GTIMatt's Mods
By GTIMatt · Mar 23, 2009in Hacks/Mods💬 346 posts👁️ 60,843 views
Page 7 of 14
Posted Apr 03, 2009 · 19:21 UTC#151
This is in Boris' version of his "ui_pioneer\800_480\ui\setting_800_480.ui" file in his "setting.rar" data.zip..Try that
Finally got around to downloading examdiff, both files have this coding. anyone else know where this would be activated? I checked the sys.txt and that seems to be fine too.
ialso have another request. possibly adding a nav screen button to the nav settings. would look good on the right side where there are only 3 buttons in non-route mode.
Or GTI, if you can point me to a tutorial on adding buttons, I would try this myself. Are your buttons custom? It appears I would have to mod/move the "in-route" buttons as well to fit it in, correct?
Posted Apr 03, 2009 · 19:25 UTC#152
696packbee, do you see any difference in cmh's files and GTI's that would lead to the building settings to be shown? BTW, love ExamDiff, I think it is easy to use.
Posted Apr 03, 2009 · 19:27 UTC#153
Just tried it out. WORKS PERFECTLY!!!
I just searched for the different files and added them into my DATA.ZIP and incorporated it with my existing mods an VIOLA!!
I like it. I just have to go back in and put back my previous linear compass and speedcam box but otherwise it all works as expected. You did your homework on this one, Matt!!
Thanx:)
Posted Apr 03, 2009 · 20:58 UTC#154
**** New Version ****
Here is a link to a new version of my data.zip: http://www.mediafire.com/?gmtyib0j3ut
The changes in this version are:
Added following to custom alert setting subscreen
- Warning Volume slider
- Set whether warning beep mode (disabled = no beeps, When approaching = beep when within distance specified, Over Limit = Only beeps within distance speficied if you are over the camera limit)
- Warning Beep on Mobile Cameras (turns off the approaching beeps for mobile cameras)
- Warning Beep Distance (sets how far away from the camera the warning beeps start can be from 200ft to 1000ft or metre equivalent)......
Nice... Mind if I steal some of the camera code for mine? :) I still want to keep the language selection option (nothing phases people more than having the navi bark at them in Russian all of a sudden :D ) but I want to incorporate your voice control...
Posted Apr 03, 2009 · 21:47 UTC#155
How can I add cams only because I have 3 by me and they didn't appear on the screen.
Just in case I turned on the cam option. :D
If you have the correct DATA.ZIP:
Select the spot on the map where the camera is.
Click the Map Info button on the right side of the screen
Click "Save As" button.
Click "Add Camera"
Edit camera info and click "Done"...
Hey Boris when I click on save as there is no Add Camera button. There is add Pin, Favorite, And something else dont remember right now, but no add camera.
I'm gonna install the new DATA.ZIP and see if I can do it there.
Posted Apr 03, 2009 · 21:52 UTC#156
I've been reading this forum for almost a year and have been trying to do the mods without having to ask but by reading first.
So I'm sorry for asking so many questions. AND Thanks for all the quick responses.... You Guys ROCK!!!!
Posted Apr 03, 2009 · 22:00 UTC#157
Go for it, it's the main reason I put it out there so that people can cherry pick the mods they want and incorporate them into their own, I tried to comment the code logically so it was easy to take the bits people wanted. Besides if it wasn't for your help I would never have got this far!
Posted Apr 03, 2009 · 22:11 UTC#158
One quick question. I see buildings are enabled but I believe I need something else to actually seem them. Is that correct? Will go put it in and see how it works. Thanks from Dallas, TX
Posted Apr 03, 2009 · 22:23 UTC#159
US or Euro Speed Limit Style option (bottom of the visual settings menu, choose US or Euro style)
Added building settings
Added changes so US users can add cameras (hopefully! my Euro model has this as std so if someone in the US runs this can they see if they can add camera as apparantly you couldn't on my previous versions)
Add additional speed limit values when setting up speedcam to better fit US speed limits
Fixed issue where when manually adding a mobile camera there speed slider is not displayed
Again, I would describe this a beta, I've briefly tested my changes but not extensivley. If you have any problems then post in this thread and I'll try to fix them.
Enjoy!
Matt.
Thanks Matt, can I ask where the coding was to activate buildings settings?
Posted Apr 03, 2009 · 23:25 UTC#160
Hey Matt, could you possibly get a screen shot of the new US speed limit sign? Thanks.
Posted Apr 04, 2009 · 01:09 UTC#161
Matt, this is the motherload of all mods thus far. Seriously the options are great. If only I could get a "tools" icon on the nav screen :( Good job.
Posted Apr 04, 2009 · 06:41 UTC#162
Do you mean a button that takes you to the Navi Settings screen? If so that should be fairly simple, you should just be able to call NEXTSTATE with something like st_navisettings (I'm not sure of the name as I don't have the code in front of me, but its in setting.ui). I'm just not sure where you would put it as the screen is pretty crowded as it is.
Posted Apr 04, 2009 · 10:23 UTC#163
Hi Matt,
Great development on your mod. You keep suprising me.
But can you please update your data file with this issue??
viewtopic.php?f=34&t=23046&start=0&hilit=finally
Its for the building visability in the new color schemes and maps.
I only dont know if it affects settings with normal color schemes and older maps
Posted Apr 04, 2009 · 18:04 UTC#164
Is there a way for the music volume to drop when a speed camera warning is played, so you can hear it better at louder music volumes?
Posted Apr 05, 2009 · 06:20 UTC#165
That means that your PLACExxx.UI files do not enable it... Are you using Matt's ones? Since he's in Europe where the functionality is enabled by default may be he didn't change it... I guess you could try using mine. I don't think there's anything in mine that would make iincompatible with the rest of Matt's files...
Posted Apr 05, 2009 · 06:22 UTC#166
Thanks. Your code is clean enough so it should be easy...
Posted Apr 05, 2009 · 07:33 UTC#167
with your permission i would like to integrate a couple of your mods with mine in my next update
Posted Apr 05, 2009 · 08:11 UTC#168
Not sure if this was being asked of me or Boris but if it was me then feel free to use whatever you want.
Posted Apr 05, 2009 · 19:17 UTC#169
Installed the latest version a bit ago. Didnt drive anywhere, just sat in the driveway. But everything looks great and seems to work. AWESOME stuff, Matt!
Posted Apr 05, 2009 · 21:54 UTC#170
Check that. Just took it out for a drive and I dont get ANY speed limit indicator. Pretty sure I have all the settings right. What am i missing? :?
Posted Apr 05, 2009 · 23:01 UTC#171
it might be because the speed limit in the area your driving is not known
Posted Apr 05, 2009 · 23:18 UTC#172
I installed the new Data.zip and it has the add camera option.
Thanx for reply
Posted Apr 06, 2009 · 01:10 UTC#173
Thanx for reply
Good.Things like Speed cameras affect more than a single file, so you have to make sure you get all the code to support them properly...
Posted Apr 06, 2009 · 02:21 UTC#174
hey GTIMATT,
anyway you could make the turn restriction to be turned on/off in the route settings?
Posted Apr 06, 2009 · 11:46 UTC#175
Hi Matt,
http://avic411.com/forum/viewtopic.php? ... it=finally
This will be in my next version.
Page 7 of 14
