New Nav mod (Updated Mar 23, 2010) (Now 3.0 version)
By BorisM · May 24, 2009in Completed Mods/Themes💬 684 posts👁️ 133,910 views
Page 26 of 28
Posted Dec 16, 2009 · 12:53 UTC#626
December 15 update from Andr2000 (Firmware 3.x)
+ Added button to return to Navigation screen from Route Planning screen
+ Integration with Avic_Net
Hi Boris, The December 15 version suffered the same rebooting problem like the earlier version. I removed the "no screensaver" codes, it is working fine so far. :D:D:D
Ah, cool. By the way, where do you remove them (I haven't looked at code in a while) from? I might as well upload a US-specific version with no screensaver...
Thanks I got it working.
Jimbo
Posted Dec 16, 2009 · 15:12 UTC#627
I removed the codes from the two files and so far so good. BTW I am using F500BT US version.
FILE 1:
\ui_pioneer\800_480\ui\general_800_480.ui
Line 106
FILE 2:
\ui_pioneer\common\ui\navigatemap.ui
Line 1279
Posted Dec 16, 2009 · 19:56 UTC#628
What do you mean by Phone menu? I'm pretty sure that it is doable, though.
I would like to able to go to the phone settings from the nav screen.
Jimbo
I'll need to check on the Russian forum. I believe they had a list of messages you could send through iGO scripts to bring up different AVIC programs.
Why would you need to access phone settings that often, though, I wonder...
Any luck on the Russian form? Just curious if we can do something with the rear view camera also.
Jimbo
Posted Dec 16, 2009 · 21:04 UTC#629
Jimbo
No... only found messages to make phone calls, but not ones to bring up phone settings. I don't think anybody specifically looked for it, though.
Posted Dec 16, 2009 · 22:30 UTC#630
FILE 1:
Line 106
FILE 2:
Line 1279
Could it be that you are using a visiblemodel for time in the date display code? Maybe try visiblemodel="gps.current_date.valid" Shouldn't cause reboots but then again nothing else in there should either.
Posted Dec 16, 2009 · 23:53 UTC#631
FILE 1:
Line 106
FILE 2:
Line 1279
I changed it to "gps.current_date.valid and and it kept rebooting.
So I deleted the above two files and it works again.
Jimbo
Posted Dec 17, 2009 · 00:36 UTC#632
I downloaded the zip last night and installed it a few minutes ago. I didn't change anything in the zip and it booted without any issues. Took it in the garage to get a signal and still no issues. The blank screen is activated by longclicking the lower left corner.
I must have a freak unit as I'm not having the issues many others have in this thread or diaftia's thread. My unit a F500BT and I'm in the U.S.
Posted Dec 17, 2009 · 06:20 UTC#633
Jimbo
1. Jimbo, do you mean that it is enough to have a blank ui_ScreenOff layer for it to work?
2. pls, try removing line-by-line: for examplem, remove the first line and run. then restore the first line, but
remove the second one and run. and so on (we have 3 lines there) - this will allow us to understand which line(s)
exactly cause the problem
3. try changing font="digital" to font="tahoma" on both lines
thank you!!!
Posted Dec 17, 2009 · 11:24 UTC#634
Jimbo
thank you!!!
I deleted the first line: reboot
I then restore the first line and deleted the 2nd line and it did work.
I did not change the font.
Jimbo
Posted Dec 17, 2009 · 12:39 UTC#635
can you please continue and try this scenario:
1. delete both 2nd and 3rd lines
2. delete only 3rd line
thanks
Posted Dec 17, 2009 · 21:04 UTC#636
I agree. I ran it fine as well turning on the screen saver with no problems. Anyone running anything external that would cause problems? I just had a person chime in about someone who was getting solid freeway signs. Turns out it is most likely the project mayhem theme. If you delete all save files (including favorites.dat) that solved it.
Posted Dec 18, 2009 · 00:26 UTC#637
thanks
When I deleted the 2nd and 3rd line it works (starts up).
When I deleted the 3rd line it works.
Only the 2nd line is when it keeps rebooting.
Jim
Posted Dec 19, 2009 · 20:30 UTC#638
What file is the Navi button for the Route Planning screen in and where in the file? I am not familiar with the coding yet and would like to take a look to see what was done to try and learn how to do some of this and maybe add it to Diaftia's mod. That is a great addition.
Update 12/20/2009:
Never mind, Diaftia already posted the info. Thanks for the great work.
Posted Dec 21, 2009 · 13:36 UTC#639
thanks
Jim
Hi Andr2000 Group:
I have another question for you. I would like to change the street labels in night mode on NAV screen from white to black. I was looking thru the color schemes and also color3d.ui in the common folder but had no luck changing the colors. Can you help me out?
Jimbo
Posted Dec 21, 2009 · 20:04 UTC#640
sorry, cannot help you with this :(
never tried to do something like this
Posted Dec 21, 2009 · 20:34 UTC#641
Hi,
I have two small problems with this mod:
- If different route modes are displayed (fastest, shortest, economic, etc.) they are all displayed with the same color
on the map (green) ? I believe this is not right, isn't it?
- How do I switch from 2D to 3D maps?
Thank you!
Hugo
Posted Dec 21, 2009 · 21:01 UTC#642
Hi,
Thank you!
Hugo
I think pressing the compass changes 2D/3D :)
Posted Dec 21, 2009 · 21:20 UTC#643
Hi,
Thank you!
Hugo
1. The button next to the plan mode button IIRC. It can be an airplane or a compass depending on the map mode you are in.
2. You need to get a compatible scheme that supports multiroute. Download the zip in my thread or IDT's thread and pull the scheme files out of it. They will work.
Alex
Posted Dec 22, 2009 · 00:37 UTC#644
I am trying hard to find where I can change the street labels from white to black in night mode.. I am puzzled as I can't find the scripts or codes.
Has anyone have done this in the past?
Any ideas on where I can start looking?
I have looked at color.ui in the common folder and tried to change a few things but no luck.
Any help would be appreciated.
Jimbo
Posted Dec 22, 2009 · 01:08 UTC#645
Jimbo
i think street label colors are in the schemes
Posted Dec 22, 2009 · 02:26 UTC#646
Jimbo
I have been looking in there. I changes a few color values and still did not change..
Any idea which line I should change?
Jimbo
Posted Dec 22, 2009 · 06:09 UTC#647
Hi,
Thank you!
Hugo
Alex
dank you for the help, yet I encountered another problem: most buttons have become their labels in Dutch which is alright, - I am native Flemish -, but some, however, are still in English. Where can I insert the translations, I would add the French and German translations too if missing and, of course, upload the files.
Thanks in advance,
Hugo
Posted Dec 22, 2009 · 16:43 UTC#648
Thanks in advance,
Hugo
...\content\lang\Lang_{name of language>.ZIP is a file that has translations. Look for dictionary.lang file in the archive and add translations for strings that are missing...
Posted Jan 18, 2010 · 19:46 UTC#649
January 18, 2010 update
+ Runs ExtLauncher, instyead of autorun.mscr
+ Program Launch Menu: all programr removed, iGo exit added
- Bug fix: "Select" button in POI detail screen would allow selection only if accessed through Main Menu\Destination
+ Can calculate real distance to POI: currently, iGO shows distance to POIs in POI list as the crow flies. Now added a button to compute real distance to POI from current GPS position
+ Call POI button change. If a phone is connected, it is a button. If not, static text.
Posted Feb 09, 2010 · 15:56 UTC#650
I think there is a problem with the download link. Only downloads 250kb of the 6mb file.
Can you re-host it?
Rob
Page 26 of 28
