ryoung77 Posted April 5, 2015 Report Share Posted April 5, 2015 Pressing "the spot" on the lower left corner does not work on this unit as it does on previous NEX models(8100,8000 for example)..PAC TR7 does not work either..Seems a simple on/off switch is the only thing that will bypass it..Any ideas? Quote Link to post Share on other sites
ryoung77 Posted April 5, 2015 Author Report Share Posted April 5, 2015 Possible extend the time out on the negative trigger wire on the TR7? Quote Link to post Share on other sites
jeremyh Posted April 5, 2015 Report Share Posted April 5, 2015 yeah I would like to know too, I just installed the 4100nex on thursday, I grounded brake wire to the radio ground like I did on my 8000nex, and I never had the nag screen unless I shut the radio off on the navigation screen, then if I had it on Sirius radio and I shut the radio off and turn it back on, it would just go to the Sirius screen without the nag screen, yeah the 4100nex ask me no matter what source i`m on always give me the nag screen. Quote Link to post Share on other sites
ryoung77 Posted April 5, 2015 Author Report Share Posted April 5, 2015 It only appears to be an issue on the 4100, and the 4000 to i believe. Quote Link to post Share on other sites
ryoung77 Posted April 5, 2015 Author Report Share Posted April 5, 2015 I think the issue is that the TR7 comes on and does its thing and times out before the intial Pioneer/NEX splash screen, and first warning screen..So the unit may never really see a no ground/ground immulation Quote Link to post Share on other sites
ryoung77 Posted April 5, 2015 Author Report Share Posted April 5, 2015 Ive put in a few of the 4100s and 8100s..seen a sum quercks in both units Quote Link to post Share on other sites
nolarola Posted April 5, 2015 Report Share Posted April 5, 2015 Need a micro bypass for the 4000 Quote Link to post Share on other sites
ryoung77 Posted April 5, 2015 Author Report Share Posted April 5, 2015 Is that like a double pulse trigger Quote Link to post Share on other sites
tickerguy Posted April 5, 2015 Report Share Posted April 5, 2015 Yep. I have one for my 4000 and it works fine. Quote Link to post Share on other sites
kenny36 Posted April 6, 2015 Report Share Posted April 6, 2015 i install the 4100nex i had to get a bypass on ebay it was like 15 dollars to by pass it but it does work i think the seller its lessco electronics on ebay Quote Link to post Share on other sites
ryoung77 Posted April 6, 2015 Author Report Share Posted April 6, 2015 Thanks for all the info everyone..ill get one on the way and give it a whirl Quote Link to post Share on other sites
ZomBGreaseMnky Posted April 11, 2015 Report Share Posted April 11, 2015 I have the 4100NEX we ran a toggle switch and it works with no issues at all. Quote Link to post Share on other sites
Welder69 Posted April 22, 2015 Report Share Posted April 22, 2015 When I installed my 4100 with the micro bypass it does not work!!!! Load time is to long..... the bypass turns on before the system boots up.If there is another solution i would like to know, other then a toggle switch. Quote Link to post Share on other sites
NSCRDV Posted April 22, 2015 Report Share Posted April 22, 2015 you are using the wrong micro bypass - this one is what it's designer directed me to use: http://amzn.com/B00VKQ6ECQ Quote Link to post Share on other sites
galvan3 Posted April 23, 2015 Report Share Posted April 23, 2015 Yep. I have one for my 4000 and it works fine. Just wondering tickerguy, did you just match wire for wire and was it good to go? The reason I ask is because ive heard that a wire had to be moved over in the harness or something like that. Just installed a 4100 yesterday and tried a 2 pole switch but it wasn't working for me. (Connected parking brake wire to one side and a wire that was tapped to the ground wire from the harness to the other side on a 15 amp switch. Did I miss anything?) anyway, purchased a bypass so just wondering. Quote Link to post Share on other sites
