IDT v4.2 on p46, last for 2.0
By ill.die.trying · Mar 12, 2009in Hacks/Mods💬 801 posts👁️ 102,601 views
Page 2 of 33
Posted Mar 19, 2009 · 04:37 UTC#26
wow this stuff is amazing...goin to have to try and figure out how my avic-900bt works once i get it installed sometime this week.
Posted Mar 19, 2009 · 07:22 UTC#27
Hi all,
Long time lurker, first time poster. I have been trying all the different layouts and made one of my own using IDT's as a base. His is the cleanest and uses the best button placement of all the ones I tried. I did add a few buttons on the top row for: Go Home, Favorites, and MSN. I modified a few BMPs to maintain the look. I added keeper's linear compass with road list on push for quick detours,
increased a few font sizes, used Mav's speed and altitude, added house numbers back to the clock on push, and made full screen cockpit a sticky setting.
I Uploaded it as cmh928_data.zip to http://66.59.250.9:8000/ username: avic password: leave blank, for anyone who cares to try it. I also posted the speedcam voice files. They unzip to apl2\igo\audio.
Thanks for all the help guys!
Posted Mar 19, 2009 · 11:46 UTC#28
Hi all,
post some pics
Posted Mar 19, 2009 · 13:47 UTC#29
I am having one big problem please help. it seems that when i have a route active, the speed limit sign shows up when i am on a highway and blocks the stop sign delete route button. yet it still lets me delete the route when i press it. thank you
Posted Mar 19, 2009 · 14:17 UTC#30
Hi all,
post some pics with route and without route. i would like to see, i will post mine today
Posted Mar 19, 2009 · 15:10 UTC#31
search for the stopbutton_onmap.bmp on navigate_800_480.ui and play with the values, there should be two inthere that you have to cahnge the values
or
you could move speed limit sign beside the current speed sign, same thing , search for speed limit icon and play with the x&y values
Posted Mar 19, 2009 · 15:25 UTC#32
WHATwhat does this file do illditrying mod mar 12.res? i noticed it in the download manager.
Posted Mar 19, 2009 · 15:33 UTC#33
its his latest mod (data.zip) file... using his mod right now on my unit and works good.
Posted Mar 19, 2009 · 15:39 UTC#34
or
this is the only instance that i see that code;
;Delete route/ POI select
could it be that this code;
;Display Posted Speed Limit
ends differently than the other 2;
;Display Elevation
;display current clocked speed
Posted Mar 19, 2009 · 15:40 UTC#35
i dont think its a mod, it isn't a zip file it is a .res file.
Posted Mar 19, 2009 · 15:46 UTC#36
or
;Display Elevation
oh yeah, there's only one stop button, so change it's values to your liking or, this is the easiest way to go, you could copy the values of the addressselect_onmap.bmp or the poi_onmap.bmp so that it would be on the upper section along with the 3d/2d button,
Posted Mar 19, 2009 · 15:58 UTC#37
ohh you mean that... well its really a zip.. rename it to zip and you will see... i dont know why he named it to .res
Posted Mar 19, 2009 · 16:27 UTC#38
you are write. Were there any major differences with that and the march 9 file. i made so many changes that I would hate to start all over again. Please let me know.
Thank you
Posted Mar 19, 2009 · 16:34 UTC#39
Sorry i dont know how to write code, this might be a stupid question, but which values should i change and what would changing the x and y values do to the speed limit code?
Posted Mar 19, 2009 · 16:39 UTC#40
the x corresponds to horizontal position and the y is the vertical position, changing the values will change the positions, if you want to move icons/buttons around you have to know what the icon name is, look in your 800_480 and common folders and you'll find pretty much all bmp's that you are using, for example, go to your 800_480 folder and look for the poi icon, once you see the icon copy the name and search your navigate_800_480.ui for it and there you'll see the x & y and experiment on it.
Posted Mar 19, 2009 · 22:47 UTC#41
Be aware that you can change x values all you want, but several of the buttons will not move or will "ghost" if you change their y values. This is due to them being referenced in navigatemap.ui under the common folder. If you change y values in the 800_480\ui ones, be sure to update the "pos. y" values in the common\ui folder. The same goes for deleting buttons or commenting them out. Make sure to make updates to both files.
Posted Mar 20, 2009 · 15:16 UTC#42
Which one is "CMH_928DATA.ZIP" ??
Posted Mar 20, 2009 · 15:22 UTC#43
that is cmh_928's mod : link
Posted Mar 23, 2009 · 01:56 UTC#44
I have been totally unsuccessful with fixing this. any help would be appreciated. from the pictures you can see that the speed limit sign blocks the delete button when there is a speed limit. I would like to have that not show up when it is in route. please help i have attached my ui file file.
thank you
Posted Mar 23, 2009 · 02:34 UTC#45
I have a question, is the displayed info (time of day to destination, speed, distance to destination) not changable in IDT's mod? I tried changing it as I prefer time to destination and it wouldn't change.
Posted Mar 23, 2009 · 03:02 UTC#46
as of the last update all the infos in the route info box has a fixed infor, that is now fixed but still not ready to put out the new update, a couple more of cleaning up and it will be ready,
Posted Mar 23, 2009 · 03:38 UTC#47
Can't wait. Thanks for your hard work,
Posted Mar 23, 2009 · 05:20 UTC#48
i'll try my best to finish it up maybe by the end of this week, kinda hard working on it full time,
Posted Mar 23, 2009 · 08:30 UTC#49
I have updated my data.zip with the latest speedcam mods and an easier to read linear compass. It is posted to the FTP server. http://66.59.250.9:8000/ username: avic password: leave blank
Combined with the speedcam voice files saved to apl2\igo\audio, this will say speed limits in english MPH.
Thanks to IDT, BorisM and GTIMatt viewtopic.php?f=34&t=17820&start=315
Posted Mar 23, 2009 · 11:31 UTC#50
im going to try this tonite :) pretty simple install yes? just replace the stock files with the ones we download?
Page 2 of 33
