US Speed and Elevation Road Signs...
[uPDATED 3/4/09 to assist with removing the Route Info and Map Zoom displays so they dont overlap with the road signs. Note that step #3, will turn off the route info display when no route is selected however when a route IS selected, the route info display will be fixed to show distance to destination, time to destination and current speed. Still looking for code to allow you to set these variables through the AVIC interface]
1) Copy the (3) bitmap files in the ZIP file to \ui_pioneer\common. These are the various road sign templates. You may want to make a backup of speed.bmp. I'm not sure if this stock speed.bmp is even used on the F series.
2) Copy the DSDIGI.TTF file to \My Flash Disk\APL2\iGo on your F series. Note: This is an alternate font used for the digital display on the "your speed" sign. You can stick with the stock fonts but if you do, you will need to change it back to tahoma or tahomabd in navigatemap_800_480.ui.
3) If you are using the stock navigatemap_800_480, you will notice that the ROUTE INFO display will show when not navigating and this will be a waste of precious screen realestate. If you are already using a script like Mavrickster's, this has already been removed for you. If not, you will probably want to turn off this off. This also will allow the various road signs to not overlap the ROUTE INFO display. If you are already using Mavricksters mods, you can skip to step 4.
To turn off the ROUTE INFO display when not navigating, replace all the code in the section as with this code:
; start hidden
hide
;end hidden
4) To also remove the Map Scale, open up DATA\ui_pioneer\common\ui\navigatemap.ui and seach and replace all references of
map.ZOOMCONTROL_SHOW 1
with
map.ZOOMCONTROL_SHOW 0
Do the same thing for DATA\ui_pioneer\common\ui\browsemap.ui
4) To display the posted speed limit, place the following code in navigatemap_800_480.ui in the same layer as noted in step 3 (). Insert this code at the bottom, just before the statement:
;Display Posted Speed Limit
5) To display your elevation, add the following code in the same layer (again, just before the statement:
;Display Elevation
6) To display your clocked speed, add the following code in the same layer (again, just before the statement:
;Display Clocked Speed
Many thanks to those who have gone before me to show the way....
.jpg)
