jct_ucb Posted January 5, 2015 Report Share Posted January 5, 2015 Hi all, So my car was in the shop for awhile and now that I have it back I am thinking about installing Carplay for the first time. Does anyone have any advice or suggestions or warnings before I go ahead? Everything on my HU works fine, I have an iPhone 6 running the most recent IOS. Thanks for any help, JT Quote Link to post Share on other sites
joemamma1954 Posted January 5, 2015 Report Share Posted January 5, 2015 Plug into usb1. If it doesn't automatically boot to carplay, setup smartphone setup to usb, enable carplay. Quote Link to post Share on other sites
PaCharger Posted January 6, 2015 Report Share Posted January 6, 2015 Plug into usb1. If it doesn't automatically boot to carplay, setup smartphone setup to usb, enable carplay. Wouldn't it be best to connect to hdmi and usb1, then to adapter and have everything enable with one connection? Quote Link to post Share on other sites
9512tacoma Posted January 6, 2015 Report Share Posted January 6, 2015 Wouldn't it be best to connect to hdmi and usb1, then to adapter and have everything enable with one connection? I don't think carplay will work through the hdmi adapter from apple. Quote Link to post Share on other sites
joemamma1954 Posted January 6, 2015 Report Share Posted January 6, 2015 I don't think carplay will work through the hdmi adapter from apple. you either have carplay via usb1 or app radio via apple a/v adapter. can't have both. Also note, when you have apple a/v adapter hooked up, the usb port is used for charging only, the head unit will not connect thru the usb to lightning, and if you hit usb1 while hooked up this where are you, it will give you an error message, "not a compatible device". You have to understand, the apple digital a/v adapter separates the audio/video and sends thru hdmi to head unit. charging is thru lightning to usb, no communication, head unit communicates to iPhone thru bluetooth. Quote Link to post Share on other sites
