RonS Posted April 1, 2021 Author Report Share Posted April 1, 2021 23 hours ago, salfrax said: Hi RonS, thanks for your quick reply. I followed your suggest, but in USER\SYSTEM\SECURITY there is no file... Take a look at this: http://avic411.com/index.php?/topic/90633-unabte-to-enter-the-password-or-modify-any-setting-on-a-f840bt/&do=findComment&comment=357725 Quote Link to post Share on other sites
drevlin Posted April 23, 2021 Report Share Posted April 23, 2021 is there someone who can give me a working link to this program? Quote Link to post Share on other sites
RonS Posted April 24, 2021 Author Report Share Posted April 24, 2021 11 hours ago, drevlin said: is there someone who can give me a working link to this program? Nothing wrong with the link. You must be a registered user. Since you now are registered, try again. Quote Link to post Share on other sites
ips Posted May 1, 2021 Report Share Posted May 1, 2021 On 2/26/2019 at 5:19 PM, RonS said: It should work. Easy (and safe) to find out. No, these instructions didn't work on X9310BT. Quote Link to post Share on other sites
d.gst 14 Posted May 1, 2021 Report Share Posted May 1, 2021 Merci ! Le script a parfaitement fonctionné sur mon AVIC-F930BT. Quote Link to post Share on other sites
RonS Posted May 1, 2021 Author Report Share Posted May 1, 2021 9 hours ago, ips said: No, these instructions didn't work on X9310BT. What, if anything, did it do? Did you get any errors? Quote Link to post Share on other sites
ips Posted May 31, 2021 Report Share Posted May 31, 2021 No, did not get any errors at all. Quote Link to post Share on other sites
lb2204 Posted July 2, 2021 Report Share Posted July 2, 2021 Ok, maybe a little bit outdated that im still using a avic, but they switched recently my battery, and had the same password issue. Many kudos for you, the script still works fine. Even in 2021 Quote Link to post Share on other sites
gokul Posted July 16, 2021 Report Share Posted July 16, 2021 On 1/29/2019 at 2:00 AM, Ytumer said: As a follow-up; I had contacted Pioneer about my password issue and was waiting on a reply when I came across this thread. I thought I'd try the script instead of waiting for a reply, which worked perfectly for me. Turns out the Pioneer tech support team is extremely helpful. They sent through these instructions for me to clear my password. I haven't personally tried it as I had already run the script in this thread. If the script isn't working for anyone and you'd like to try an official alternative method to reset the password (not remove the prompt completely as this script does) please see the attached picture with instructions. I'm not sure which models this will work for as the reply to my email was specific to my AVIC F840BT. I'm sure other models with a similar password prompt will likely have the same procedure. I didn't think posting this would be more of an issue for theft than this script already is. Either method is easy and does the same thing so... Wow. Worked for AVIC-F930BT Quote Link to post Share on other sites
EEdithSSR Posted July 25, 2021 Report Share Posted July 25, 2021 ty Quote Link to post Share on other sites
Hunterbres Posted August 19, 2021 Report Share Posted August 19, 2021 How are you? I just installed this radio in my vehicle and now it’s asking for a password. I was wondering if you have an updated script or if you can re-post the script zip file because it’s taken down on the old thread. It would be very much appreciated Quote Link to post Share on other sites
RonS Posted August 19, 2021 Author Report Share Posted August 19, 2021 2 hours ago, Hunterbres said: you can re-post the script zip file because it’s taken down on the old thread. The download works fine. You must be a member to download any files hosted by avic411. Since you've now joined, try again. Quote Link to post Share on other sites
winglam132 Posted September 15, 2021 Report Share Posted September 15, 2021 superr just done my f940bt your files are great and simple keep up the good Quote Link to post Share on other sites
12Chrismike Posted September 19, 2021 Report Share Posted September 19, 2021 I have a prionner x930BT i forget the password was need help 9515032309 Quote Link to post Share on other sites
RonS Posted September 19, 2021 Author Report Share Posted September 19, 2021 22 hours ago, 12Chrismike said: I have a prionner x930BT i forget the password was need help I am not sure what you are trying to say. This thread has all the help you should need. You should ask a specific question if you don't understand something about the process. Quote Link to post Share on other sites
Join the conversation
