IDT v4.2 on p46, last for 2.0
By ill.die.trying · Mar 12, 2009in Hacks/Mods💬 801 posts👁️ 102,601 views
Page 5 of 33
Posted Mar 28, 2009 · 05:35 UTC#101
I think the work you guys are doing looks great! I'm just curious why no one is using something like keepers quicklaunch with the hidden panel for a cleaner look? I've been using that for a while now and just feel it makes the screen look less cluttered and all the icons you guys are using will come up with one touch.
personal preference buddy,
Posted Mar 28, 2009 · 05:39 UTC#102
No i agree. Didnt mean to offend, just didnt know if u guys were aware of the mod. :D
Posted Mar 28, 2009 · 05:44 UTC#103
non taken, i was actually looking into doing it before when i just started but i figured i'd rather do my own,
Posted Mar 28, 2009 · 06:38 UTC#104
I use all the icons displayed on a regular basis. Why touch twice when you can touch once? Where the icons are on these is just blocking sky in the 3D angles I use. In route, the unneeded icons are hidden and the space used for streetnames.
Posted Mar 28, 2009 · 14:04 UTC#105
Newbie here. ill.die.trying couldn't have made the latest update any easier to do...however, I copied the SD files and installed them in the proper folders on the flash drive and it looks exactly the same (compass still below the time, no date, etc.) anyone have any ideas?
SPE999
Posted Mar 28, 2009 · 14:07 UTC#106
Disregard everything after "Newbie here". I just noticed ill.die.trying hasn't posted the files for the latest update...
SPE999
Posted Mar 28, 2009 · 16:58 UTC#107
i don't get it?
Posted Mar 28, 2009 · 16:59 UTC#108
SPE999
having a little problem right now with my connection that's why i haven't posted the new data.zip yet
Posted Mar 28, 2009 · 17:07 UTC#109
i don't get it?
It was in reference to:
"I've been using that for a while now and just feel it makes the screen look less cluttered and all the icons you guys are using will come up with one touch."
You have to hit it once to unhide the panel then look for the icon you need and hit it again. The space being used for icons on our versions doesn't block anything but sky in 3D mode, which is why I like it better than all the other mods with icons down the sides.
Posted Mar 28, 2009 · 17:24 UTC#110
i don't get it?
You have to hit it once to unhide the panel then look for the icon you need and hit it again. The space being used for icons on our versions don't block anything but sky in 3D mode, which is why I like it better than all the other mods with icons down the sides.
now i get it
Posted Mar 28, 2009 · 17:35 UTC#111
is there a problem with the web file manager, i cant seem to get on that?
Posted Mar 28, 2009 · 17:45 UTC#112
it' down right now
Posted Mar 28, 2009 · 18:22 UTC#113
i have two mods that i really need help with.
1. i cant get the blue boxes to show up from cmh928 data file. The route info box disappears and those blue boxes are much nicer than the green ones.
2. I know i am being picky but since IDT and Boris helped me fix the speed limit issue, now it shows up even when there is no speed limit detected and just says 0. It does disappear when in route like you guys helped me with, but I also want it to disappear when there is no speed limit also. Please let me know if this is possible.
Thank you
Posted Mar 28, 2009 · 19:06 UTC#114
Thank you
Are you using navigation.current_speed_limit.valid for a visibler model for the text?
Posted Mar 28, 2009 · 19:12 UTC#115
I'm posting more to my FTP space.
ftp://avic:[email protected]/
GTIMatt's latest is on there as well as some utilities and stuff.. Use the readmes.
Let me know of any additions you'd like to see on it or if you'd like me to host your mods.
I probably won't be posting the full OEM backups as this is probably why the other FTP space got overloaded. I may post the essential files from them minus the maps, though.
Posted Mar 28, 2009 · 19:40 UTC#116
please check page 7 for the update link
Posted Mar 28, 2009 · 19:48 UTC#117
yes this is what i have
;Display Posted Speed Limit
Posted Mar 28, 2009 · 19:59 UTC#118
change your visible model to what Borism said
Posted Mar 28, 2009 · 20:18 UTC#119
i didnt read it correctly, so i replace; textmodel_wstr="navigation.current_speed_limit.number_text" with this navigation.current_speed_limit.valid
Posted Mar 28, 2009 · 20:22 UTC#120
not the text model, the visible model, please read first
Posted Mar 28, 2009 · 20:32 UTC#121
IDT's latest mod is mirrored on my FTP.
ftp://avic:[email protected]/illdietrying
no popups and much faster DL than the uploaded.to site.
His link also includes a hacked ezrider and license file if you need it, though.
Posted Mar 28, 2009 · 20:33 UTC#122
thanks.
Posted Mar 28, 2009 · 20:36 UTC#123
dont know if you remember but a while back i asked if i could have the speed limit not show when there is a route active and i was told to replace this:
with this:
so now i am really confused because if i re-use navigation.current_speed_limit.valid, wont this make the speed limit sign show up when there is a route active?
is this something i will have to deal with?
thank you
Posted Mar 28, 2009 · 20:40 UTC#124
with this:
thank you
try using the first one,
Posted Mar 28, 2009 · 20:45 UTC#125
no you will have to add it to his mod
Thanks, I would have no idea how to do that, but IDT did state that this is fixed int he next update, I am in no hurry.
You can find the directions in my signature, if you're familiar with coding.
I can post my data file which has Frum Roll's files for the route info box, although i am still waiting to fix the speed limit sign. You can use the file to compare and adjust the 3 files needed.
you still haven't fixed that stop button?
I posted some pics and my ui file on the 4th page of this thread. Any chance you can take a look. I know you are working on an update, can't wait to see it, but I cant get this to work. This is the only problem I have with the avic right now. thank you
here you go
i dont know if you remember this question i asked above
and the 1st one is what i originally had, wont this make the speed limit sign show up when there is a route active?
Page 5 of 33
