HOW TO: US Speed & Elevation Road Signs
By mgreinke · Jan 04, 2009in Hacks/Mods💬 94 posts👁️ 24,799 views
Page 2 of 4
Posted Feb 27, 2009 · 00:58 UTC#26
Jeez, you're a genius! :)
I'll go back thro' thread and get a better understanding..........
Posted Feb 27, 2009 · 01:04 UTC#27
Krueger, can you list what you did on your install, start to finish
Posted Feb 27, 2009 · 01:06 UTC#28
not sure what that means I don't think anywhere in this thread is it described where the new pieces are added and then taking the old pieces out?
is there any way to disabled the "Disaplyed info" that is built into the unit itself?
Phil
Posted Feb 27, 2009 · 01:09 UTC#29
copied the data.zip file from my avid to my flash drive in case I effed it up somehow
added the code that was posted at the beginning of this thread to the bottom of the navigatemap_800_480.ui file that I found in the data.zip file in the ui_pioneer\800_480\ui folder
copied the modified data.zip file to my avic
restarted the avic
everything shows up. but it's double for some reason. i can post a pic if it would make more sense?
Posted Feb 27, 2009 · 01:28 UTC#30
Yup, post a pic. When I called you a genius, I meant that I didn't think it was that easy to end up with icon on icon LOL!
Posted Feb 27, 2009 · 01:51 UTC#31
here are the pictures.
had to take them side ways it's dark outside and the glare from the flash was horrible. these were actually taken with a 10 MP camera. no clue why they are so blurry ;(
you can totally see the white behind though where those are the new signs. they look bad ass but QQ they are overlapping :(
Posted Feb 27, 2009 · 02:24 UTC#32
I can't make anything out, your pics are awful: try taking some more in daylight, in the meantime I'll think about what may be causing your prob
Posted Feb 27, 2009 · 02:36 UTC#33
take a look at his original picture taht he posted. now imagine the factory stuff is disaplyed on top of that in the lower left hand side. that's what I have going on.
I'd totally be down with taking pictures tomorrow though it's kinda windy and rainy here atm :(
Thanks for all your help
phil
Posted Feb 27, 2009 · 02:56 UTC#34
Sounds like it's being called upon more then once. Check the navigate 800 file for duplicate instances of the same action. If you do indeed find multiples, comment out the extras then re-start the nav.
Posted Feb 27, 2009 · 03:27 UTC#35
I added the code at the very bottom. the modded code is only called on once cause the speed limit only shows up once. but the facory settings are still showing
Posted Feb 27, 2009 · 07:21 UTC#36
I think you need to set the visiblemodel on the factory stuff to not show when there is no route active so that only the speed limit is displayed.
I dont have the code in front of me but if you look in Mavericksters (I think that's his name!) thread you can see the code you need to change, look at the bit where he adds the speed limit and elevation to the bottom left.
Posted Feb 27, 2009 · 08:46 UTC#37
Give these a try. I didnt try them myself. Since the circle would need to have transparancy, hopefully I have that correct. I'm sure you will also need to adjust the X/Y coordinates to make the numbers fit.
Good luck!
superb!
Posted Feb 27, 2009 · 15:57 UTC#38
I'll try that tonight when I get home from work thanks a bunch.
Phil
Posted Feb 28, 2009 · 18:01 UTC#39
[updated 3/4/09]
I've updated the first post to address this issue.
Sorry about the mix-up.
Posted Mar 02, 2009 · 04:47 UTC#40
would you mind posting a complete Data.zip file with just that mod I tried to plug in your code into maverickster's completed filed and I think something got messed up cause now my unit is stuck on starting up and never completes that process?
Phil
Posted Mar 02, 2009 · 18:41 UTC#41
Ditto on posting the complete data zip file. I too have Mavs mods and am very happy with them and would like to add these signs to it. I am comfortable adding the data zip but not editing it my self, I know my limitations!!
Thanks in advance and nice work!!
Posted Mar 02, 2009 · 18:51 UTC#42
Hi Folks,
You just made me realize I did forget to mention that you need to remove the Route Info display when not navigating. Yes, I started with Mavericksters mod which already took care of this.
Find the layer called in the STOCK navigatemap_800_400.ui and replace it with this:
If you want to keep the Route Info display, then you'll need to move the X/Y coordinates of the speed limit and/or elevation graphics to an open portion of the screen from the coordinates I used.
Sorry about that.
Let me know if that helps.
this only works half for me.
it takes away the small icons, the background and some info, but it leaves 0000 on the first and second line.
also the scale keeps on screen. how do I lose that?
Posted Mar 02, 2009 · 22:47 UTC#43
Hi Folks,
Sorry about that.
The speed limit sign shows up and it seems to be trakcing the speed limit. Also Elevation shows up. NICE !!!
But the numbers from the factory stuff is still there?
How do I get rid of that ??
Phil
Posted Mar 03, 2009 · 02:31 UTC#44
I will third the request for a data.zip with this working with Maverickster's Mod. Me + coding/programming = disaster of epic proportions
Posted Mar 03, 2009 · 04:53 UTC#45
bump for an answer i've been working on this for a couple hours now...
i've done all the steps correctly this is the first mod i've running into problems with..
the speed and elevation mod works great but just like everyone else here i'm getting the old map route info in behind... i tried copying what you wrote that didn't work... I tried going to mavericks site and copying that over and placing you speed code at the end of that layer in replace of his speed codes and that didn't somebody help us out here...
Posted Mar 03, 2009 · 05:48 UTC#46
About 5 posts up from this one he answers the double display situation, read the thread. He used a previous mod (Mavs) which had those already disabled, then he gives instructions for turning them off. Seriously, 5 or 6 posts above this one is the answer.
Posted Mar 03, 2009 · 09:15 UTC#47
which only works half... :wink:
Posted Mar 03, 2009 · 23:53 UTC#48
and doesn't clear them all... i think a mod should edit the first post and clear this up that way people don't have to go thru 4 pages and still find a wrong answer...
this is a really cool mod and i'm sure people are going to way a good DIY for it and like most of us on here we not computer programers! bump for the code that clears them all!
Posted Mar 04, 2009 · 03:07 UTC#49
Yea paQ pointed that out already, I just meant that the reason was noted. sorry for the confusion.
Posted Mar 04, 2009 · 03:41 UTC#50
Sorry if I didnt post correct info. I started with an early version of Mav's mods. I could post my full DATA.ZIP but then you wouldnt have all of Mav's mods.
Here is the entire layer which removes the ROUTE INFO display when not navigating and also adds the Speed Limit, Elevation and Your Speed displays.
If this works, I will fix the first post and remove the incorrect data posted later on.
; start hidden
hide
;end hidden
;Speed limit
;Elevation
;Your Speed
To remove the Map Scale, open up and search through the code of every file in the DATA/ui_pioneer/common/ui folder in the DATA.zip file. The following code should be changed as follows EVERYWHERE it appears. From the best I can tell, this is in navigatemap.ui [and] browsemap.ui:
Replace this:
Code:
map.ZOOMCONTROL_SHOW 1
with this
Code:
map.ZOOMCONTROL_SHOW 0
Page 2 of 4
