IDT v4.2 on p46, last for 2.0
By ill.die.trying · Mar 12, 2009in Hacks/Mods💬 801 posts👁️ 102,601 views
Page 16 of 33
Posted Apr 22, 2009 · 04:20 UTC#377
I am having big problems. I extracted the files from the NOMSN folder into my SD card, let it load fully then turned car off, then turned back up, now it shows me that system is loading but goes no further than this. My navigation no longer works and having problems where the unit will reboot after a few minutes. what can I do to fix this. Is there anyone that can give me a copy of there stock flash drive?
Thank you.
you didn't back up your files?
Posted Apr 22, 2009 · 04:28 UTC#378
If someone doesn't follow a readme file and backup their system or extract files properly, what are the odds they would be able to restore the unit even if they had all the files sent to them?
Posted Apr 22, 2009 · 11:54 UTC#379
eomsux wrote:I am having big problems. I extracted the files from the NOMSN folder into my SD card, let it load fully then turned car off, then turned back up, now it shows me that system is loading but goes no further than this. My navigation no longer works and having problems where the unit will reboot after a few minutes. what can I do to fix this. Is there anyone that can give me a copy of there stock flash drive?
Thank you.
I did back up my files. I backed up my DATA.Zip, Image.res, Sys.txt, and any other file that I replaced with another. I replaced all of these files, but still having the same problem. I didnt realize the mod i downloaded was a self extractor. I ususally exchange the files manually so If I needed to I can restore them. Has anyone else had a simular problem, where the unit displays "system loading" and message never goes away navigation wont go past the warning screen, and then unit will reboot after a few minutes. all radio functions still work, but cant go to settings or phone.
Posted Apr 22, 2009 · 16:00 UTC#380
Thank you.
I've had the same problem. I tried installing this update with 2 different freshly formatted SD cards, but no luck. So I just reverted back to my previous mod. Although I tried just replacing the zip file so that may be the problem. For now, I just used CMH's mod until I can successfully install IDT's.
Posted Apr 22, 2009 · 16:48 UTC#381
Thank you.
The only thing I havent done was replace the EZRider.exe file, I will try that when I get home if not then I might have to go your route and go back to the previous mod that I was using.
Posted Apr 22, 2009 · 22:46 UTC#382
Thank you.
did you guys include the fontfile?
Posted Apr 22, 2009 · 23:29 UTC#383
Yup, I did. It's the same font file included with CMH's as well. Not sure what happened...this happened to me a previous time I tried uploading one of your updates. Its weird.
Posted Apr 22, 2009 · 23:51 UTC#384
what unit do you have and is it a US or a EU model?
Posted Apr 23, 2009 · 00:13 UTC#385
IDT I have an F900 and it is a US model.
Its fairly new. I tried using your auto install AND doing it manually, but it didn't work. Basically the "start up" message constantly shows, I can browse to my iPod, then after about 5 mins, the system reboots. Haven't had this problem before.
I like your updates though...its less busy. I usually update coming from CMH's latest mod, which is similar to yours (in terms of ezrider, text files, icons, etc).
Posted Apr 23, 2009 · 01:05 UTC#386
ok, try this, http://ul.to/xoezyb, that's a special one i did for jeflac,
Posted Apr 23, 2009 · 16:49 UTC#387
Hi IDT, this one worked! What was different in the files? I like the new set up, very nice. I noticed that you removed the blue bars on the top and also the 3 display items...do you have multiple versions of this mod?
Posted Apr 23, 2009 · 17:21 UTC#388
i'll have to double check which files i added, there is only onversion of 2.7, but like i've said ill have to check what file i changed,
Posted Apr 24, 2009 · 03:14 UTC#389
IDT, did you figure out a way to increase the spoken warning volume?
Posted Apr 24, 2009 · 04:35 UTC#390
i'm still working on it, this is actually the reason i haven't released the new version,
Posted Apr 24, 2009 · 08:41 UTC#391
See if these are loud enough for ya. Just drop them into your data.zip. :-)
Posted Apr 24, 2009 · 22:31 UTC#392
cmh928, when you say drop them into data.zip, do you mean I can just open up my two folders (can't remember the names, the ones that self extracted thanks to IDT) and just replace the entire audio file?
To date I've relied on you guys to make self extracting programs for me.
Posted Apr 24, 2009 · 22:33 UTC#393
Or do you mean-
1. Copy files to my SD card
2. Boot my unit into testmode and navigate to your SD card.
3. Copy DATA.ZIP to: \My Flash Drive\APL2\iGo
Select yes when it ask you if you want to replace the files.
Thanks for the help, I'm definitely a newbie on here!
Posted Apr 24, 2009 · 22:55 UTC#394
finally,
what's new,
-changed speedcam icons
-added spoken warning test sound when volume slider is clicked,
-bigger turn restriction icon
-added screen off button on navi screen (thanks to MIKEGEDGE)
-blanks out navi screen,
-added clock when screen is blanked out
-fixed MIKEGEDGE's script to also hide warnings, turn restrictions and current speed and speed limit
-all buttons except for screen off button dims out when not in use,
-better day/night scheme button image
-added my custom speedcam warning
currently unsolved issue,
-speed limit display for CANADIANS,📎 DSC01741.JPG📎 DSC01740.JPG📎 DSC01743.JPG📎 DSC01742.JPG📎 DSC01747.JPG📎 DSC01744.JPG
instructions:
1) first off this is not an auto installer, this is leetlauncher v2 that i use to install my mods
2)extract files and transfer all files to a freshly formatted SD card
3)this already has testmode file so no need to add anything else
4)insert SD to unit,
5)boot up unit
6)click testmode
7)copy DATA.ZIP, SYS.TXT, and DS-DIGI file to igo folder
8 )optional, copy EZRIDER to igo folder and copy license to content folder,
9)once done click down on control knob and then click the pioneer logo,
10) wait for it to boot and your done
PLEASE BACKUP YOUR FILES
here's the file http://ul.to/9dtqbs
Posted Apr 24, 2009 · 23:25 UTC#395
Hey, IDT. I love the cam icons!
I am going to grab those BMP's a put them in my mod!!
Kudos, dude!!
Posted Apr 24, 2009 · 23:40 UTC#396
Kudos, dude!!
go ahead, i just grabbed those BMP's myself from an igo skin,
Posted Apr 24, 2009 · 23:54 UTC#397
I swapped them into my current data.zip that I am using from CMH928. I know they are a bigger physical size(speed_cams.bmp). You also did some major coding changes too that I noticed using the Exam.diff. For now I just wat to add the icons. Is this going to be okay?
Thanx,
Bud
Posted Apr 25, 2009 · 00:02 UTC#398
Thanx,
Bud
for the speedcams, you need to copy 746_32K_MN-619_32b from 800_480 folder and speed_cams.bmp and speedcams.spr in common folder, you might wat to edit your speedcam_800_480.ui for the proper x and y values of the speed_cams.bmp
Posted Apr 25, 2009 · 04:04 UTC#399
Also, it **seems** to me that the speedcam box is clickable now??
Also, what is the difference from your Speedcam_800_480_ui file text "" and mine which is: ?
BTW..Thanx for this update!!
Bud
Posted Apr 25, 2009 · 04:16 UTC#400
The camera icon in the alert box has been clickable. It mutes the warning.
Page 16 of 33
