IDT v4.2 on p46, last for 2.0
By ill.die.trying · Mar 12, 2009in Hacks/Mods💬 801 posts👁️ 102,601 views
Page 29 of 33
Posted Jun 22, 2009 · 16:27 UTC#701
i'll take a look at it,
I believe it is using an external executable to hide camera files and delete content of speedcam folder.
Posted Jun 22, 2009 · 17:24 UTC#702
we'll i guess so as it is refferring to an exe file ,
Posted Jun 22, 2009 · 20:03 UTC#703
Why yes it does... Hmmm, methinks this would be an excellent template to build a potential launcher menu for external apps from w/in iGo, perhaps? :) The most interesting code from the skin:
Need to figure out how the addition of the sys.txt [utility] section worked for the .exe though:
[utility]
utilitymov=",1,\SD Card\IGO8,"
utilitydel=",2,\SD Card\iGO8,"
„\SD Card\iGO8“ - path to „iGO8“ folder .
Looks like it defines the arguments pased to utility.exe when iGo calls it. Heck, we could even use this to automate some registry imports and file copying (ala MortScript) from start.ui, which might enable the SDIO 802.11g + web browser without the need for testmode/LeetLauncher/MioUnlock sort of trickery which means we get to keep the source changing abilities of the stock Pioneer soft.
Posted Jun 22, 2009 · 21:06 UTC#704
[utility]
wow, i guess there's more to our unit then
Posted Jun 22, 2009 · 21:51 UTC#705
long time lurker, first time poster,
first off, THANK YOU VERY MUCH, for sharing your mods with us, i have used all your mods from v1 to the present and i have to say that your's is the best there is, everything is well laid out, i'm guessing you've spent hours and hours of work figuring all this out, i've seen people here in the forum adapting your mods and using it as their base because it's so functional, from CMH to coachpuff,
that said i would like to know if you have a paypal account that i could send some donations to? i know that your modding our unit using your own time and this is the only way i could show how much i appreciate your mods,
Posted Jun 22, 2009 · 21:56 UTC#706
glad you like my mod,
Posted Jun 22, 2009 · 21:57 UTC#707
so do you have a paypal?
Posted Jun 22, 2009 · 21:58 UTC#708
here you go [email protected]
Posted Jun 22, 2009 · 22:07 UTC#709
donation sent
Posted Jun 22, 2009 · 22:10 UTC#710
donation sent
THANK YOU
Posted Jun 22, 2009 · 22:37 UTC#711
Hey, IDT,
Is it possible to get the route edit screen to zoom in?
This one:file.php?id=7203
It would make it handy to edit the speed cams on multi-lane roads. It it too hard in the current config since it does not zoom wheras the CMH mod I was using did.
Thanx!
Bud
Posted Jun 22, 2009 · 22:52 UTC#712
Hey, IDT,
Thanx!
Bud
the zoom functions work in planmode, i think the reason why it's not zooming in far enough is because that's how it was set on my sys.txt
Posted Jun 22, 2009 · 23:10 UTC#713
I am using MY sys.txt:
[device]
type="PIONEER746UC"
[interface]
skin="ui_pioneer"
default_day_color="COLORSCHEME~Pioneer Blue Day"
default_night_color="COLORSCHEME~Pioneer Blue Night"
tmc_events_icon_set="$tmc2.spr"
small_tmc_events_icon_set="$smalltmc2.spr"
show_kml_type=0
maxzoom2d=6000000
show_exit=1
defaulttilt3d=8300
[rawdisplay]
screen_x=800
screen_y=480
class="landscape"
highres=0
[debug]
skip_eula=1
show_lane_info=1
enable_roadshadow=1
enable_buildings=1
restart_mode_in_file=1
traincrossing=1
speedcam_enabled=1
cache=2048
[folders]
;app=""\My Flash Disk\APL2\iGo"
data="\My Flash Disk\User\UserData\iGo"
tts_nuance="\My Flash Disk\APL2\iGo\ScanSoft\RealSpeakSolo"
secondary_app="Storage Card/usericon,USB Disk/usericon"
usb_trackexport_path="\USB Disk"
storage_trackexport_path="\Storage Card"
[gps]
port=7
baud=9600
log_base_dir="\My Flash Disk\User\UserData\iGo\LogData"
default_latitude="34.05116"
default_longitude="-118.24258"
[3d_config]
roadsign_lines_per_screen=19
[local]
voice_key="Eng_us_m1"
default_language="english US"
[regional]
units=1
[dynamiccompressor]
compressor="1"
a0="56806"
thrs="24703"
ratio="8"
gain="8"
[timezone]
reset_os_timezone=1
[map]
3d_scale_carmodel=1
3dcarsizemin=6000
3dcarsizemax=8000
3dcarsizemul=40000
3d_tunnels=1
3d_max_tiltlevel=10000
3d_max_zoomlevel=4000
3d_min_zoomlevel=40
3d_max_zfar=8000
show_oneway=1
[smartzoom]
minangle=30
maxangle=81
restore_smartzoom_on=1
[poi]
;enable_pois_before_080217=1
Posted Jun 22, 2009 · 23:14 UTC#714
Also....
The speedcam settings display two different speeds and the slider is not in increments of 5MPH. If I change the sliderbar increments will this screw with the ACTUAL speed??
Thanx,
Bud
This line in speedcam_800_480.ui:
Thanx!
Posted Jun 22, 2009 · 23:34 UTC#715
Also....
Thanx,
Bud
are you sure your using my mod? that never happens to me as i have changed a code in the speedcam.ui and replaced it with this
;SETFORMATTED_UNIT_TEXT txtSC_SpeedUnit "km/h"
	runif nCamSpeedUnit 0 'txtSC_SpeedUnit.SET "mph"'
       	else_run 'txtSC_SpeedUnit.SET "km/h"'
Posted Jun 23, 2009 · 00:37 UTC#716
Yes! V4.2
Would it have anything to do with the fact that I am in the states and not Canada, eh? 8)
Posted Jun 23, 2009 · 00:50 UTC#717
Yes! V4.2
:lol: , nah, i just checked it again and the speed camera settings would just stay the same the whole, km values on top of the mi values, could you check your speedcam.ui for the code i posted above,
regarding the zoom in planmode, i don't know but it just stopped zooming, i might add a zoom-in/zoom-out button on the planmode screen
Posted Jun 23, 2009 · 02:48 UTC#718
IDT you've done it again! v4.2 is working 100% and my speedcam spoken alert is working like a charm!!
Thanks as always............
Posted Jun 23, 2009 · 04:49 UTC#719
you're welcome
Posted Jun 23, 2009 · 06:12 UTC#720
[utility]
Thanks for looking with me :D maybe we'll find a nice solution
Posted Jun 23, 2009 · 07:41 UTC#721
I know of some Igo8 mods(non-pioneer),that have a button on their menu to start wince, from there i was able to start tomtom on my previous machine, but only to start it, my machine lacked memory to run it.
Posted Jun 23, 2009 · 14:58 UTC#722
Yes! V4.2
It is in my speedcam_ui but,....?
	txtSC_SpeedValueMI.SHOW
	txtSC_SpeedUnitMI.SHOW
	txtSC_SpeedUnit.SHOW
	run sc_hscSC_Speed_OnChange
	sprSC_Type.PHASE "vTmp"
	sprSC_Dir.PHASE "vDir"
	runif vTmp 1 'txtSC_SpeedValueMI.HIDE, txtSC_SpeedUnitMI.HIDE, txtSC_Speed.HIDE, hscSC_Speed.HIDE, txtSC_SpeedValue.HIDE,  txtSC_SpeedUnit.HIDE, txtSC_SpeedNo.HIDE'
	runif vTmp 4 'txtSC_SpeedValueMI.HIDE, txtSC_SpeedUnitMI.HIDE, txtSC_Speed.HIDE, hscSC_Speed.HIDE, txtSC_SpeedValue.HIDE, txtSC_SpeedUnit.HIDE, txtSC_SpeedNo.HIDE'
Thanx!
Bud
Posted Jun 23, 2009 · 22:22 UTC#723
Yes! V4.2
Thanx!
Bud
so did you got it sorted out?
Posted Jun 23, 2009 · 23:59 UTC#724
Nope...still shows a larger font speed reading (MPH) above and a different displayed number which is smaller font below (also in MPH)..:(
Posted Jun 24, 2009 · 00:08 UTC#725
try this
change this part
		txtSC_Speed.SHOW
	hscSC_Speed.VALUE nCameraSpeed
	hscSC_Speed.SHOW
	txtSC_SpeedValue.SHOW
to this
		txtSC_Speed.SHOW
	hscSC_Speed.SHOW
	;runif nCamSpeedUnit 0 'txtSC_SpeedUnit.SET "mph"'
       	;else_run 'txtSC_SpeedUnit.SET "km/h"'
	;txtSC_SpeedValueMI.SHOW
	;txtSC_SpeedUnitMI.SHOW
	;run sc_hscSC_Speed_OnChange
	runif vTmp 1 ' txtSC_Speed.HIDE, hscSC_Speed.HIDE, txtSC_SpeedValue.HIDE,  txtSC_SpeedUnit.HIDE, txtSC_SpeedNo.HIDE'
	runif vTmp 4 ' txtSC_Speed.HIDE, hscSC_Speed.HIDE, txtSC_SpeedValue.HIDE, txtSC_SpeedUnit.HIDE, txtSC_SpeedNo.HIDE'
and in your speedcam_800_480 change this code
to this
haven't tried it but it should work, let me know how it goes
Page 29 of 33
