Maverickster's Mods - UPDATED 12/9/08
By Maverickster · Dec 03, 2008in Hacks/Mods💬 430 posts👁️ 106,956 views
Page 15 of 18
Posted Mar 03, 2009 · 02:34 UTC#351
I assume this works fine on the F90BT also?
Posted Mar 03, 2009 · 04:04 UTC#352
Thanks guys - I got it working without a problem. Except --- The speedo/altimeter MOD. Maverick says we have to delete all occurrences of map.ZOOMVIEW..... Any of you know exactly where they are and how many? Also, he provides the spot for the code, but I don't see what we replace. One more Q - I've seen MOD's for 3D buildings. I'm in Detroit area, but usually in the burbs and not downtown. I've never seen the 3D buildings on the unit before - are they only in the main city areas? I'm not going to bother with the MOD if it won't really apply to me.
Thanks again!
Posted Mar 03, 2009 · 09:18 UTC#353
Thanks to Maverickster!!!!
I just installed my new F700BT. While I was waiting for it to arrive I found this great forum. After using the unit 1 day, I knew I wanted Maverickster's hacks. I applied the Parking Brake Speed hack to Maverickster's Data.zip file & now my Nav Unit is much easier to use & I love disabling the annoying voice prompts when I don't need them.
Thanks so much,
Paul
Posted Mar 03, 2009 · 10:05 UTC#354
Thanks so much,
Paul
I've heard rumors he is working on such a button for our wives
(mine can give a lot of annoying instructions too)
Posted Mar 03, 2009 · 10:21 UTC#355
LOL what about a kill-switch.................... :lol:
Posted Mar 03, 2009 · 10:39 UTC#356
Or instead of bypassing the parking-brake hack, ENGAGING mute when I'm driving.
Posted Mar 06, 2009 · 00:54 UTC#357
Too many posts to read, but has anyone suggested making the clock easier to read when you're on any of the audio screens? I.e. Ipod, FM, etc...
Shawn
Posted Mar 06, 2009 · 01:51 UTC#358
Yeah, but that's how you learn, Shawn....................
:wink:
Posted Mar 06, 2009 · 02:00 UTC#359
Im sitting in my truck after spending two hours reading on how to copy my data.zip I got from this thread! I think my fiancee will kill me if I spend another 2 hours... :oops:
Thanks though, I'll keep looking
Posted Mar 06, 2009 · 03:56 UTC#360
Shawn
I am not sure if you can edit non-navigation screens. It is not part of the code you can change via the ui files.
Ceger
Posted Mar 08, 2009 · 07:44 UTC#361
Yesterday I replaced my original data.zip with the one from Maverick.
I started it up again and saw all the new buttons and they all seem to work fine.
30 minutes later I tried to start it up again, but now unit seems to turn "dead" after 20/30 minutes or so.
It starts up and I see the splash screen but then the screen turns dark and the unit stops responding.
It is not even possible to boot it in testmode to put the original data.zip file back.
It is a european one with 1.9 firmware.
Anyone has got an idea or solution?
Posted Mar 08, 2009 · 10:29 UTC#362
I suggest you download Firmware Update v2.0 and see if you can install that. If successful, delete your copy of Mavs' DATA.zip, download again, and try reinstalling. I'm not sure, but I think his mods were done with v2.0 update.
Posted Mar 08, 2009 · 10:58 UTC#363
careful with putting 2.0 on a EUR model!!!
they are different hardware-wise
(curious if it'll work though ;) )
Posted Mar 08, 2009 · 11:05 UTC#364
I installed EURO v2.0 on my Euro 500 no prob. Obviously one needs to install correct Region (EU or US) update but also the correct one for that particular model. The update for the 500 is different to the update for the 700/900 models
Posted Mar 08, 2009 · 14:04 UTC#365
2.0 is the US version and 1.9 is the same version for European models.
I thought, whatever happened or went wrong, you could always put your original files back via testmode or boot via SD card? In my case that is impossible and the unit seems useless!
Posted Mar 08, 2009 · 14:09 UTC#366
EURO v2.0 has never existed for the 900. First you had EURO v1.9 (US v2.0) and the latest one is EURO v.2.001.
Posted Mar 08, 2009 · 14:14 UTC#367
Yep, thats the one I'm running.
As I said I have a Euro 500 and the firmware is v2.001000...... so I would still say that's v2.0, ands NOT 1.9 - wouldn't you? :wink:
Posted Mar 12, 2009 · 05:23 UTC#368
i wanna add 3d buildings to this how can i do this put keep this data.zip file is that possible or what..
Posted Mar 12, 2009 · 16:48 UTC#369
What program do you use to edit the files and put the modified codes in with? Do you have to extract any of them?
Posted Mar 12, 2009 · 18:43 UTC#370
notepad, paint, CS4,7zip
Posted Mar 12, 2009 · 20:48 UTC#371
I used Notepad (for the editing) and PS Elements (for the couple of custom buttons I made). No specialized software required.
--Mav
Posted Mar 19, 2009 · 17:08 UTC#372
Hey, Mav,
Just a confirmation. The clickable Zip on the first page IS the latest and greatest Data Zip mods even when using Ipods?? I did'nt find the code for the voice mute though added to the latest version. Should I do this one separately? (***CORRECTION*** I found the voice mute code...:))
Thanx again for all of your hard work and effort!!! :D:D:D
Posted Mar 22, 2009 · 15:14 UTC#373
Hey Mav,
Just found this site few days ago, I've been reading through threads like a maniac in the past nights: you rock man!!!
thanks for sharing all your work with us!
I have a question, though, I'm Italian and I'm using a setting in KM/h and meters for altitude, will your mod increase the speed number size and add the altitude even if I have selected metric system? and, basically I'm going to see the speed in kilometers and get the altitude in meters or exactly as you posted in your screen shots in miles and feet?
thanks again,
Posted Mar 23, 2009 · 13:27 UTC#374
Hey, Mav,
It's the current version used by me. I don't use an iPod, so it doesn't incorporate any mods to accommodate the iPod cover art (as others have done elsewhere in this thread and on this forum).
--Mav
Posted Mar 23, 2009 · 13:29 UTC#375
It should work that way, yes.
Page 15 of 18
