New Unit Theme by GUGA - Version 2.0
By ggarcez · Feb 16, 2009in Hacks/Mods💬 186 posts👁️ 37,899 views
Page 5 of 8
Posted Apr 26, 2009 · 16:32 UTC#101
ahh i didnt extract the files fully so i could view them! thanks tapas!!
it works!! haha thank you all!!!!
Posted Apr 26, 2009 · 19:58 UTC#102
hi ritu_o0o,
regards
tapas
Posted Apr 27, 2009 · 18:32 UTC#103
thanks for the theme, man. greatly appreciated!
Posted Apr 27, 2009 · 20:35 UTC#104
hey i downloaded the theme and my msn stop working anyone know why?
Posted Apr 27, 2009 · 20:40 UTC#105
so what have you really downloaded? you posted on CMH's thread that you downloaded something but you didn't specify it, best way to go is to revert back to your backup and then try adding 1 mod at a time and then check if your MSN still works,
Posted Apr 27, 2009 · 21:34 UTC#106
i posted that by mistake, i downloaded gugas theme, i changed the main menu icons, i added the speed cams, i added the poi images, the bluetooth phonebook mod i did them all seperate and it worked fine then i changed the main menu icons and it stopped working i think i might have deleted something by mistake..is that possible or is there nothing in the screen that you can delete that effects msn
Posted Apr 27, 2009 · 21:36 UTC#107
try doing a reset,
Posted Apr 27, 2009 · 21:39 UTC#108
kk thnx man
Posted Apr 28, 2009 · 15:17 UTC#109
try doing a reset,
Same thing i told him in the other thread. Its a bug that happens sometimes after coming out of test mode, doing a reset fixes it for some people other can just go back intotestmode and then come back out and it fixes it.
Posted Apr 28, 2009 · 17:45 UTC#110
Can somebody help create a custom "destination" icon for the main menu screen with a GT Mustang theme? Here's some sample images for ideas, but I'm open to your creativity.
When the updated image is created, what should I name it as so it updates the main menu?
Thanks in advance!
Posted Apr 28, 2009 · 17:53 UTC#111
hi ritu_o0o,
regards
tapas
THANKS A LOT TAPAS :D
Posted Apr 29, 2009 · 17:30 UTC#112
Thanks in advance!
Images are already named correctly. Hope ya like em. 8)
Posted Apr 29, 2009 · 17:37 UTC#113
or this
Posted Apr 29, 2009 · 17:45 UTC#114
cool, how about one from this..
Same just with that car? Or try something different? Either way, I'll try to get to it later. 8)
Posted Apr 29, 2009 · 18:29 UTC#115
Thanks in advance!
Thank you Lonestar...
Just checking, I renamed these to end with .bmp...then saved them to the ui...and 800_400 folder. I added these two files and it did not replace anything. I also added these two images to the common folder. Does that sound right?
Posted Apr 29, 2009 · 18:38 UTC#116
Hmm... well they were named correctly. Didnt know photobucket renamed images. Anyhoo, just send me your image.res file and i'll do it for ya. 8)
Posted Apr 29, 2009 · 19:09 UTC#117
The image.res file is too large to post, but its Guga's version posted on page 1 of this thread.
Posted Apr 29, 2009 · 19:38 UTC#118
Nice job !
by the way, you can put the horse in the bmp: 746_32K_MN-001_24b.bmp
than it is in the button between Phone and Settings
example :
Posted Apr 29, 2009 · 19:59 UTC#119
Nice, never knew that. Will have to change mine. :mrgreen:
sizzlin, here ya go. Should work. Just copy/paste over existing one. Be sure to make a back up first though.
http://rapidshare.com/files/227258626/Image.res.html
Posted Apr 29, 2009 · 21:05 UTC#120
Thanks Lonestar...I'm lovin the new look:
Do you have a stang? If so...have u done any other mods?
Posted Apr 29, 2009 · 22:24 UTC#121
I drive an F-150. 8)
Posted Apr 30, 2009 · 01:17 UTC#122
Ok, sorry, I'm a complete newb at this so I need some pretty specific instructions about making a custom Icon. I dont know how to edit the pictures so that i can put my own car on there. Will someone please explain this to me? Thank You!
-Brian
Posted Apr 30, 2009 · 16:30 UTC#123
How do you do this? Do you just rename a picture to this or do you have to edit the picture to fit and all? I am trying to get a Virginia Tech logo in that spot. Thanks for the help!
Posted Apr 30, 2009 · 16:57 UTC#124
Give this a try. 8) The BMP is in the zip.
Posted Apr 30, 2009 · 17:20 UTC#125
whateve ryou want to do,the first 2 picts are on from the web of the car i own, the 3rd one is a pict i took myself.
Page 5 of 8
