skip warning and nag for AVIC F900BT 4.001000 update
By carver · Jun 18, 2009in Hacks/Mods💬 251 posts👁️ 162,920 views
Page 6 of 11
Posted Jan 20, 2010 · 20:52 UTC#126
This works on the the f-7xxxBT also
Posted Jan 22, 2010 · 13:28 UTC#127
upd 15.12.2009 update for 3.020200 version, UC or EW.
fixed CommonLib.dll for MAP button or map icons, and no parking warning
fixed MainMenu.exe - only for power-up warning, via press MAP button after two seconds
(need fixed CommonLib.dll for work)
fixed SystemSetting.exe - for Pioneer DEBUG MODE in System Information tabs
my f90bt always show me error screen, so, i always need press OK twice.
i don't understand, how to disable both nag screen.
for first - i can edit speed setting in config file, but for second error - no any way at search.
so, i found 3 screen for navi warning at my avic
map
destination
setting->navi
but in avic software i just found and skipped only first two screen,
also my avic UC (US) version, so it can tested only at UC software.
guys, if anybody has time, please test. thanks.
293 MSG_14_00_00_01    NS_STR_MSG_14_00_00_01 System detected improper connection of Parking Brake lead. Please check your configuration for safety. Please see Operation Manual for more information regarding safe operation.
513 MSG_13_02_01_02   NS_STR_MSG_13_02_01_02 This Navi product is intended solely as a driving aid. Review instruction manual and select route before driving. Navi is not a substitute for your attentiveness, judgment, and care while driving or moving your vehicle.  Always observe safe driving rules and driving laws, and follow road signs even if they contradict Navi's instructions.  By pressing OK key, you accept the license agreement in the instruction manual.
upd. i delete old file, and post new. please, test it. it better.
download/file.php?id=7321
upd 13.07.2009 update for 3.x version, UC or EW.
but power-up MAP warnind don't fixed. only like before.
📎 CommonLib_v3b1.rar
upd 14.08.2009 update for 3.010100 version, UC or EW.
update from 13.07.2009 with power-up fix also, but at this moment, only for testing
...i delete this file, it not good solution.
Carver -
I have an F90BT (US) running Diaftia's mods on v3.020200. I copied the 3 files to my APL directory, and still got the nag screen. So, then I tried just copying the commonlib.dll, and it still didn't work. What am i doing wrong?
BTW - both times it asked me to update my system settings. Is that normal? Should I say yes or no to this prompt?
Thanks,
Posted Jan 24, 2010 · 10:40 UTC#128
does this remove the parking lead detection msg too? thanks
Posted Mar 04, 2010 · 04:21 UTC#129
I installed this on my F700BT and it works great for the most part Im running 3.02. I never see the annoying caution screen before switching to Navi. It works when the unit boots straight to navi or if I switch to it.
The only problem that I have encountered is that sometimes when the unit boots up straight to the navi screen the map does not track. By this I mean that the arrow icon starts moving accross the map as I drive and eventual leaves the screen. The map doesn't "follow" and i'm left with a static image. If I hit the map button it snaps back to track the arrow and everything works great.
This occurs maybe 20-30% of the time I start the car. Anyone else have this happen and/or have a solution?
Posted Mar 13, 2010 · 19:35 UTC#130
Thanks for the hard work. Nice and easy, leamon skweezy. Worked on my 700 no issue.
Posted Mar 24, 2010 · 21:00 UTC#131
Does anybody have my same setup and can verify that this will remove the start up warning? I've got a F900BT with unofficial FW 3.0 and Diaftia's Hybrid Mod v2.3 There are no other changes. I'm sure that Carver has answered my question already but I have a real hard time understanding his English (sorry Carver). :?
Would be great if someone could tell me which files to use and how to install in English. Thank you!
Posted Apr 04, 2010 · 14:23 UTC#132
So its a bit confusing. Does the download from the 1st page work for US versions? I have an F700BT US.
Posted Apr 04, 2010 · 15:47 UTC#133
Yes.
Posted Apr 05, 2010 · 15:05 UTC#134
I used the download from the first page and it is all ok for me.
I have one F900 EU version and the official 3.020200 fw. :D
Posted Apr 06, 2010 · 13:15 UTC#135
AVIC_F900 v322 nowarn.rar
(292.66 KiB) Downloaded 572 times
I replaced the three files inside the APL folder, with files from the AVIC_F900 v322 nowarn.rar archive, everything is working perfect for me. I have a US/CANADA model of AVIC-X710BT.
Posted Apr 07, 2010 · 00:59 UTC#136
There are a couple on the 1st page, which one did you use?
Posted Apr 18, 2010 · 09:17 UTC#137
Hello, I live in Europe and i have a F910BT since 2009. I have used the testmode v2.3 and it worked well. Then i copied commonlib.dll from the AVIC_F900v322nowarn.rar and this works perfectly. I also put in the compass mod and also a succes. Thanx for that all.
Now i want to figure out the speed warning system. I have te speed camera function installed and its working, but i only want to have the warning when i am driving too fast. Now the F910BT always gives a warning, no matter the speed i drive. Is there any solution to this?
Regards, Chris.
Posted Apr 21, 2010 · 16:15 UTC#138
Can someone please confirm which file is the correct one to download! There are multiple links on the first page
Posted Apr 21, 2010 · 16:40 UTC#139
I unrar the AVIC_F900 v322 nowarn.rar file and replace existing files in the APL folder without issue, everything is working fine.
Latest update is:
(292.66 KiB) Downloaded 704 times
Posted Apr 22, 2010 · 04:11 UTC#140
Thanks Chuck, I appreciate it. :D I'm used to other sites where dead links and wrong links get changed or deleted.
Posted Apr 26, 2010 · 23:13 UTC#141
worked very well for me!
Posted Apr 29, 2010 · 08:00 UTC#142
If I am running 3.0101, which version of this do I run? will the 322 version work just fine? Or should I go to one of the previous versions? reading here it looked like they weren't as stable?
Posted May 01, 2010 · 15:57 UTC#143
Hi, can anyone comment? Thanks.
Posted May 01, 2010 · 16:01 UTC#144
As I said couple of posts up ...
Latest update is:
Posted May 02, 2010 · 18:56 UTC#145
Thanks Chuck88, I had read that but I wasn't sure of the context. I'll give it a try.
Posted May 03, 2010 · 04:50 UTC#146
I downloaded and installed this on my F700 yesterday. So far I am enjoying it. I have noticed two issues though -
Sometimes when the map screen loads, it is a static screen i.e. it does not move when I drive the car. When I press the Map button, the map screen becomes normal but sometimes I can't even press the map button (see below)
The second issue it that sometimes after booting up, the nav unit becomes unresponsive for a while (about 3-4 minutes)
I'll give an update in a few days - maybe it is just a temporary issue.
Posted May 03, 2010 · 12:22 UTC#147
I have already noticed your first issue, but couldn't relate it to the hack though ...
Never the second one though.
Posted May 06, 2010 · 02:50 UTC#148
I haven't seen either of these issues in last couple of days. I installed couple of mods after this issue and one of them might have fixed the problem.
I am very happy with the Nag Screen gone
Posted May 06, 2010 · 12:40 UTC#149
I tried it out this morning, looks like it works fine so far. I played with the debug screen, that is what I have been looking for, THANKS!
Does anyone know if the "Caution: Screen image may be reversed" can be removed when viewing rear camera? I imagine, the text can just be replaced with spaces once found.
Posted May 06, 2010 · 13:15 UTC#150
I just found out more details about this issue when I am driving in tight streets around my house: sometime there is a target cross on the map screen right after booted up, like the one that you press the map screen but without the cursor popup menu. If you move your car right after starting it, you might get very far and out of the last screen with the target cross, but you car is moving around the street but out of the last static screen. That is why when you press the MAP button, it does resume normal display. I notice that this morning because after moving a while around the cross, I still see my location but not centered in the map.
I think that this should be caused by this Nag Msg hack.
Page 6 of 11
