IDT v4.2 on p46, last for 2.0
By ill.die.trying · Mar 12, 2009in Hacks/Mods💬 801 posts👁️ 102,601 views
Page 27 of 33
Posted Jun 17, 2009 · 17:17 UTC#651
Every time unit is restarted before fully booting (i.e. after exiting Test Mode w/o starting up Navi, or sometimes when using a remote starter), MSN becomes hosed. As long as you make sure it is restarted only after full boot of the Navi part, MSN should keep working.
Boris, Thanks for the tip. This is intersesting.
OK... so if the power is cut when the startup splash screen is still on, then MSNDirect gets hosed. Is that what I'm hearing? Do I have to wait until everything is working, or just until the splash screen is gone, and I see the "Destination, Contacts, AV Sources" screen or the map warning? Or, do I have to wait for the "Please wait... system starting" message across the bottom to disappear as well? I have to keep reminding myself that this is Windows that I'm working with... and there are various levels of "startup" involved.
So... does this classify as an MSN issue, a Pioneer issue, or a mod issue? Also, is there any way to fix this? Does it even happen on brand new (not-yet-modded) units? They had to have known about the problem... why isn't there an MSN reset button built into the software? Hopefully FW 3.0 will address the issue.
Thanks again. With the right instructions, I think my MSN will work more consistently.
Posted Jun 17, 2009 · 17:46 UTC#652
Hey IDT,
I just finished modding some of your v4.0 Data.zip last night and am loving it. Thanks for the great mods! Could you tell me which files have been edited in v4.1 so I can paste into my Data.zip and not have to re-edit everything?
Thanks again
just examdiff it, not that much was changed so it would be an easy thing
Posted Jun 17, 2009 · 17:49 UTC#653
I downloaded and followed you instructions to the letter. My 700bt keeps rebooting. Any ideas?
anyone else having any problems with v4.1?
Posted Jun 17, 2009 · 17:51 UTC#654
Hey, Guys!
I've been using cmh928's mod for quite some time, and I had problems with MSN Direct, so I decided to try IDT's latest (4.1), and I'm still having the same issue. Can anyone tell my why MSN Direct seems to never have any data? Please see the picture below. Sometimes I can fix it by pressing the reset button on my F90bt, but most of the time, it just comes and goes as it pleases. It just tells me "No [gas, traffic, movie, etc] data available" Is this an MSN problem, or a mod problem? CMH told me to just hit the reset button, and it should be fixed... but that only works some of the time, and it doesn't STAY fixed. It's really annoying because my trial period is gonna be over soon, so I have to fix it so that I can make a decision on whether to keep it or not.
Now, for a few suggestions/requests...
IDT... would you consider putting an MSN butterfly on the map screen that goes to the MSN Direct screen? I'm sure you've considered this... because I know it alienates f70bt users... but you could also having a non-MSN version, if it's not too much trouble to maintain two versions. Just a suggestion. Also, would you consider putting the MSN butterflies on the two "hotspots" on the MSN Direct screen? Your mod leaves us blind to fumble around to find them. I'm sure you know what I mean, but for those of you that are unaware... there are two invisible "buttons" on the MSN Direct screen that you have to push (left one, then right) to get to the data screen from my screenshot. CMH's mod has two MSN icons over the hotspots so that we can find them easily.
Anyway... back to my MSN Direct problem... Normally, it would have valid data for each entry, but most of the time I get the screen I've posted below, where it looks like all the data has been wiped.
And, finally... I like your map screen and the icons and high-res graphics in the upper-left corner, but I'm used to pressing the graphic there to hear the last audio prompt. Instead, I get the trip timeline. How do I hear the last audio prompt on-demand? Would you consider making this part of your mod? I believe CMH had the compass function as the trip timeline shortcut... and he didn't have a shortcut to the time settings. Which, we may all agree... the time settings aren't too important once you set the time for the first time. (Unless you disconnect the battery a lot)
Thanks again for the mod. I hope you can help me iron out my issues with MSN Direct, as well as to help me get used to your new mod.
i'll see what i can do, the hard part is i'm not familiar with the whole MSN thing so i 'll have to figure that out first
Posted Jun 17, 2009 · 18:15 UTC#655
Thanks. If you need any particulars, let me know, and I'll do what I can. I'm sure there are others that know more than I do, though... hence the quick reply from BorisM about fixing my epic MSN fail.
Posted Jun 17, 2009 · 22:02 UTC#656
i'll have it ready tonight,
regarding the last voice prompt, it was requested by a member to have it as a shortcut to the itenerary screen, i will try to sort things out so that it would work out for everyone,
regarding the time shortcut, i myself don't use the shortcut that much but i don't find the sense for pressing something to show up something not related to it, here's an example, the time being used as a shortcut for track log recording, how would time be anyway related to track logs? also, you know how in windows xp/vista that when you double click the time it opens a window for the time setting? that's the approach i went and tried to have it as simple but functional as i can,
Posted Jun 17, 2009 · 22:25 UTC#657
Works like a charm for me. Maybe he didn't clear the user data?
Posted Jun 17, 2009 · 22:28 UTC#658
i just hope he did,
Posted Jun 17, 2009 · 22:58 UTC#659
I had the track/time shortcut as I use it frequently when I am off roading but it is not a biggie for me. I had made the next street text box call out the "saynextcommand" like some other mods had in the navigate pane or whatever you call it. I had made some other subtle changes to mine as well but overall I like(d) it.
Unfortunately, I am having issues (as posted prior) with the trip computer freezing and the track logs not being retained. I had tried a new FAT32 SD, erased ALL of my data and user files, reset it numerous times and yet I have the aforementioned problems.
I even went with an entirely unmolested mod and still I cannot get any track logs to stick. Sometimes they will and sometimes they won't.
I think the only other alternative at this point is to completely blast the flash disk and start with a new LPUE080.
I am at wits end with these damn things.
It's great they can be modified but it sucks when you have problems :twisted:
Oh well, keep up the great work!
Posted Jun 17, 2009 · 23:09 UTC#660
atleast those are the only problems you're having, right now i'm trying to figure out how the hell can i get my hands on the 3 update without spending anything, worst case scenario is that i'll just be contented with what i have and leave the forum as i my work here is done,
Posted Jun 17, 2009 · 23:16 UTC#661
1000
Posted Jun 17, 2009 · 23:23 UTC#662
1000
WOW - And I remember when you were just starting out. You've provided a great service to the forum.
Keep up the good work!!
Posted Jun 17, 2009 · 23:57 UTC#663
Hey IDT, CHILL BRO!!! Right now we arent even sure if this firmware update is going to speed things up and make us happy and if its gonna lock us outta testmode or not. Lets wait till it comes out and see what the first people that get it say. Then if all is positive i personally will post a thread along with make the first paypal payment toward you getting the update. For $70 people will chip in and you'll have it in no time! You are one of the main and very talented skin modifiers on here. Theres tons of people on here including myself that are rocking your zip and are very happy with the avic because of it. And i'm not trying to kiss your ass just speaking the truth so i'm sure people will want to chip in for you. With that said you won't be going anywhere and we will continue to see new and exciting mods to come! :D
Posted Jun 18, 2009 · 00:29 UTC#664
that would be nice,
Posted Jun 18, 2009 · 02:47 UTC#665
the MSN version is done, i'll post it once i've tried it, it will be up later tonight
Posted Jun 18, 2009 · 17:03 UTC#666
IDT_MSN_v4.1.zip is intended for users that have MSN direct
-removed gps siganal button on navi screen to give way to MSN button
-direction icon is now back SAYNEXTCOMMAND instead of the itenerary shortcut
instructions:
for newbies READ THE HACKS THREAD FIRST, don't just jump into doing a mod without enough knowledge,
1) first off this is not an auto installer, this is leetlauncher v2 that i use to install my mods
2)extract files and transfer all files to a freshly formatted SD card
3)this already has testmode file so no need to add anything else
4)insert SD to unit,
5)boot up unit
6)click testmode
***if this is your first time,PLEASE BACK UP YOUR FILES
7)all the files are in files to be added folder
8)copy DATA.ZIP, SYS.TXT, and DS-DIGI file to igo folder
9 )optional, copy EZRIDER to igo folder and copy license to content folder
10)optional sound files, copy files inside sound folder and paste to myflashdisk/data/sound
**I RECOMMEND DELETING THE SAVE FILES, it's in My Flash Disk\USER\UserData\iGo\save, everything should be deleted except for favourites.dat if you have it
11)once done click down on control knob and then click the pioneer logo,
12) wait for it to boot and your done, DO NOT REMOVE THE SD AFTER, IF YOU WANT TO REMOVE THE SD CARD TURN OFF THE IGNITION BEFORE DOING SO
here's the link
ftp://avic:[email protected]/illdietrying
Posted Jun 18, 2009 · 17:15 UTC#667
Are you going to put the itinerary as a shortcut somewhere else? I found that alot more useful than next command. I guess i can just save the code and just copy and paste on your future updates.
Posted Jun 18, 2009 · 17:28 UTC#668
i'll have that on the next update, i found a bug on the multiplanning so i'll include that when i get that fixed,
the bug is nothing major, it's just that when on the multiplanning screen the turn restriction shows up for some reason (shows up only when turn restriction is data is available and disappears right after) i'll have it figured out later tonight
Posted Jun 18, 2009 · 17:36 UTC#669
Great. :D What are u planning on using as the shortcut?
Posted Jun 18, 2009 · 17:39 UTC#670
Cant seem to download the MSN version. Gets to 12% completion then hangs.. Anyone else had success?
Posted Jun 18, 2009 · 17:42 UTC#671
this one
Posted Jun 18, 2009 · 17:44 UTC#672
i just tried it and it's working ok, check it again and if it still won't let you then i'll post it somewhere else
Posted Jun 18, 2009 · 17:51 UTC#673
Oh ok. I thought you were going to use something thats already on the screen. So to put that icon means to take something else away no? Can't fit anymore at the top of the screen.
Posted Jun 18, 2009 · 17:52 UTC#674
Oh, now its working.
Posted Jun 18, 2009 · 17:58 UTC#675
don't worry, i'll figure something out
Page 27 of 33
