New Unit Theme by GUGA - Version 2.0
By ggarcez · Feb 16, 2009in Hacks/Mods💬 186 posts👁️ 37,899 views
Page 2 of 8
Posted Feb 24, 2009 · 15:43 UTC#26
You need to download the zip file decompress it and then rename the image_generic.res to image.res
GUGA
Posted Feb 25, 2009 · 06:40 UTC#27
Created two new main menu navigation icons....
GUGA
Hi,
Here is my contribution to the collection of the navigation icons . . .
Thanks GUGA for "refreshing" the image.res file !
BobD
Posted Feb 27, 2009 · 03:30 UTC#28
GUGA
Hi,
BobD
Bob,
When I do my reflection I make it end in black...tak e a look at my icons....and when you raise the bright it's better if you do it in the entire image, this way the bright reflection is increased too....
Nice work
GUGA
Posted Feb 27, 2009 · 06:08 UTC#29
Bob,
Nice work
GUGA
GUGA,
You are right. Icon looks better when dissolves into black background.
As per "brightening" of the icon I do not like to "bright" entire icon - black will become gray and it will be shown as a rectangular button . .
Any way, I will make some changes if I get some time to play more with my AVIC GUI.
Thanks again for making AVIC better!
BobD
Posted Feb 27, 2009 · 06:16 UTC#30
BobD,
I only increase the bright in all the images, not in the black background, this way, when you click the icon, the not only the icon but the reflection shines too as would happen in the "real world" lol
GUGA
Posted Mar 01, 2009 · 15:20 UTC#31
I found unwanted lines in some Guga generic icons and removed it, here you have the new icons and my porsche boxster destination icons:
DELAROSA13 ICONS.zip
Posted Mar 02, 2009 · 10:58 UTC#32
GUGA
could u do one of these with a gray mkv vw gti. that would be great.
Posted Mar 06, 2009 · 17:42 UTC#33
GUGA
Vwboy,
I don't have time to create all the icon that a lot of people have benn asking, you can use the images in the post to create you own icons.
Any other change, not specific icons, i'll be pleased o do
GUGA
Posted Mar 08, 2009 · 04:23 UTC#34
GUGA
hello to all
i am new in forum and first tahank you for all this great works.i tried what you say but nothing happened.there is no change.one of my trying the home icons became to disappears.i can't beleive how i can't do this.it's looks ver easy.copy-past....but i can't.
i request that could you description this process step by step.
i downloaded the zip file.
decompress the file with 7zip (also winrar)
rename to image.res(image,image.red:-) ,image_generic.res i tried all of)
and copy to my flash disk /apl
and reboot.
1
Posted Mar 08, 2009 · 17:35 UTC#35
don't decompress the zip... take the "image.res" out of the zip you downloaded
decompress that with 7zip as a folder which should just be called "image"
edit your images
right click the folder and go to 7zip > add to archive
save as a 7zip file but change the ".7z" to ".res"
load that on your system and you're golden
Posted Mar 08, 2009 · 18:57 UTC#36
edit your images
thanks a lot.i will try .i'm sure will work.
thans again
Posted Mar 08, 2009 · 19:46 UTC#37
The images look great! How do you install them?
Posted Mar 09, 2009 · 19:10 UTC#38
Take a look at the first post...
GUGA
Posted Mar 09, 2009 · 19:58 UTC#39
GUGA
I have read the first post and downloaded the file. How do I copy it to the APL directory?
Posted Mar 09, 2009 · 20:06 UTC#40
GUGA
You need to go into testmode to do this. Search the forum for testmode and you'll find all the info you need.
GUGA
Posted Mar 09, 2009 · 20:41 UTC#41
GUGA
I have searched the forum for "testmode" and unfortunately, the correct results were not returned. Is there any way you could maybe link me to the correct threat explaining how to run testmode?
Posted Mar 09, 2009 · 20:53 UTC#42
GUGA
The very first, very stickied thread would be a good place to look...
Posted Mar 20, 2009 · 18:58 UTC#43
I'm working on some new icons. As soon as I get them ready I'll post it for download.
GUGA
Posted Mar 21, 2009 · 18:25 UTC#44
Can someone please help me on what im doing wrong on my theme i have gone through all the threads that i can find on this but i must be missing something.So this is what i got i copyed my Image res from my unit unziped it with 7z changed the pictures the ones listed Normal and Push Kept the same file name rezip with 7z image.7z changed the name to Image.res replace it with the one on my unit and it boots up just fine but no imags in my top menu and the lines are missing that seperate the buttons for like setting/phone and my pictures in my AV and Contacts are missing along with back arrow button pic. but my destination pictures are there so a little confused i have replaced with my backup image.res and everything is fine i have can back messed with the pictures gone through the threads some more tryed again and again still same results.
So please can some one help me out maybe look at my image res and see if im missing something i follow direction very well and i have done all the reading before i even thought of asking for help.
It cant be that hard Right
Josh
Posted Mar 23, 2009 · 01:06 UTC#45
I'm trying to change my AV2 button. I made all the edits, changed the file to a .res file and loaded it. Everthing works but my AV2 button does not show. I included my Image.res file. Any suggestions? Thanks for the help.
Posted Mar 24, 2009 · 18:24 UTC#46
GUGA
What kind or new icons are u making? I'm patiently waiting for your update! :lol: I've been rocking your theme and think it is the best by far!
Posted Mar 24, 2009 · 18:31 UTC#47
Bryvale,
You need to save the file as 16bit Hicolor BMP (windows format) not 24bit True Color.....Try saving this way, should work.
GUGA
Posted Mar 24, 2009 · 18:34 UTC#48
GUGA
Eurotuner,
i've been really busy at work, that's why the new version of the theme isn't ready yet. I'll probably change almost every icon on the system, and some of the icons that I already changed.
If anyone has an ideia for any icon let me know.
GUGA
Posted Mar 25, 2009 · 23:25 UTC#50
Bryvale,
GUGA
GUGA,
I changed the Image to windows format but I am still having the same issue. Any other suggestions? I appreciate your help!!
Page 2 of 8
