Sorry if I didnt post correct info. I started with an early version of Mav's mods. I could post my full DATA.ZIP but then you wouldnt have all of Mav's mods.
Here is the entire layer which removes the ROUTE INFO display when not navigating and also adds the Speed Limit, Elevation and Your Speed displays.
If this works, I will fix the first post and remove the incorrect data posted later on.
To remove the Map Scale, open up and search through the code of every file in the DATA/ui_pioneer/common/ui folder in the DATA.zip file. The following code should be changed as follows EVERYWHERE it appears. From the best I can tell, this is in navigatemap.ui [and] browsemap.ui:
Replace this:
Code:
map.ZOOMCONTROL_SHOW 1
with this
Code:
map.ZOOMCONTROL_SHOW 0
no apologies you've been a huge help in my whole programming thing here just to clarify for the replacing section:
Code:
with this
Code:
there's only 2 files that contain the "map.ZOOMCONTROL_SHOW 1"under the ui_pioneer->common->ui
they are:
-browsemap (1 code to replace)
-navigatemap (2 codes to replace)
I just went through them all to save you some time for you guys i also just copied over you new coding section to remove the map source i'm going to go check it now and i'll update the info... thanks again
