sorry, but are you 100% sure that data r1272 does work and r1273 does not?
thanks
thanks
sorry, but are you 100% sure that data r1272 does work and r1273 does not?thanks
I will try again and get back to you.
Jimbo
then, pls try this one:
http://www.4shared.com/file/164776302/97b8f5c6/data_usa_no_screensaver.html
it doesn't have changes of r1273 file
then, pls try this one:http://www.4shared.com/file/164776302/97b8f5c6/data_usa_no_screensaver.html
This file works. Looks like you found the problem! Now can I get the latest update?
Thanks for looking! I thought I was crazy!
Jimbo
that one at 4shared is the latest, but w/o screen saver
thank you very much for your support!!!
now I have to understand how did that simple screen saver feature brake the things ![]()
last test for today:
http://www.4shared.com/file/164785161/cb8aefab/data_usa.html
can you pls try this one?
thanks
You are welcome! I just love this mod and always looking forward to the latest updates.
Jimbo
please, can someone else also try this file
does it work or still you see the unit rebooting?
thanks
can someone pls try this data: http://www.4shared.com/file/164486061/5e6958dc/data_usa.htmlit has only one change reverted that may cause rebooting. but anyway, it does work in Ukraine/Russia
BTW, Boris forgot to mention these changes in the latest release:
- nearest POI list is now optimized for 40 pixel icons
- there is a sound played on road shields show
- current date on screen saver screen
- speed cameras triangle signs, like "give way", were unproportionally stretched
Hmm, May be I missed one update, because speedcams is the only change that is outside of the spoiler tag on 4PDA... ![]()
please, can someone else also try this filehttp://www.4shared.com/file/164785161/cb8aefab/data_usa.html
thanks
Yes, the unit reboots itself.
The no_screen saver version works great. No reboot. ![]()
thanks
hm....
I did expect some problems with other big changes.
bit I did not expect any with such a change as screensaver.
it does work in Ukraine/Russia, but it doesn't in the US
ok, guys - thanks for helping. for now, you can use no_screensaver version:
it has all the changes the latest version has, but screen saver
BTW, if it reboots in an emulator as well, can someone pls post save folder of it?
This one worked in the emulator on the first try. Didn't save route and POI visibility settings when I did exit (test mode configured in sys.txt) but it restarted after that, which is better than the previous data.zip I was testing in emulator.
thanks
Hi ANdr2000:
I would like to have my sign post cover my icons when it appears on the map. Right now, my icons are showing thru the sign post. What can I do to change it?
Jimbo
I do not have the digital TTF in my igo. Just to be clear, I want to add the font file itself rather than the zip, right?
Thanks,
e39m5
Thanks,
e39m5
For the font, yes. Copy DIGITAL.TTF file to APL2\IGO folder.
December 15 update from Andr2000 (Firmware 3.x)
+ Added button to return to Navigation screen from Route Planning screen
+ Integration with Avic_Net
Hi Boris, The December 15 version suffered the same rebooting problem like the earlier version. I removed the "no screensaver" codes, it is working fine so far. ![]()
Ah, cool. By the way, where do you remove them (I haven't looked at code in a while) from? I might as well upload a US-specific version with no screensaver...
what is avic_net?
what is avic_net?
Something like Launcher with tools for connecting to the Internet through some Russian cellular providers.
i see, are they working on something like that for US users?
One could probably adapt configuration scripts to work with NA providers, but most phones/modems I have seen mentioned as working are Nokias and Benq-Siemens models that are hard to come by here...
Boris: I
I trried the 12-15-09 data file and it kept rebooting. I think it is the same problem we had on the last data file something to do with screen saver. Do you think we can have Andr200 make a data file With out the screen saver?
I worked with Andr2000 on the last data file.
Thanks Boris
Jimbo
i hope someone (i mean the ANDR2000's team) could create something for US users (nokia, sony, iphone)
hi, guys!
Well, I know that screensaver reboots the system. But the problem is that I don't know why.
Again, it does work ok for Ukraine/Russia, but it doesn't for the US.
I think that this code makes the problem for you (ui_pioneer/common/ui/navigatemap.ui):
Actually it's an empty state to display screen saver's layer only. And for some reason igo reboots
because of this code.
I cannot reproduce it myself, so if anyone could try playing around this code.....
thanks
hi, guys!Well, I know that screensaver reboots the system. But the problem is that I don't know why.
thanks
What would you like me to try?
I deleted the line from (ui_pioneer/common/ui/navigatemap.ui) and still get the reboot.
What should I do next?
Jimbo
