ok, i had my original disc in the drive and i figured maybe the menus in another language were ok so i switched it to french. when it switched over it also loaded the firmware from my original disc. so now im good to go. but if someone can figure out what files to delete to stop the system from updating with the new disc then we would all be set...except for the east coast guys
Hmmm, that's different. Is your disc rather old? My previous disc was CNDV-70MTP. There are other parts like GPS, System, etc. On mine, all those things matched the N5 disc, the only difference was the missing PRG file. When I did a file compare on mine, all the UC010*.* files matched mine.
If you got the PRG from an older disc with an older version, all the other files are probably newer so that's why you've got mismatched files and it tried to update the language and other parts. Total guess, but I think using an older disc, you're going to need to also copy over the UC050*.* files for the D1/D2 in order for it to not update. Probably the only reason I didn't need to is my previous disc was CNDV-70MTP.
Yeah, this is definitely not the official retail release. It's an "OEM" version specific for the N5. The CJ1226blahblah (forget exactly) version number is an indication of that, the real release will have a version starting with CNDV-80MP.
