Progress Report
By BorisM · Sep 10, 2008in Hacks/Mods💬 361 posts👁️ 65,220 views
Page 10 of 15
Posted Feb 28, 2009 · 03:05 UTC#226
Changres are in Navigatemap and Route UI files. I'll need to look up what the exact changes were, since I am not running it right now. Pretty miunor, though. You basically need to call SIMULATE instead of FLYOVER mode from the Route information screen.
Posted Feb 28, 2009 · 08:03 UTC#227
if ever you have the chance could you post it up, thanks
Posted Feb 28, 2009 · 10:31 UTC#228
Standard speed display code will work for simulation.
To hide other buttons, replicate exactly what it does for Stop button.
All other buttons hide when I press the stop button. But what I want to know is how do I get the buttons to hide when the simulation finishes and I did not get the chance to press the stop button.
Posted Feb 28, 2009 · 18:38 UTC#229
I'll try, need to find if I still have these files somewhere.
Posted Feb 28, 2009 · 18:40 UTC#230
I would think it should be the same code that makes the Stop button disappear. I'll see if I can find it...
Posted Mar 02, 2009 · 13:58 UTC#231
Hi Guys,
I created my own speedindicators. I expanded the box in the downleft corner so that it shows the speedlimit, drivespeed and elevation. Al of them with icons and transparency.
What I want to do now is change the color from drive speed into red when you exceed the speedlimit and position the visual speedcam warning all to the right of the screen because it is displayed behind the modification now.
Does anyone know how to change color on this condition and where I can reposition the visual speedcam warning?
BorisM, did you have any luck on finding out how the stop button gets hidden when the simulation ends?
If someone is interested in this mod, please let me know and I will post my files.
Posted Mar 02, 2009 · 14:51 UTC#232
To change the speedcam warning position you need to modify the ui_SpeedCamWarningLayer in speedcam_800_480.ui in ui_pioneer\800_480\ui. Here is my code that moves it to the right. Bear in mind I use an Ipod so mine stops short of the ipod artwork, if you don't use an ipod then you might want to move the x of the all the elements in the box further right.
Hope this helps.
Matt
Posted Mar 02, 2009 · 16:39 UTC#233
Haven't looked at stop button yet -- wasn't home over the weekend.
For speed numbers, you could try something like this (from Gurjon skin):
You'll need to adjust positions and colors acordingly...
Posted Mar 02, 2009 · 17:00 UTC#234
si i was able to figure out the simulation controls and all taht, now i'm having the same problem as TOXIT
Posted Mar 02, 2009 · 22:16 UTC#235
I like the idea of a bigger info box, any chance you can post a closer/more detailed pic?
Posted Mar 03, 2009 · 10:21 UTC#236
GTIMatt
I have changed the speedcamwarning code as you suggested. Unfortunately I don't get speedcamwarnings when I'm simulating my route for some reason so I can't test it yet, but I'm sure it will work. Thank you for your reply!
BorisM
I used your advise for the color change and it works perfectly. When I'm over the speedlimit the speedindicator turns red. Thank you for your reply!
Dumpystig
The previous pic was made with my mobile phone. I have made one with my digital camera now. If you want the files, please let me know.
The only thing left to do is to find out how to hide the simulation buttons when the simulation ends without pressing the stop button. If anyone has any suggestions, please reply.
Posted Mar 03, 2009 · 10:47 UTC#237
Toxit,
That looks really good, but what's the display at bottom right, and what is the icon?
Next thing, I'm no Photoshop man (as you can see :lol: ), so how much trouble would it be for you to make a similar box as yours, only with all the info displayed one above the other, as in the pic below?
Posted Mar 03, 2009 · 11:24 UTC#238
Dumpystig,
Creating the box isn't the most of the work. Finding out the exact positions of the icons and text is what takes the most time because you have to run in and out of your car all the time to change the pixels one or two positions. The box on the bottom right shows your elevation.
If you position the boxes on top of each other, you don't have enough free place. The top box would be positioned on top of your second driving instruction. Also, the scale indicator would be visible through the boxes. All of that has to be changed to make it work like that and that will take a lot of time. That's why I made it like this.
I'm no photoshop man either, I used a program called Slavasoft Paint Express. This program shows you the transparency while you edit your picture like in Windows Paint. Editing the box is very easy this way. All you have to do then is figure out the exact locations of the icons and text. The box is called: "746_32K_OM-014_32b.bmp" and is located in the "\ui_pioneer\800_480\" folder. The icons are: "746_32K_OM-062_32b.bmp", "746_32K_OM-063_32b.bmp" and "746_32K_OM-066_32b.bmp" in the same folder.
Posted Mar 03, 2009 · 12:06 UTC#239
Iknow plenty about altering 'x', 'y', 'w' coordinates, I had to change a shed load in my DATA.zip mod, so for me that's the easy part! But I've got the 500 so I do whatever I need in the comfort of my den LOL. And I've got rid of map scale.
I can still have a column of six boxes, it's a simple case of altering outer box height to suit available space and then dividing into six boxes slightly shallower than yours. Then if any fontsizes need to be adjusted I can also do them to suit.
Can you post your mods to date so I can have a look at doing my mod to your mod :)
And thanks for info on Slavasoft, I'll have a look at it tonight.
Cheers
Posted Mar 03, 2009 · 14:37 UTC#240
Dumpystig,
I have the edited box .bmp file and a .txt file with all the changes I made for the speed and elevation indicators. I hope you find it usefull.
Speed Indicators.rar
Posted Mar 03, 2009 · 16:22 UTC#241
Toxit,
Thanks for your file, I've d/l'd it and will have a look a bit later. Will let you know how I get on, but seeing how it looks in your pics I'm already impressed!
:D
Posted Mar 03, 2009 · 16:26 UTC#242
Toxit,
:D
Posted Mar 03, 2009 · 16:26 UTC#243
I'm REALLY pissed off with these double/treble posts, I'm only submitting them once FFS
:x
Posted Mar 03, 2009 · 16:52 UTC#244
BorisM
You're welcome.
Also, when you are doing a flyover there will be no speedcam warnings. You might get some if you change it to Simulate mode.
Posted Mar 03, 2009 · 18:03 UTC#245
BroisM, sorry I am a bit confused on how to get all the functions from your scripts. I copied the newest scripts from the first post on page 1 and overwrote what's in my Data.zip. I got the POI search by address, but the street number does not show. Do I have to use the 798.66k file in page2? I did a comparison of the extraction between the scripts and my original Data.zip, some of my original files are newer (I have 500BT w/ firmware 2.0). So I am not sure if I should use your scripts to overwrite all my files. And if I do, do I just overwrite .ui files or all files?
The other question is about skin. The 8.0 skin from igo8mods doesn't have 800*480 (only 8.3.x skin has 800*480). Do I just use any 8.0 skin for other resolutions?
Thanks.
Posted Mar 03, 2009 · 18:19 UTC#246
Thanks.
You can't use skins with built-in iGO, at least not until someone makes a full skin for us...
Did you overwrite all of the UI files in data.zip with бьшту or some? For example, house numbers are in navigatemap_800_480.ui...
Posted Mar 03, 2009 · 18:49 UTC#247
Toxit,
What were the original navigate and speedcam files that you started with? Were they stock files or from someones DATA.zip mods?
Posted Mar 03, 2009 · 20:08 UTC#248
Toxit,
Doesn't matter about above post, I've sorted my initial prob.
Your mod looks great, going for a drive shortly to give it a try out. But I've found a prob, wonder if you're having the same as me: in > Navi Settings >Visual > Map Settings, when Full Screen Cockpit is turned on and return button or map button are pressed, the unit turns off and then restarts at Navi/Map caution screen. Any ideas on this?
I'm off for try out, back shortly :)
Posted Mar 03, 2009 · 21:46 UTC#249
dumpystig,
I don't know about this problem. I have never used the full screen cockpit function before. I will check this first thing tomorrow and let you know.
As for your first post, I've modded everything from my stock data.zip.
Posted Mar 04, 2009 · 00:59 UTC#250
Hi Toxit. Can you please help me? I'm trying to have my current speed indicator which i took from keeper and have it stay exactly the same as it is now but have it change to the color red when over the speedlimit. I'm really not understanding the code and would appreciate if u could just add to my code to get that to work. Thanks
Page 10 of 15
