sheringham Posted September 30, 2017 Report Share Posted September 30, 2017 Has anyone an idea if this device supports speedcams - and if so if IGO speedcam files can be used ? I have looked in different forums and I see that some users are mentioning thoose .txt files to be compatible ... I have copied as suggested it to a SD card (FAT32 - default settings ) and to this path : F:\poi\speedcam\ But when starting the Pioneer nothing is loading ?Is there anyone in here that might know about this option ? speedcam_DK.txt Quote Link to post Share on other sites
Sjarrel Posted October 1, 2017 Report Share Posted October 1, 2017 Has anyone an idea if this device supports speedcams - and if so if IGO speedcam files can be used ? I have looked in different forums and I see that some users are mentioning thoose .txt files to be compatible ... I have copied as suggested it to a SD card (FAT32 - default settings ) and to this path : F:\poi\speedcam\ But when starting the Pioneer nothing is loading ? Is there anyone in here that might know about this option ? The unit accepts speedcams but not on the way you added them, in the link http://s000.tinyupload.com/index.php?file_id=18892399194920218897 you can find a rar file and that's the way it works. Greetings from Holland Quote Link to post Share on other sites
sheringham Posted October 2, 2017 Author Report Share Posted October 2, 2017 OK - I will try that later - thnx for mentioning this Sjarrel I see 3 files from 2014 ? Arent there any newer once .How to actually perform the update ? Quote Link to post Share on other sites
Sjarrel Posted October 4, 2017 Report Share Posted October 4, 2017 OK - I will try that later - thnx for mentioning this Sjarrel I see 3 files from 2014 ? Arent there any newer once . How to actually perform the update ? BPost.PNG Your welcome! and this is very old and i don't know if the update the speedcams. this was bought from poibase.com Quote Link to post Share on other sites
frisk Posted October 16, 2017 Report Share Posted October 16, 2017 Hi, I can provide actual fixed speedcams (from POIbase) for F930BT/F9310BT... here Quote Link to post Share on other sites
