If a speed limit is present in the maps on a given stretch of road, then the speedcam interface will apply that limit to the display and voice even if the camera speed itself is set to zero. If a camera does have an assigned speed, then that speed takes precedence over the map speed limit. Almost none of the US cameras are set to anything but zero MPH, yet the voice will read off the speed limit of the road I'm on as I approach them.
IDT v4.2 on p46, last for 2.0
Great mod but I think I found a bug. The address numbers feature puts 100 addresses per block.
House addresses are purely a function of the map data. If they display at all, then there is no bug other than faulty TeleAtlas/Navteq data. They are routinely 30-100 off the mark and occasionally on the wrong side.
I am trying to add a favorite’s button on the nav display but not having much luck. I know very little about the code
Hers what I have put in the navigatemap_800_480.ui.
;Favorites
I have made the favorites_onmap.bmp and entered the above. Can someone please tell me what I am doing wrong?
I am trying to add a favorite’s button on the nav display but not having much luck. I know very little about the codeHers what I have put in the navigatemap_800_480.ui.
;Favorites
try this and just change the x and y values,
;Favorites
also if you want to get the button to dim you may want to have it named like what you did with the first code and go to navigatemap.ui and search for this code
then add the name of the name of the bmp on both scripts and just copy how they were scripted
Hello
Maybe this seems dumb, but where do I find the schemes files?
Greetings
Labgate
I have a question on the map color used on your MOD. In the option it has many choses to change the map color scheme, however none seem to work for me. Am I doing something wrong, or do these not actually change the look of the map colors, etc... Thanks!
you have to download the schemes and put it inside myflashdisk/apl2/igo/content/scheme
Hello
Greetings
Labgate
here you go http://avic411.com/forum/viewtopic.php?t=18175
Okay hers where I am at I have entered the code below and the button works but it is not visible.
;Favorites
;Favorites
change your visiblemodel to gps.valid
minor updates,
-changed a couple onmap bmp's, still working on the 2d button but i think the updated one is good for now til i figure something out,
-changed the cursor to an animated 8.3 version
-8.3 style direction icons,
-also included in the download is an optional sound folder that goes inside the myflashdisk/data to sync with all the other sounds to to better sync with the rest of the sounds
instructions:
1) first off this is not an auto installer, this is leetlauncher v2 that i use to install my mods
2)extract files and transfer all files to a freshly formatted SD card
3)this already has testmode file so no need to add anything else
4)insert SD to unit,
5)boot up unit
6)click testmode
7)copy DATA.ZIP, SYS.TXT, and DS-DIGI file to igo folder
8 )optional, copy EZRIDER to igo folder and copy license to content folder,
9)optional sound files, copy files inside sound folder and paste to myflashdisk/data/sound
10)once done click down on control knob and then click the pioneer logo,
11) wait for it to boot and your done
here's the file ftp://avic:[email protected]/illdietrying
PLEASE BACKUP YOUR FILE
IDT, I just loaded your mod. The design is very nice. I noticed the day/night button disappears when in route. Did you make it that way? Also, all of the option buttons on top grey out after about 10 seconds and you have to tap the screen to bring them back. I like the new POI and speedcam icons.
Hi IDT I am trying to enable the analog speedometer but it does not work, Please can you tell me what to do to enable it. Thank you
if you'll check your navigatemap800_480.ui you'll find this
remove the ; on the last five scripts and comment out the first two,
and in navigatemap.ui you'll find this
;ATTACH_SPEEDOMETER sprSpeedRange "speedometer_range.ini" ;runif bUnitType 1 'sprSpeedometerNumbers.bmp "speedometer_num_km.bmp"' ;else_run 'sprSpeedometerNumbers.bmp "speedometer_num_mph.bmp"' ;ATTACH_SPEEDOMETER sprSpeedometerPointer "speedometer.ini"
remove the ; on all of them,
and that's it, let me know how it goes
the day/night button is designed that way, also the buttons ae alos designed tho dim out if not in use, if you don't want that feature look for this code in navigatemap.ui
and replace them with this
it is working,Thank you IDT
Ok, I figured it out. It actually is a nice feature. I think I will keep in in place. The only thing that would be nice is the itinerary shortcut list.
Hi....
i've installed your application and i'm lovin it. but i have some questions about it.
1º i would like to get a bigger poi icons while navigate
2º i got a white moldure under the date and clock like the idt speedometer but it has no information inside. can you tellme what i expect to see inside or how can i remove it.
thanks
I have the same issue..
Btw did you remove the distance settings for the speedcam warning? so that the simple spoken warning only sounds at 200 metre before the speedcam.
btw.. very nice new icons/skin and love the dutch voice.. gj
Hi....
thanks
the reason why a blank speedlimit sign appears is because the location that you guys are in have a weird speedlimit, i have the speed limit sign set to call the bmps and if the speed limit is available but is not ilisted in what i've scripted then it would show the blank bmp, give me an address or location where you guys are seeing the blank speed limit and i'll fix it,
for bigger poi icons you have to edit the poi_mapclose.bmp and make it bigger to your liking, once you've edited the bmp you also have to edit the poi_mapclose.spr and change the stripes to the new poi height,
i have removed the distance slider, still thinking if i want it back or not,
hello how are you doing i was just wondering why when i press the power button i get an error about not finding the speed cam files please help. also just extra information i dont know if know this already but i have a ppc phone with i go8 and renamed the map files to the same way the unit would have it and my unit recognized it.
what error is it givving, could you post a picture if possible, what version are you using?
Hi....
thanks
hi...
i have that white moldure under date in
street: "all streets"
City:Aveiro
Contry: Portugal
thanks
quote]2º i got a white moldure under the date and clock like the idt speedometer but it has no information inside. can you tellme what i expect to see inside or how can i remove it
Hi....
thanks
hi...
City:Aveiro
Contry: Portugal
thanks
that might be the case, i have it set to run on us and canada maps, i'll look for a portugal map then i'll try and fix it,
Hi....
thanks
hi...
City:Aveiro
Contry: Portugal
thanks
ok... thanks
now i know what the problem is, maps other than US/Canada have proper speedlimits, i'll will create a new set of scripts for users that are not on USA/Canada, could you post some location where you know what the speed limits are, this would help me verify that my theory is correct,
anyone else having this problem please post your location and an area in your location where you know a speedlimit, a highway most probably would be the best location since most of the major highways have the speed limits on the map,
thanks for pointing this one out,
IDT
