salfrax Posted March 20, 2021 Report Share Posted March 20, 2021 Hi guys, I recently bought a second hand Hyundai i20 Sound Edition. The machine is equipped with an AVIC-F840BT as standard. The device seems to work normally (gps or radio functions normally), but it is not possible to change any settings (for example, devices cannot be associated with bluetooth) and even trying to reset the device, it is not possible to enter the password because the keyboard is disabled. Anyone have any idea how changes can be enabled? Thanks. Quote Link to post Share on other sites
RonS Posted March 21, 2021 Report Share Posted March 21, 2021 Assuming it is correctly installed, set the parking brake. Many menu items and settings will not work if the parking brake is not detected. Quote Link to post Share on other sites
salfrax Posted March 22, 2021 Author Report Share Posted March 22, 2021 Thanks Rons for your replay, but I definitely engaged the parking brake, but the problem remained. I was hoping that someone who has the same car could help me to understand where to check the correct connection of the sensor. Quote Link to post Share on other sites
BlakeStone Posted March 25, 2021 Report Share Posted March 25, 2021 You will have to find the wire that is supposed to go to the parking brake. It may have come loose and just needs to be re-connected. Quote Link to post Share on other sites
salfrax Posted March 26, 2021 Author Report Share Posted March 26, 2021 Hi guys, the automotive electrician says the system is locked because the wrong password has been entered more than three times and therefore the system is under protection. He reports that it is necessary to contact Pioneer support. Is it really necessary or is there a way to unlock the device? Thanks Quote Link to post Share on other sites
BlakeStone Posted April 1, 2021 Report Share Posted April 1, 2021 If your radio is not asking for a security code to re-enable it, then it is as I have described and you need to find and re-attach the emergency brake wire(or just ground it permanently to bypass this feature). If it is asking for a code then I have not seen a way around this other than calling Pioneer. I don't think you need to send the unit in, but you might have to take it out to find the serial number or something like that. Quote Link to post Share on other sites
RonS Posted April 1, 2021 Report Share Posted April 1, 2021 Yeah, I'm starting to think this isn't a case of it being hard-locked due to 3 failed password attempts. In that case I'd expect it to prevent usage at all, while providing some sort of info on the screen at boot time. I see that Navi Settings is grayed-out, so it can't be used to check (via Connection Status) if the Parking Brake is being detected as "On". However in TestMode, # 22. External Connection Test shows its status. From the maintenance manual: Quote Link to post Share on other sites
salfrax Posted April 4, 2021 Author Report Share Posted April 4, 2021 Hi RonS, thanks for your courtesy. I went in "testmode", but the menù is different (probably is different for F840BT model). I find a similar item at #33 as you can see in attached photo; unfortunately, however, I cannot understand the meaning of the output. Quote Link to post Share on other sites
RonS Posted April 4, 2021 Report Share Posted April 4, 2021 I don't know enough about your car or the F840-BT to say whether that CAN-BUS test applies to your situation. Some cars use CAN-BUS to communicate between various components. You would need lots of technical info about your car to know if your parking brake has a CAN-BUS interface. Judging by that last picture, it doesn't seem to be connected via CAN-BUS. There might be more info in the F840-BT installation manual. Most cars just have a simple switch as part of the parking brake lever/pedal. The headunit just has a parking brake wire in the harness that is supposed to be connected to that switch. Many people just ground that wire (to fool the headunit into thinking the parking brake is always set) instead of connecting it as shown in the installation manual. Quote Link to post Share on other sites
