builderman918 Posted August 18, 2007 Report Share Posted August 18, 2007 so i read on this forum that moving and grounding the mute wire mutes the subwoofer preout...is this true cause i just install my amp and subs and the signal is very muted coming out...i really don't want to loose the bypass since pulling over to plan a route would suck...any ideas Quote Link to post Share on other sites
JasonH Posted August 18, 2007 Report Share Posted August 18, 2007 You don't ground the mute wire, you move it to the un-used pin. Check the how-to. Quote Link to post Share on other sites
builderman918 Posted August 18, 2007 Author Report Share Posted August 18, 2007 um...check out the sticky's you move the mute wire then ground it with the parking brake and radio ground here you go http://www.avic411.com/forum/viewtopic.php?t=4670 Quote Link to post Share on other sites
whtcrxghst Posted August 18, 2007 Report Share Posted August 18, 2007 Bypass has nothing to do with the subwoofer out. Zero Quote Link to post Share on other sites
builderman918 Posted August 18, 2007 Author Report Share Posted August 18, 2007 that is refreshing to hear...do you think it could be a bad rca becuase i know all the connections are right unless the amp or both subs were damaged in shippin Quote Link to post Share on other sites
Play_Her Posted August 18, 2007 Report Share Posted August 18, 2007 Be sure you have the amp connected to the rca labeled subwoofer. Also check the subwoofer adjustments under the sound menu. Quote Link to post Share on other sites
