I’ve run into a challenge getting this to work. The main highways around me have a posted speed limit that shows up on the unit, but it shows up naturally as the speed limit number with a white circle surrounded by a red line. I’d like this to show properly if at all possible on a normal speed limit sign, similar to what is at the beginning of this post.
See pictures. The first picture shows the lower left side of the screen with “your speed†and “altitude†with NO speed limit sign, this is expected for streets without a posted speed limit that iGo reads. The second picture shows the addition of the actual speed limit but isn’t posting it within the “speed.bmp†file.
Any help you can provide would be appreciated. How do I get the speed.bmp image to show “behind†the posted speed limit number?
EDIT: Pictures posted in reverse order.
search for speed.bmp in your navigate_800_480.ui and play with the x and y values,
