Progress Report
By BorisM · Sep 10, 2008in Hacks/Mods💬 361 posts👁️ 65,220 views
Page 12 of 15
Posted Mar 05, 2009 · 22:19 UTC#276
so tell me if i get it right, i only have the faster.slower button, so does that mean that i only have to put
btnNMB_Faster.Hide
btnNMB_Slower.Hide
on the three files?
Posted Mar 05, 2009 · 23:00 UTC#277
btnNMB_Faster.Hide
btnNMB_Slower.Hide
on the three files?
Yes... if you try to hide a button that does not exist, it will throw an error and quit (probably rebooting the unit)...
Posted Mar 05, 2009 · 23:12 UTC#278
I think that would be your problem. I think that when the unit boots, the sc_ShowTopMenu script in the start.ui file gets executed. If you refer to undefined objects in your scripts, the unit hangs or gives an unknown object error message.
If you have only those two buttons defined, you should only use those buttons in the code. To be sure, you should check if those buttons are named exactly like that in your navigate_800_480.ui file. Otherwise you will still be referring to undefined buttons.
You can check my files in my previous post to see what I mean or you can try them all on your unit first to verify that they work if you're still not sure.
Posted Mar 06, 2009 · 05:10 UTC#279
damn, still can't get it to work,
Posted Mar 06, 2009 · 19:24 UTC#280
finally, had to go through all the ui files,
here's what i got,
no route
route active
simulate buttons
thank for all the help
Posted Mar 06, 2009 · 20:29 UTC#281
Mind posting your data.zip somewhere?
Posted Mar 08, 2009 · 03:03 UTC#283
Toxit,
Your modded speed warning/route info box is great, thanks for the details.
I'm now looking at your route simulation mod, but need your buttons:
Pause.bmp#3
Resume.bmp#3
I've had no luck finding them, what folder are they in?
And any chance of some pics of the simulation screen?
Posted Mar 08, 2009 · 03:32 UTC#284
i rather like that... good job man
Posted Mar 08, 2009 · 05:17 UTC#285
ill.die.trying
PostPosted: Fri Mar 06, 2009 8:45 pm Post subject:
here's my data.zip if anyones interested
http://rapidshare.com/files/206168761/DATA.zip.html
this crashes me when i try to open my gps... anyone else have this problem?
am i missing something besides just the data.zip like fonts or something?
Posted Mar 08, 2009 · 10:12 UTC#286
ill.die.trying
forgot to add the the font for the current speed mod, here it is
http://rapidshare.com/files/206739689/DS-DIGI.TTF.html
add that to your apl2 folder, let me know how it goes, and any comments would be ver ymuch appreciated
Posted Mar 08, 2009 · 17:30 UTC#287
why does it do this?
White silhouette around the images I created that are what the original images are.
Any way to fix this? I want these to match the theme on the rest of my system.
Posted Mar 08, 2009 · 17:55 UTC#288
photoshop would fix that
Posted Mar 08, 2009 · 18:39 UTC#289
yeah.... it should...
which is what i used to make these images
but it doesn't...
it's like there's a shadow layer or something... that wants to add to or cut off on my replacement images
Posted Mar 08, 2009 · 21:01 UTC#290
hey could you do me a favor, can you upload my data.zip and the font to the FTP site, i guy was asking for it but i can't get access to it
Posted Mar 08, 2009 · 21:20 UTC#291
but it doesn't...
what i would suggest is redo all your images, i'm guessing you used my images and then just copied over the images you wanted, if that's the case you should check channels tab in PS and see if your new image is masked or just the previous image,
Posted Mar 09, 2009 · 03:08 UTC#292
you got it, I'll try that out
Posted Mar 09, 2009 · 03:18 UTC#293
dude good call, I didn't even think of that
Posted Mar 09, 2009 · 22:02 UTC#294
OK, so I've installed Toxits' Simulation mod, but when I plan a route and then press Flyover the only button that displays is the green one (which takes me to the Route menu screen, is this what it should do?) and no pause/fast/slow are displayed. Any help folks?
Posted Mar 09, 2009 · 22:09 UTC#295
do you have all those buttons (pause, resume, play etc)?
Posted Mar 09, 2009 · 23:04 UTC#296
Yeah, got the buttons but nothing is coming up. I've only loaded Toxits' mods, do I need anything else...........?
Posted Mar 09, 2009 · 23:41 UTC#297
Take a look at his advmenu800_480 file. There's some flyover and simulate stuff in there.
Posted Mar 09, 2009 · 23:47 UTC#298
and more in the route800_480 file
FYI - I'm not using his scripts, just trying to help ya out.
Posted Mar 10, 2009 · 01:17 UTC#299
New UI files for speed camera usage.
Image files in COMMON: properly phased speed camera icons for the warning layer. Now, when the camera warning appears on screen, it will
show the real camera type.
speedcams_800_480.ui - changed steps for the camera speed slider to better reflect what is possible in US (thanks to N-S-E-W).
Files in COMMON\UI - work in progress on spoken camera warnings. It seems to finally speak camera types properly, but does not pick correct speed to say... Everyone is welcome to fix :)
Spoken warnings require iGO2006 speech files, i.e. from here:
http://depositfiles.com/files/iu2fmiia7
speedcams.rar
Posted Mar 10, 2009 · 07:36 UTC#300
http://4pda.ru/forum/dl/post/33246/SpeedcamVoice_En.zip
Hey Boris, Any chance you have this zip file? I click on the link and it takes you to a russian site that you seem to need to register on. I tried google translate and still couldn't work it out!
Matt
Page 12 of 15
