IDT v4.2 on p46, last for 2.0
By ill.die.trying · Mar 12, 2009in Hacks/Mods💬 801 posts👁️ 102,601 views
Page 18 of 33
Posted Apr 28, 2009 · 20:58 UTC#426
I still cannot get the speedcam box to cancel if it displayed on the screen. The code reads:
yet it does not function.
And in the common file it pulls up this code:
So does this mean it is only going to cancel the section cams? Because in the line below that it has an SC cancel for the section cams:
Thanx<
Bud
what you can do is create a script that hides it or moves it out of the screen, and then give it a shot, you may want to create some test cameras, the only problem that could occur is that lets say you hide the camera warning box, it may not appear on all camera locations unless you find out a way to run another script to show it, either way the best way to go is create a script and see if it only gets hidden on that intance
Posted Apr 28, 2009 · 21:03 UTC#427
Right now, #333333 is black and #FFFFFF is white. Easy!
Good luck,
Bud
just a clarification #000000 is black
Posted Apr 28, 2009 · 21:04 UTC#428
NP ;)
I made the simple semi colon and color change, but now my nav gets stuck in "Startup in progress..." and then it restarts. I am using 7zip and I used a blue color for the time color.
What do you think the issue could be? This only happens with IDT mods...
try reverting back, and then try it again, could you post your nav_800_480.ui here so i could take a look at it,
Posted Apr 28, 2009 · 21:11 UTC#429
NP ;)
Here it is. I am just trying to delete the date on the nav screen and possibly change the time to a color that isnt gray b/c it blends too much with the Riks night theme.
Posted Apr 28, 2009 · 21:25 UTC#430
checked it and didn't find anything wrong with it, try redownloading the v2.9? try that and see what happens, i think there's a corrupt file somewhere and that's what's causing the reboot,
Posted Apr 28, 2009 · 21:51 UTC#431
Good luck,
Bud
oops :(
Posted Apr 28, 2009 · 21:52 UTC#432
ok, in what file is the dimming icon script hiding, thinking about adding it to my mod, but can't find it to see what i need to add to mine.. lol
Posted Apr 28, 2009 · 21:54 UTC#433
The clean redownloading of v2.9 is working fine. I'll just leave the tweaking to the pros from now on. :) Thanks IDT for your help.
FYI, leetlauncher 2.0 is very good for making these kind of updates.
Posted Apr 28, 2009 · 21:56 UTC#434
in navigatemap.ui
you also have to declare the buttons in your navigatemap_800_480.ui that you want to dim
Posted Apr 28, 2009 · 21:57 UTC#435
I have it in mine now as I added all of the buttons.
It is in the common/navmap.ui:
To declare the buttons you then have to go into the navmap_800_480.ui and change the button you want to dim. For instance, change this:
to this:
It's easy.
..Bud
Posted Apr 29, 2009 · 15:47 UTC#436
cool, I'll give it a try when i have time in the next few days to work on it. this was very helpful!! THX!!!
Posted May 01, 2009 · 00:33 UTC#437
ok now i'm trying to add the date to mine.... i got the date stuff done in the navmap_800_480.ui file, but i don't know what else i need to add.
Posted May 01, 2009 · 00:49 UTC#438
there's nothing else you need,
Posted May 01, 2009 · 00:52 UTC#439
ok thx,
Posted May 01, 2009 · 00:53 UTC#440
ok thx,
no prob
Posted May 01, 2009 · 18:52 UTC#441
got the date put in (i think my dyslexia messed me up the other day while trying to put it in), desided not to try to tackle the fading buttons thing for now, might try sometime in the future.
Posted May 01, 2009 · 19:17 UTC#442
UPDATE:
what's added,
-speedcam warning box made clickable to hide the warning box and mute speedcam alerts,
-added a button to show speedcam warning box if ever it's hidden (note; once clicked speedcam setting would be
set to "only when approaching)
-optional analog speedometer with a digital unit on the bottom, (to revert back to previous display you have to comment out the following scripts in navigate _800_480.ui
;Current clocked speed
and remove the ; from the following codes
instructions:
1) first off this is not an auto installer, this is leetlauncher v2 that i use to install my mods
2)extract files and transfer all files to a freshly formatted SD card
3)this already has testmode file so no need to add anything else
4)insert SD to unit,
5)boot up unit
6)click testmode
7)copy DATA.ZIP, SYS.TXT, and DS-DIGI file to igo folder
8 )optional, copy EZRIDER to igo folder and copy license to content folder,
9)once done click down on control knob and then click the pioneer logo,
10) wait for it to boot and your done
PLEASE BACKUP YOUR FILES
link has been disabled due to some bugs
Posted May 02, 2009 · 19:25 UTC#443
hey here, i figured i would give this a shot and i tried it without using leetlauncher because i dont use that program. it seems like it works but when i first boot it up and go to map, an error comes up. heres a screenshot. maybe you can shed some light on this?
http://i11.photobucket.com/albums/a158/venom0713/S7300611.jpg
Posted May 02, 2009 · 20:54 UTC#444
ill take a look at it
Posted May 02, 2009 · 21:17 UTC#445
could you try downloading the file again and load it to your avic, ad also could you explain to me how that error mesage appears (did hit any buttons before it appeared, ets)
Posted May 03, 2009 · 01:39 UTC#446
ok, ill try it again tomorrow. but it does it only once and thats when the avic first starts up. it doesnt do it until i hit the map button, and then if i tap the little ok button, it seems to work ok.. but i dont know what that error is for or what it means
Posted May 03, 2009 · 07:39 UTC#447
i just tried the one on the download site and i'm not having any problems, try downloading it again and loading itto your unit and see how it goes
Posted May 03, 2009 · 16:49 UTC#448
Hi idt i got the same error,download it twice but the error still there
Posted May 03, 2009 · 17:17 UTC#449
that is weird, i'll ave to take a closer look at it,
Posted May 03, 2009 · 19:36 UTC#450
yeah man, i tried deleting my flash disk and rewriting it and i did everything over again and i still get that error : ( if it matters, i do change the brake speed from 16 to 256 because i use the software bypass..
Page 18 of 33
