I think there is a problem with the download link. Only downloads 250kb of the 6mb file.
Can you re-host it?
Rob
Just checked it, downloads fine... Try again, may be with a different browser?
Can you re-host it?
Rob
Hey Boris, It's been some time... I have a tiny issue, and I'm 100% sure you know the answer to it.
My Nav crashed a month ago, I did a install of 3.002 (I think) to fix it, I grabbed your Data file today and put in place of the old (renamed original) once I replaced it the nav started crashing, wont actually boot up to the pioneer gui.
I thought at one point we also needed to copy the sys file and fonts, has something changed? Any ideas why the nav would crash with the data.zip you provided.
Holla' IDT and NSEW
Holla' IDT and NSEW
try reverting back to the stock and see if it works, if it does then that means the modded files that you have might be corrupted
Holla' IDT and NSEW
Yea original works, booted up fine.
Think I should re download and try again? besides the data file isn't there a couple others that need to be replaced?
I just tested the nav mod again, re download the file and uploaded it to thumbdrive, tested, still rebooting.
I swear the sys file was different... and there was a font or 2
Download and extract the digital font on page 40 and install it in apl2/igo folder. Should take care of re-boot issues.
Hi Boris:
Any chance of split screen and map changer on this mod? I put the split screen in. I noticed that IDT mod has the map changer which works great! He also have the fuel mod also.
Jimbo
Yes, this one needs the digital.ttf font file. It should work with stock SYS.TXT, though.
Hi Boris:
Jimbo
If the author decides that he wants the split mode, he'll put it in. I will post a suggestion on 4PDA, but really Stanislavovich's and Andr2000's philosophy is to keep it as straightforward and simple as possible.
yeah, I will not add anything like map changer and so on ![]()
BTW, there are number of skins that do have much more features to play with ![]()
Strange, this mod seems to only work when i delete my save files in igo8 folder, then once i turn it off and on again, it starts a reboot loop. so only the first time on a fresh save folder...
Id love to use this mod because the 2.06 nav is so plain!
btw this mods great!
wish it would work 100% of the time though.
Same happens on my unit when i tried using this Mod
Cheers, I figured there was something ![]()
How you guys been? NSEW I saw you got your trip calc working nicely.
March 23 update
+ In Trip Computer, instead of switching Via Point/Destination, calls up route plan.
+ In route plan, remembers zoom level. Moving through via points centers the map on them. Added FIT button for full view.
+ "Speed Breaker" camera type can have default speed value specified in system.ini in the [warning] section: speed_breaker="30"
+ Speed log saved only manually: go to log screen, and save from there. Log is saved to userlist\speed.log. Also copied to a flash card (Settings - Copy speed log+save date). Saves internal flash memory from wear.
+ Mobile Camera Collection function.2 modes available (Settings-Warning): mark presence/absence, or off. Collection of the next mobile speed trap is turned on 300 meters (~300 yards) before. Radar icon will have a spinning ring around it. 10 seconds after passing it turns to stopped with a countdown timer. During that time you can click the radar icon to confirm or reject mobile camera. Click is confirmed with a sound and ring is changed to a flashing blue ring. Export to flash card: Settings-Run-Transfer Camlog to USB (userlist\camera.log). Current log is automatically removed. All parameters set in? Settings-Warning
+ Query (Searches Criteria) works again as intended: search POIs by given criteria(location+POI group+ POI text).
+ DATA.ZIP cleaned up by 1.7MB by crick
March 23 update
Hi Boris:
I installed the 3/23/10 data file and I got an error message after loading that says:
Failed to open file
$traffic_speed.small.spr
Exiting Application
I did deleted my user files after the first time and still have the same result.
Any ideas to fix this?
Jimbo
get the picture from your previous data.zip and add the file mentioned to the new data at ui_pioneer\common
One guy and me we tried to clean up the data.zip from unneeded bmps ![]()
It has never been tested for the US, so it is possible that some pics are absent
get the picture from your previous data.zip and add the file mentioned to the new data at ui_pioneer\commonOne guy and me we tried to clean up the data.zip from unneeded bmps
Thank you. I copied over the file and it now works.
JImbo
For those just coming in, the latest version also needs traffic_speed_big.SPR/BMP as well.
Boris/andr - don't forget to change the update date on the main post.
Right, done.
sir,
do you mind posting some pics on the first page?
sir,
There are some in the first post. General appearance haven't changed since then.
when i replace the data.zip in my avic F500BT...appears a text box : system startup in PROGRESS..plz wait......any solution for this problem?
thanks guys!
when i replace the data.zip in my avic F500BT...appears a text box : system startup in PROGRESS..plz wait......any solution for this problem?thanks guys!
Did you add th font file as well?
Just came back from my test drive with this. It's awesome, really. Superb work – I love it!
One minor bug I noticed:
– While using an iPod, the cover-art prevents the speed-limit sign from being displayed.
Keep up the great work!
Daniel
