Just for your information,
the Windows CE emulator described in this post can run under LINUX, (if you are a linux user, like myself, but still wanna mod you AVIC)
Just follow the instructions posted in this website. download the indicated files.
Note to install msi files on linux you need to use the following command on the terminal:
wine msiexec /i xyz.msi
this will run the installation of the msi files downloaded.
Copy the file :~/.wine/drive_c/Program Files/Windows Mobile 6 SDK/PocketPC/DeviceemulationV610/0409/PPC_USA.BIN to the wine folder where you installed the emulator so it is easy to run the startup script.
then change the bat file to the following script
> wine DeviceEmulator.exe PPC_USA.BIN /memsize 256 /tooltips ON /video 800x480x16 /vmname "Pioneer Emulator"
You all set.. now you can run the windows CE emulator under Wine on LINUX!!!! without having to switch to windows in order to work on your avic mods... wowww... works beautiful, well the emulator, i still trying to get the Avic soft to run on the emulator....
