New Nav mod (Updated Mar 23, 2010) (Now 3.0 version)
By BorisM · May 24, 2009in Completed Mods/Themes💬 684 posts👁️ 133,910 views
Page 23 of 28
Posted Nov 10, 2009 · 19:32 UTC#551
November 11 update for firmware 3.0
+ More flexible tilt up adjustment: 1 degree increments instead of presets.
Hi BorisM, can you tell me the values to modify (which file) to allow using this with another mod ?
Posted Nov 10, 2009 · 22:00 UTC#552
Wherever Visual settings are, I haven't looked at the code for this one yet.
Posted Nov 10, 2009 · 23:03 UTC#553
Can you tell me a place to look? I currently use a mod that does not tilt by degrees degrees in a corner near horizon.
Posted Nov 11, 2009 · 00:32 UTC#554
I have a rebooting problem after updating the new version. The first time I installed it, it worked fine but then after turning it off then back on again, it kept rebooting itself. I have tried to delete the save files in the log and it did not help. Appreciate your help. :?::?::?:
Strange... should work, particualrly if it did work the first time. You could try rolling back to previous version...
Hi Boris:
I had the same problem.It kept rebooting at startup so I reinstalled my old data file.
Jim
Posted Nov 11, 2009 · 16:41 UTC#555
Hi Boris:
Jim
Strange. I checked it yesterday and it seems to generally work fine (I have a problem of having absolutely no free space of the flash drive right now, which does create issues).
Can you check how much free space you got on the My Flash Drive? If it is too low, it could lead to problems due to lack of memory...
Posted Nov 11, 2009 · 17:17 UTC#556
Boris:
I am using about 1.69GB and have 120 MB left.
Jimbo
Posted Nov 11, 2009 · 17:40 UTC#557
I loaded it up in the simulator last night it crashed right away looking for tracking.spr in the Igo_8 folder that does not exist. As soon as I added this folder it worked fine. Something is looking for that in the new build. I suspect this might be the cause.
Posted Nov 11, 2009 · 18:57 UTC#558
David.I have tried the above,but the emulator still crashes when it gets to loading languages.If I then delete all the data in the save folder,it will restart.However it will then go through the same sanario on restarting the second time.
Posted Nov 11, 2009 · 19:31 UTC#559
Boris:
Jimbo
That should be enough memory.
I've reported on the Russian forums, so let's see what developer says.
Posted Nov 19, 2009 · 00:05 UTC#560
Boris:
Jimbo
Boris:
Any feedback from the developer on the latest mod?
Jimbo
Posted Nov 19, 2009 · 04:57 UTC#561
+ 2D head-up in in overview mode. Turned on in Settings->Visual->Zoom control->Use 2D headup. Turned on by default
+ Shows adjustable zoomscale in 3D mode. Dragging the zoomscale changes map zoom, just like in 2D.
+ When navigating, if Show NextInfo is tuerned off, top bar is not displayed.
+ Screen Off: in Navigation or Plan modes, long tap in lower left corner switches screen to black with clock.
If tilt angle in 3D does not work, put these in SYS.TXT:
[map]
3d_max_tiltlevel=9000
3d_default_tiltlevel=9000
Where can I get this latest update? The data.zip download on the first pages says it was last updates 9/25/2009.
I very much apprecaite the work done here but it would be nice if updates were more easily identified as to where to download them. Again thanks for the work. I would like to get the lastest to try it.
Also where does the difital.ttf file go. I already downloaded it.
Posted Nov 19, 2009 · 14:53 UTC#562
Boris,Did we get an answer regarding the reboot problem?Thank you.
Posted Nov 19, 2009 · 17:10 UTC#563
He looked at Crash.txt data, but can not reproduce it. It does seem to be far more prevalent on US systems, though.
For what it's worth, I have significantly improved my system's stability by freeing up more space on the flash disk (there are TTS software files that can be safely removed since they do not correspond to any voice we have available).
Posted Nov 20, 2009 · 03:52 UTC#564
[map]
I am stilling waiting for someone to answer as to whether the data.zip file on page one is the latest since it says updated 9-25-09.
Also does this include the destination on the left/right setting in sys.txt or do I need to add that myself. I use Samantha (US).
I like the stock day color scheme from the 3.0 software so what do I need to do to keep that color scheme.
Also I want to change the compass to the one that displays the N-S-E-W bar like the attached picture. Where can I find the info for that. I know I can search but if any of you readily know where that info is please let me know to save me time.
Thanks for all the great work all.
Posted Nov 20, 2009 · 12:48 UTC#565
Hi Boris:
I deleted a few files in MY Flash Drive. When I try to run the latest data file thru ezrider, it crashes when it get to the languages. Does this helps you at all?
Jimbo
Posted Nov 20, 2009 · 16:54 UTC#566
Hi Boris:
Jimbo
Well, that tells me that you have probably deleted something that you should not have :shock:
Can you be more specific than "a few files"?
Posted Nov 20, 2009 · 23:12 UTC#567
The link takes you to the download the date is correct there- this is the right one, wrong date on page
http://www.4shared.com/file/129128249/7 ... /data.html
Updates have never changed from the first page, oh the wrong date but clicking the link would have seen that.
apl2\igo folder same place as the ezrider.exe
I doubt, the left/right destination is a different add on
Either mod this theme into a blue one like stock or use it as is. I have modded it some you can find it here
viewtopic.php?f=34&t=27989&hilit=dpdurst
If you get my file above and search in the navigatemap_800_480.ui file for ;dd you can find that pretty quick
Posted Nov 20, 2009 · 23:23 UTC#568
The announce of left/right destination is separate from the data.zip. A new entry does need to be added in the sys.txt as well as having a compatible tts file.
See this thread: http://www.avic411.com/forum/viewtopic.php?f=34&t=28834
If I'm wrong, please correct me and show me the way to do it.
Posted Nov 21, 2009 · 00:08 UTC#569
September 25 is the latest version for firmware 2.x.
November 11th (09-11-2009, writing the date in the order nature intended) is the latest version for 3.x firmware.
DIGITAL.TTF goes to the same folder as DATA.ZIP
This is an iGO skin only. It does not include color schemes, SYS.TXT changes, or anything like that. To use, say, N-S-E-W's street side enhancement, you need to d/l his voice file and make the change in SYS.TXT as he instructs.
Posted Nov 21, 2009 · 02:36 UTC#570
Hi Boris:
Jimbo
L just deleted a couple of the language files such as ESP and France. Kept the Us file. I was trying to free up more space as it was not starting before.
Right noe I beleive I am using the October 27th data.
Thanks Boris
Posted Nov 22, 2009 · 05:19 UTC#571
I very much apprecaite the work done here but it would be nice if updates were more easily identified as to where to download them. Again thanks for the work. I would like to get the latest to try it.
http://avic411.com/forum/viewtopic.php? ... it=dpdurst
Just wanted to say thanks to you and others for answering my questions. Thanks so much all.
I clicked on the data.zip link on the first page and got the old version. Thanks for the info for the right one. I am running the official 3.02 software.
The left/right destination announce sounds like it should work with Samantha, which is the voice I use. I have not tried this mod yet but may try it soon.
I just finished loading Diaftia's hybrid mods, which include most of the same things, and yes I did a full My Flashdisk backup first. I even have My FlashDisk saved on my laptop and on 2 drives on my main PC.
I will have to do a few mods to get things just the way I like but at least I have some great mods to start with. I have waited months because I wanted to see how these mods progressed and what my final decision would be. Also I have not wanted to invest much time in my own modding yet.
Thanks again all.
Posted Nov 23, 2009 · 17:05 UTC#572
Thanks Boris
It will create problems if you delete language files for voices that came standard on your country's model. I.e., deleting French and Spanish TTS files on the US model will kill Tel.exe (Bluetooth phone connector), even if you do not use them...
Posted Nov 24, 2009 · 12:43 UTC#573
Thanks Boris
Hi Boris:
Is seems to be working fine without the files I deleted. Should I put them back in?
Jimbo
Posted Nov 24, 2009 · 17:13 UTC#574
Thanks Boris
Hi Boris:
Jimbo
If everything does work, including the bluetooth system, then don't worry too much, just make sure you don't switch to the voice that's not there any more...
Posted Nov 26, 2009 · 01:35 UTC#575
So am I right in thinking the direct link I used from the thread for 3.0 isn't completely updated?
e39m5
Page 23 of 28
