August 7, 2007 I haven't touched any of the cables (before or after running the update), so I'm wondering if anything could have happened as a result of the update or resetting the system? Quote Link to post Share on other sites
Hyperite Posted August 7, 2007 Report Share Posted August 7, 2007 Lemme guess, your FM radio works fine, but CD player doesn't. Quote Link to post Share on other sites
shotgun_customs Posted August 7, 2007 Report Share Posted August 7, 2007 Hyperite, I know where u'r heading w/ this. Quote Link to post Share on other sites
subie Posted August 8, 2007 Author Report Share Posted August 8, 2007 I don't have the car today. I'll check tomorrow. What do you think is going on? Quote Link to post Share on other sites
shotgun_customs Posted August 8, 2007 Report Share Posted August 8, 2007 First, check to see if you have audio w/ the FM/AM tuner but not w/ any other source. If yes, then you are using the ant remote to turn on your factory/aftermarket amp. Go under system menu and change the "ant control" to power. The AVIC reset changed this to the default setting, which is tuner. Quote Link to post Share on other sites
subie Posted August 8, 2007 Author Report Share Posted August 8, 2007 Yep that's probably it. Thanks guys! Quote Link to post Share on other sites
