cdaniel76 Posted August 28, 2007 Report Share Posted August 28, 2007 I just switched from a D1 to a D3 and am having trouble getting my external, stand-alone Sirius receiver to work with the D3. I have it plugged in to the red & white RCA input plugs on the accessory harness. The D3 recognizes it and shows me SOMETHING is plugged into the AV-2 input but will not play anything through the system. If I go into the settings, it only allows me to select "Video" as the AV source. My D1 allowed me to change the AV input source to either Video or Audio (The D3 only gives me a Video option, no Audio choice). Also something else weird about the D1 was it NEEDED to be on video for the Sirius to play through it. It wouldn't play when "Audio" was selected. Thanks for any help... Quote Link to post Share on other sites
whtcrxghst Posted August 28, 2007 Report Share Posted August 28, 2007 Sounds like you have it plugged into AV1, not 2. Go into the menu and switch AV1 to 'video' and you should be good to go Quote Link to post Share on other sites
cdaniel76 Posted August 28, 2007 Author Report Share Posted August 28, 2007 If it were plugged into the AV1, wouldn't it allow me to push the AV1 button on the Source Menu? The AV1 button is "grayed" out. The AV2 button is the only other button, besides "Radio", that is opperable. I'll go out and give it a try real quick and report my findings. Thanks for your reply Quote Link to post Share on other sites
cdaniel76 Posted August 28, 2007 Author Report Share Posted August 28, 2007 Well I figured it out... I went out there with the intention of making sure I was all plugged in correctly and while I had it apart, perform the "bypass". So I get the dash all taken apart and pull the radio out. All connections look fine. Everything's where it's supposed to be. Tried changing the AV1 and AV2 setups and still nothing... So I decided to come back to that later and start on the bypass. First thing I do is look for the yellow/black mute wire on the AV harness.... Can't find it... What gives???? So I think back to when I uninstalled the D1 and installed the D3. DOH!!!!!!! I remember when I opened the D3's box, the AV harness had some wires on it that the D1 harness didn't have... I mixed up the harnesses when I did the uninstallation/installation. So I swapped out the AV harnesses and BAM!, we've got Sirius! Yes, Yes... I am a goober! Thanks whtcrxghst, for your help. -Chris Quote Link to post Share on other sites
whtcrxghst Posted August 28, 2007 Report Share Posted August 28, 2007 No problem. I think AV2 is turned on from the factory for that mini plug in the front Quote Link to post Share on other sites
Stroken Posted December 6, 2007 Report Share Posted December 6, 2007 Hello all, This is my first post, Okay, I have just installed my d3 no more then 20 minutes ago. I am on the same boat, have my external sirus, shows my av 2 and all that stuff, EVERYTHING you mentioned about yours, I did not plug my yell and black mute wire into anything? so this is my problem? can you please explain, where that goes and if it will fix it, thanks guys Quote Link to post Share on other sites
whtcrxghst Posted December 6, 2007 Report Share Posted December 6, 2007 Are you plugging it into the A/V input on the front? Or the RCAs in the back? Hello all, This is my first post, Okay, I have just installed my d3 no more then 20 minutes ago. I am on the same boat, have my external sirus, shows my av 2 and all that stuff, EVERYTHING you mentioned about yours, I did not plug my yell and black mute wire into anything? so this is my problem? can you please explain, where that goes and if it will fix it, thanks guys Quote Link to post Share on other sites
Stroken Posted December 6, 2007 Report Share Posted December 6, 2007 the rca cables in the back, i do not want to plug anything into the front... Quote Link to post Share on other sites
whtcrxghst Posted December 6, 2007 Report Share Posted December 6, 2007 When you go into the initial settings menu, what is A/V1 set to? Quote Link to post Share on other sites
Stroken Posted December 7, 2007 Report Share Posted December 7, 2007 the av1 was off and av2 was on, i reversed them and what do you know, IO got it to work! guess i should of screwed around with it before i posted this, but it being 800$ and brand spanking new I didn't want to mess anything up, thanks a lot though guys. Quote Link to post Share on other sites
jjcarp123 Posted January 14, 2008 Report Share Posted January 14, 2008 I had the same problem. My s10 would not work until i did a search here and found this information. Thanks Quote Link to post Share on other sites
