cleverdicky Posted June 2 Report Share Posted June 2 Hi, thanks for advice. I tried all night but now something isnt working right. As soon as i click open on Putty, (without radio switched on) im getting a new window with streams of data garbage, that looks like upside down U's. Obviously tried connections etc. If I switch on radio (before I click open) nothing happens. I think the usb things shagged. I'll get another one. Quick Q's, as I've not done this before, is U-boot a menu? in the radio. I searched the web but could only find referance to android boot options. Quote Link to post Share on other sites
asd255 Posted June 3 Report Share Posted June 3 check the connection. and PuTTy settings Quote Link to post Share on other sites
cleverdicky Posted June 4 Report Share Posted June 4 Good afternoon. I got the settings thanks. Problem was cheap usb - serial device. I think it fried somehow?? Anyhow, got new one yesterday and installed PuTty on another better laptop. Still win 11 tho :-( result was exactly the same. I tried with settings window open -> turned on radio. Nothing. Opened Putty after setting as above and then get uboot window. tried everything to add command, pressed keys / space bar etc as soon as radio turned on and always the same. I dont get all the data that other posts have shown before it reloops. But Im pasting below a couple of loops worth. You might see something in here thats useful? The strange characters are a worry ? Net: got MAC address from IIM: 00:00:00:00:00:00 FEC0 [PRIME] BSP A is valid BSP B is valid imx6 core num: 2 BSP A is valid BSP B is valid warp boot side A Lineo Warp!! 4.0.0 (Jupiter14 1.0.1) Tue Jan 14 13:23:03 JST 2014 SDHC2 'SU32G' 30436MB 4bit 50.0Mbit/s (HS) block: 512 sect: 127 spec: 3 Snapshot ID : e95d22fe Snapshot total size : 0x123fb440 compressed size : 0x02e35974 --- Read Snapshot --- 00800000 U-Boot 2009.08 (Jan 06 2014 - 16:32:44) CPU: Freescale i.MX6 family TO1.1 at 792 MHz Thermal sensor with ratio = 181 Temperature: 30 C, calibration data 0x57c4c97d mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 198000000Hz emi_slow clock: 99000000Hz ddr clock : 396000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6DL/Solo-JUPITER: unknown-board Board: 0x61011 [POR ] Boot Device: NOR I2C: ready DRAM: 1 GB Flash: 8 MB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2 Using default environment In: serial Out: serial Err: serial ***** display DDR calibration result ***** *************************************** Display result(register) of WriteLeveling MMDC registers updated from WriteLeveling MPWLDECTRL0 (0x021b080c) = 0x002F0035 MPWLDECTRL1 (0x021b0810) = 0x0018001C *************************************** Display result(register) of DDR calibration MMDC registers updated from calibration Read DQS Gating calibration MPDGCTRL0 PHY0 (0x021b083c) = 0x421D0214 MPDGCTRL1 PHY0 (0x021b0840) = 0x0177017B Read calibration Q1▒PHY0 (0x021b0848) = 0x48494C49 Write calibration MPWRDLCTL PHY0 (0x021b0850) = 0x413E3F41 *************************************** Net: got MAC address from IIM: 00:00:00:00:00:00 FEC0 [PRIME] BSP A is valid BSP B is valid imx6 core num: 2 warp boot side A Lineo Warp!! 4.0.0 (Jupiter14 1.0.1) Tue Jan 14 13:23:03 JST 2014 SDHC2 'SU32G' 30436MB 4bit 50.0Mbit/s (HS) block: 512 sect: 127 spec: 3 Snapshot ID : e95d22fe Snapshot total size : 0x123fb440 compressed size : 0x02e35974 --- Read Snapshot --- 00800000,▒▒▒▒▒▒cc00000 C▒▒▒▒$HHHT"@▒▒▒▒▒▒▒▒▒▒▒▒▒@ ▒ @▒warp boot side A Lineo Warp!! 4.0.0 (Jupiter14 1.0.1) Tue Jan 14 13:23:03 JST 2014 SDHC2 'SU32G' 30436MB 4bit 50.0Mbit/s (HS) block: 512 sect: 127 spec: 3 00800000▒▒▒▒▒▒▒0▒▒j3c800000 ▒▒▒▒~▒▒▒▒?▒▒▒▒ B▒▒▒▒▒H▒+D▒A (@▒▒ ▒ @ @ @@▒@▒ ▒▒@@@▒ ▒@▒ ▒@▒ ▒ U-Boot 2009.08 (Jan 06 2014 - 16:32:44) Quote Link to post Share on other sites
asd255 Posted June 4 Report Share Posted June 4 if you cannot enter commands, then you have a problem connecting the TX wire from the USB TTL adapter you also have an unstable RX connection I see artifacts in your log 4 hours ago, cleverdicky said: Snapshot total size : 0x123fb440 compressed size : 0x02e35974 --- Read Snapshot --- 00800000,▒▒▒▒▒▒cc00000 C▒▒▒▒$HHHT"@▒▒▒▒▒▒▒▒▒▒▒▒▒@ ▒ @▒warp boot side A Lineo Warp!! 4.0.0 (Jupiter14 1.0.1) Tue Jan 14 13:23:03 JST 2014 SDHC2 'SU32G' 30436MB 4bit 50.0Mbit/s (HS) block: 512 sect: 127 spec: 3 00800000▒▒▒▒▒▒▒0▒▒j3c800000 ▒▒▒▒~▒▒▒▒?▒▒▒▒ B▒▒▒▒▒H▒+D▒A (@▒▒ ▒ @ @ @@▒@▒ ▒▒@@@▒ ▒@▒ ▒@▒ ▒ U-Boot 2009.08 (Jan 06 2014 - 16:32:44) Quote Link to post Share on other sites
cleverdicky Posted June 5 Report Share Posted June 5 Guys i've been at this for hours. Although Im nearly blind now staring at those tiny holes, I've remade connections and data is nice and clean now. Thanks for the tip. But still not sending commands. I press keys as soon as pwr to radio and keep pressing but nothing opens. If I click open 1st then turn on radio I get data, but still nothing happens when I press keys. I've checked and rechecked all pins. over and over. I've also searched for an older version of PuTTy as I noticed the images here dont match the one I have. I will have a search & read for an alternative unless there are any recomendations. Quote Link to post Share on other sites
asd255 Posted June 5 Report Share Posted June 5 what radio do you have? Quote Link to post Share on other sites
cleverdicky Posted June 5 Report Share Posted June 5 OK, Im making progress. I can type now and it pauses window data ;-) I tried easyrecovery - nothing. Tried bsp init and it had some effect. (below) Now I have no boot loop but have the standard software error - contact pioneer service center. :-( Does that mean I need new sdcard ? MX6SDL JUPITER KT 4.2.2 U-Boot > MX6SDL JUPITER KT 4.2.2 U-Boot > U-Boot 2009.08 (Jan 06 2014 - 16:32:44) CPU: Freescale i.MX6 family TO1.1 at 792 MHz Thermal sensor with ratio = 181 Temperature: 40 C, calibration data 0x57c4c97d mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 198000000Hz emi_slow clock: 99000000Hz ddr clock : 396000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6DL/Solo-JUPITER: unknown-board Board: 0x61011 [POR ] Boot Device: NOR I2C: ready DRAM: 1 GB Flash: 8 MB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2 Using default environment In: serial Out: serial Err: serial ***** display DDR calibration result ***** *************************************** Display result(register) of WriteLeveling MMDC registers updated from WriteLeveling MPWLDECTRL0 (0x021b080c) = 0x00310037 MPWLDECTRL1 (0x021b0810) = 0x0018001E *************************************** Display result(register) of DDR calibration MMDC registers updated from calibration Read DQS Gating calibration MPDGCTRL0 PHY0 (0x021b083c) = 0x42230217 MPDGCTRL1 PHY0 (0x021b0840) = 0x0177017B Read calibration MPRDDLCTL PHY0 (0x021b0848) = 0x47494C49 Write calibration MPWRDLCTL PHY0 (0x021b0850) = 0x413F4041 *************************************** Net: got MAC address from IIM: 00:00:00:00:00:00 FEC0 [PRIME] BSP A is valid BSP B is valid imx6 core num: 2 BSP A is valid BSP B is valid match invalid password 2. main loop boot env = run bootargs;booti mmc1 ${bootpartition} Hit any key to stop autoboot: 0 mmc1 init failed boot error, will boot easyrecovery!! BSP A is valid BSP B is valid -launch mode . done Erased 1 sectors . done Erased 1 sectors boot easyrecovery !! main loop boot env = run bootargs;booti ${bootaddr} Hit any key to stop autoboot: 0 kernel @ 10808000 (2829424) ramdisk @ 11800000 (877890) kernel cmdline: use uboot command line: console=ttymxc0,115200 init=/init androidboot.console=ttymxc0 video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:dev=ak8814,BT656-NTSC,if=BT656,bpp=32 video=mxcfb2:off fbmem=6M,6M vmalloc=400M androidboot.hardware=freescale arm_freq=800 printk.time=1 printk_console=off Starting kernel ... Uncompressing Linux... done, booting the kernel. Quote Link to post Share on other sites
asd255 Posted June 5 Report Share Posted June 5 use "warp" command Quote Link to post Share on other sites
cleverdicky Posted June 5 Report Share Posted June 5 No MMC card found ? and its looping again ?? Quote Link to post Share on other sites
asd255 Posted June 5 Report Share Posted June 5 17 hours ago, asd255 said: SDHC2 'SU32G' 30436MB 4bit 50.0Mbit/s (HS) block: 512 sect: 127 spec: 3 0080000 I see in the log that the SD card is available Quote Link to post Share on other sites
cleverdicky Posted June 5 Report Share Posted June 5 Hi yes this is weird. I'm not so familiar that I no whats going on. But it is still boot looping unless I type bsp init. Then it seems to run a script, sorts itself out and brings up the software error on the radio screen. Putty then goes blank. Typing warp when it boots brings the error 'no mmc'. So i tried adding a new blank sdcard in the user slot, but no change. (could it be looking for update / firmware ? ) I also tried putting the original factory sdcard back in but no change. Also I noticed that the screen wont open now by the buttons. So may have some loose ribbons or could be as it hasnt fully booted. Unit is F60DAB Quote Link to post Share on other sites
Join the conversation
