GTIMatt's Mods
By GTIMatt · Mar 23, 2009in Hacks/Mods💬 346 posts👁️ 60,843 views
Page 6 of 14
Posted Mar 30, 2009 · 21:46 UTC#127
....speedcam_800_480_ui...
5c5,6
< ;SC_WARN - Changes for spoken speedcam warnings
> ;SC_WARN_SET - Changes for custom camera alert settings
29a31,160
> ;<> Start
> ;<> End
180,184d310
193c319
< runifnot vSpeedcamSoundType 3 'vTmp2.Set 0'
> runifnot vSCWCustWarning "1" 'vTmp2.Set 0'
305c431,433
< runif tmpSpeedcamWarningLangType 2 'playsound "0_unknown"'
> PLAYSOUND "!alert5"
> runif vSCWCustUnits "0" 'PLAYSOUND "0_30mph"'
> else_run 'PLAYSOUND "0_30kph"'
326c454,455
< runif vSpeedcamSoundType 3 'run sc_SpeedcameraMuteSound'
> ;runif vSpeedcamSoundType 3 'run sc_SpeedcameraMuteSound'
> runif vSCWCustWarning "1" 'run sc_SpeedcameraMuteSound'
330c459,460
< run sc_selection_alert_EN
> runif vSCWCustUnits "0" 'run sc_selection_alert_EN'
> else_run 'run sc_selection_alert_EN_kph'
341,357c471,477
< ;mh - The sounds in my code are all in English and only mph for the std UK limits. If you use kmh then you will need to create some new sounds
< ;and change the code below in each section to the following (replace 10_kmh_0 etc with the names of your sounds for each limt:
< ; runif %navigation.curr_speedcam.speed_limit.value 10 'playsound "10_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 20 'playsound "20_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 30 'playsound "30_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 40 'playsound "40_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 50 'playsound "50_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 60 'playsound "60_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 70 'playsound "70_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 80 'playsound "80_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 90 'playsound "90_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 100 'playsound "100_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 110 'playsound "110_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 120 'playsound "120_kmh"'
< ; runif %navigation.curr_speedcam.speed_limit.value 130 'playsound "130_kmh"'
361a482,484
> else_runif %navigation.curr_speedcam.speed_limit.value < 25 'playsound "0_15mph"'
> else_runif %navigation.curr_speedcam.speed_limit.value < 33 'playsound "0_20mph"'
> else_runif %navigation.curr_speedcam.speed_limit.value < 41 'playsound "0_25mph"'
362a486
> else_runif %navigation.curr_speedcam.speed_limit.value < 57 'playsound "0_35mph"'
363a488
> else_runif %navigation.curr_speedcam.speed_limit.value < 73 'playsound "0_45mph"'
364a490
> else_runif %navigation.curr_speedcam.speed_limit.value < 90 'playsound "0_55mph"'
365a492
> else_runif %navigation.curr_speedcam.speed_limit.value < 106 'playsound "0_65mph"'
369a497,511
372a515,517
> else_runif %navigation.curr_speedcam.speed_limit.value < 25 'playsound "1_15mph"'
> else_runif %navigation.curr_speedcam.speed_limit.value < 33 'playsound "1_20mph"'
> else_runif %navigation.curr_speedcam.speed_limit.value < 41 'playsound "1_25mph"'
373a519
> else_runif %navigation.curr_speedcam.speed_limit.value < 57 'playsound "1_35mph"'
374a521
> else_runif %navigation.curr_speedcam.speed_limit.value < 73 'playsound "1_45mph"'
375a523
> else_runif %navigation.curr_speedcam.speed_limit.value < 90 'playsound "1_55mph"'
376a525
> else_runif %navigation.curr_speedcam.speed_limit.value < 106 'playsound "1_65mph"'
380a530,544
383a548,550
> else_runif %navigation.curr_speedcam.speed_limit.value < 25 'playsound "2_15mph"'
> else_runif %navigation.curr_speedcam.speed_limit.value < 33 'playsound "2_20mph"'
> else_runif %navigation.curr_speedcam.speed_limit.value < 41 'playsound "2_25mph"'
384a552
> else_runif %navigation.curr_speedcam.speed_limit.value < 57 'playsound "2_35mph"'
385a554
> else_runif %navigation.curr_speedcam.speed_limit.value < 73 'playsound "2_45mph"'
386a556
> else_runif %navigation.curr_speedcam.speed_limit.value < 90 'playsound "2_55mph"'
387a558
> else_runif %navigation.curr_speedcam.speed_limit.value < 106 'playsound "2_65mph"'
391a563,577
394a581,583
> else_runif %navigation.curr_speedcam.speed_limit.value < 25 'playsound "3_15mph"'
> else_runif %navigation.curr_speedcam.speed_limit.value < 33 'playsound "3_20mph"'
> else_runif %navigation.curr_speedcam.speed_limit.value < 41 'playsound "3_25mph"'
395a585
> else_runif %navigation.curr_speedcam.speed_limit.value < 57 'playsound "3_35mph"'
396a587
> else_runif %navigation.curr_speedcam.speed_limit.value < 73 'playsound "3_45mph"'
397a589
> else_runif %navigation.curr_speedcam.speed_limit.value < 90 'playsound "3_55mph"'
398a591
> else_runif %navigation.curr_speedcam.speed_limit.value < 106 'playsound "3_65mph"'
400a594,608
Posted Mar 30, 2009 · 21:47 UTC#128
and "templates_800_480_ui"...
0a1,3
> ; SC_WARN_SET - Added longchoice6 so I can use a shorter bmp for audiable warning
153a157,159
> 	;<> Start
> 	;<> End
Posted Mar 30, 2009 · 21:48 UTC#129
..I'll spare the differences in the audio files. You know what the .ogg files you put in are so therefore they do not cause any conflict so far.
Thanx!
Bud
Posted Mar 31, 2009 · 00:02 UTC#130
Sorry 69 but I have to ask. ExamDiff is what is used to open and rewrite to ui files? Doing a google search now, can't fidn anything here.
Posted Mar 31, 2009 · 01:09 UTC#131
How easy/hard would it be to change the Speed limit sign image to reflect the US speed limit sign image?
I'm working on something now that will hopefully do what you are looking for. Should have something in a couple of days.
Awesome! Look forward to it. 8)
Posted Mar 31, 2009 · 03:13 UTC#132
Right here, dude..http://www.prestosoft.com/edp_examdiffpro.asp
Thank Boris. He turned me on to it. :):)
Posted Mar 31, 2009 · 05:23 UTC#133
Great!
I'LL HAVE TO TRY THIS TOMORROW!
I had at one time some file that I had changed in one of my previous iterrations that gave me the ability to add specific cameras with speeds in the "5"'s by moving the slider in the "add camera" screen but that is gone and is just now "NO LIMIT, "30MPH", 40MPH", ....
iI cant find it now for the life of me. WHat would need to be changed in order for the slider to be able to assign cams in the 5 increments? And would this work?
Also, i tryed to change out some stuff in the "LONG/LAT" variables to display the "Gps.elevation" instead of the coordinates when I clicked the compass as this is more to my liking . I got some FFUEI errors when doing so but I did get the altitude to display but it conflicted with the script in the blue box. WHat do I change to get it to display altitude in the upper header area instead of LAT/LONG coordinates??
Thanx,
Bud
Open speedcam_800_480.ui and search for
HSCROLLBAR hscSC_Speed
Then adjust the possiblevalues parameter to your liking :)
Got It!!
Thanx again,
Boris :)
Posted Mar 31, 2009 · 13:54 UTC#134
Got It!!
Thanx again,
Boris :)
Any time :)
Posted Apr 01, 2009 · 00:01 UTC#135
Loving it.
Got one question, while using another DATA file I was getting lables on all the streets, near and far.
With this one I am only getting street info on the ones I am crossing over. The streets that are further away does not shaw the street names.
Can someone please tell me how to enable that
Posted Apr 01, 2009 · 02:34 UTC#136
Loving it.
Did you change a color scheme? Settings in DATA.ZIP do not control street name display.
Posted Apr 01, 2009 · 03:20 UTC#137
One level of zoom makes a big change on street labels, too. Seems like fonts may make a difference, too. When I had changed my Tahoma to a modded one (dumpystig, I think) I noticed labels didn't show as much. Using smart zoom on mine but limiting it between 200 and 400 feet, gives decent labels.
Posted Apr 01, 2009 · 11:46 UTC#138
Thanks a lot guys, I will play with it and give it a try.
You guys are the best.
Thanks for the speedy response
Posted Apr 03, 2009 · 01:01 UTC#139
I've been using Matts original Data zip untill today. I installed Data Zip V2 and its even better!!!
Just wanted to say keep up the good work.
Question: Is there a red light cam mod? Here in NY City we have many red light cameras.
Thanx
Posted Apr 03, 2009 · 01:50 UTC#140
This is in Boris' version of his "ui_pioneer\800_480\ui\setting_800_480.ui" file in his "setting.rar" data.zip..Try that
Finally got around to downloading examdiff, both files have this coding. anyone else know where this would be activated? I checked the sys.txt and that seems to be fine too.
Posted Apr 03, 2009 · 07:30 UTC#141
Thanx
My data.zip will warn about red light cams as long as the speedcam warnings are turned on and the cameras are on the system.
Posted Apr 03, 2009 · 10:58 UTC#142
How can I add cams only because I have 3 by me and they didn't appear on the screen.
Just in case I turned on the cam option. :D
Posted Apr 03, 2009 · 15:25 UTC#143
ialso have another request. possibly adding a nav screen button to the nav settings. would look good on the right side where there are only 3 buttons in non-route mode.
Posted Apr 03, 2009 · 16:20 UTC#144
**** New Version ****
Here is a link to a new version of my data.zip: http://www.mediafire.com/?gmtyib0j3ut
The changes in this version are:
Added following to custom alert setting subscreen
- Warning Volume slider
- Set whether warning beep mode (disabled = no beeps, When approaching = beep when within distance specified, Over Limit = Only beeps within distance speficied if you are over the camera limit)
- Warning Beep on Mobile Cameras (turns off the approaching beeps for mobile cameras)
- Warning Beep Distance (sets how far away from the camera the warning beeps start can be from 200ft to 1000ft or metre equivalent)
US or Euro Speed Limit Style option (bottom of the visual settings menu, choose US or Euro style)
Added building settings
Added changes so US users can add cameras (hopefully! my Euro model has this as std so if someone in the US runs this can they see if they can add camera as apparantly you couldn't on my previous versions)
Add additional speed limit values when setting up speedcam to better fit US speed limits
Fixed issue where when manually adding a mobile camera there speed slider is not displayed
Again, I would describe this a beta, I've briefly tested my changes but not extensivley. If you have any problems then post in this thread and I'll try to fix them.
Enjoy!
Matt.
Posted Apr 03, 2009 · 16:25 UTC#145
Thanx I definetly try this tonight.
Posted Apr 03, 2009 · 16:26 UTC#146
If you have the correct DATA.ZIP:
Select the spot on the map where the camera is.
Click the Map Info button on the right side of the screen
Click "Save As" button.
Click "Add Camera"
Edit camera info and click "Done"...
Posted Apr 03, 2009 · 16:53 UTC#147
Enjoy!
Matt.
Awesome stuff, Matt! Going to try it this weekend. My first mod install! 8) Thanks for all your work.
Posted Apr 03, 2009 · 18:16 UTC#148
Great!
Without going through a zillion lines of code which are the particular specific line you made changes to for just the speedcam volume slider controls and the custom beeps and camera settings?
I want to add this to my current DATA.ZIP using CMH928's latest rev which already has the buildings, speedcamera editing capability. I see some files in the directories with an edit date of 4-3-09. Are these the only ones?
Thanx again!!
\Bud
Posted Apr 03, 2009 · 18:22 UTC#149
Great!
Thanx again!!
\Bud
I've labelled all the code for the speedcam settings with << SC_WARN_SET>> so search for that and it should give you all the files I changed for it. Don't rely on the date as I have been working on this for few days so files with older dates may need to be changed too.
Posted Apr 03, 2009 · 18:41 UTC#150
Thats what I figured but I thought I'd ask. Even using ExamDiff Pro is painstaking to say the least :)
Thanx again for all of your hard work, Matt!!
Page 6 of 14
