skip warning and nag for AVIC F900BT 4.001000 update
By carver · Jun 18, 2009in Hacks/Mods💬 251 posts👁️ 162,920 views
Page 5 of 11
Posted Oct 13, 2009 · 13:54 UTC#101
i make new version for testing :oops:
i just skip warning screen, but press MAP button.
i think it better, no NAG screen, and working faster, smaller delay, but you hear sound in this case.
(i set delay for 0.001 sec, for my 20 Mb masp folder - it working OK)
it for 3.010100/3.020100 version.
upd. i aslo go test :oops:
Posted Oct 13, 2009 · 14:23 UTC#102
The 2sec version is working fine, but the last version is hanging my system. No button or the screen is responding. So back to the 2sec. version.
Posted Oct 13, 2009 · 21:30 UTC#103
so, at this moment we has only two way, for skip power up navigation warning.
1) after warning - press OK button.
2) skip warning and press MAP button.
also, we has problem, for both case - we need delay with pressing,
and maps or poi size interact with this delay.
so, i share archive with two ways, and different delay for both way.
for my avic - both way with 0s delay -- forking fine,
but if solutions don't work, and you using skin or map, other from my,
try select other file, with longer delay.
so, all file inside http://www.4shared.com/file/140653868/1 ... _warn.html
p.s. fixed commonlib.dll also need for this case, in this post - just power up additional.
Posted Oct 13, 2009 · 22:48 UTC#104
Dear, friends
Some body know whi install IGO 8 on AVIC-N2?
If it's possible please let me know,
Tank's very mutch
Posted Oct 13, 2009 · 23:24 UTC#105
Dear, friends
Tank's very mutch
Try the avic n series thread
Posted Oct 14, 2009 · 03:25 UTC#106
Thnaks carver for this hard work. I thought you had gived up on it because you were gone so long. If you get everything solved then you should do a paypal account so people can donate to your cause. Maybe it will give you more inspiration to make other changes :D
Posted Oct 14, 2009 · 21:34 UTC#107
Hi, I have tried both MainMenu.exe with 0s delay, and both work well, but I keep pressing the button the MAP. Works perfectly, does not leave anything on the screen directly passed to the map view is phenomenal. With the other option screen comes a moment's notice.
I use the map of Spain.
I will continue testing it, but if no failures, this genial. Thank you very much!!
Posted Nov 11, 2009 · 10:46 UTC#108
can you tell me if this new "MainMenu.exe" I must still use the "Commonlib.dll" hacked?
Edit : it's ok, I found :wink:
Posted Nov 17, 2009 · 16:58 UTC#109
carver, can you, or someone post a link to the CORRECT commonlib.dll file to use with this?
Thanks.
Posted Dec 14, 2009 · 18:28 UTC#110
i update first topic post for 3.020200 version, UC or EW.
Posted Dec 14, 2009 · 22:38 UTC#111
also i add SystemSetting.exe for show Pioneer DEBUG MODE in System Information tabs.
Posted Dec 15, 2009 · 21:48 UTC#112
Carver thank you for the amount of time you invested into this mod.
Like everyone else in this forum I am looking to get my unit to the best possible tune and your mode is one of the items that is great to have to bring Avic unit to its best.
I currently have 3.01 and IDT mode plus green theme. Should I have any issues running your files to eliminate navi warnings?
Just to make sure I understand the sequence of install:
1. Downloaded latests thee files from the first page: CoomonLib.dll; MainMenu.exe; SystemSetting.exe.
2. Copy all three files from SD card (while I am in test mode) to My Flash Disk\APL.
Is that right? Do I need to run the .exe files or simply copy and paste them in the APL folder?
Thanks again.
Posted Dec 16, 2009 · 23:42 UTC#113
yes, just copy/rewrite to APL folder, but this files from 3.0202 version.
also, if mainmenu.exe don't help for powerup warning, you can back original mainmenu.exe.
Posted Dec 18, 2009 · 19:55 UTC#114
Hi Carver, I was when I used your version 3010100 "mainmenu.exe_0sec. It worked really well on my F910BTeu.
I saw that you ave 3020200_2sec releases a version, I found this rather long time, can you release a version 1_sec or 0_sec? or else tell me the offsets to edit with my hex editor?
thank's for your good job :wink:
Posted Dec 19, 2009 · 12:24 UTC#115
yes.
i also used 0sec version, but few guys write about problem with some used iGo skin and additional software, so i set two seconds.
mainmenu.exe fix works very easy, when avic select startup screen (TopMenu, iGo/Warning, or Passwors)
i add code to start new my thread, only if MAP-warning selected
and in my thread, i just wait two sec and press MAP button.
.text:0005A710             press_map
.text:0005A710 00 40 2D E9                 STMFD   SP!, {LR}
.text:0005A714 28 00 9F E5                 LDR     R0, =0x7D0      ; dwMilliseconds
.text:0005A718 11 31 FF EB                 BL      Sleep
.text:0005A71C 28 40 9F E5                 LDR     R4, =HMILib_SendMessage
.text:0005A720 20 30 9F E5                 LDR     R3, =0xC31000
.text:0005A724 01 20 A0 E3                 MOV     R2, #1
.text:0005A728 03 1C A0 E3+                MOV     R1, 0x312
.text:0005A730 01 00 A0 E3                 MOV     R0, #1
.text:0005A734 0F E0 A0 E1                 MOV     LR, PC
.text:0005A738 00 F0 94 E5                 LDR     PC, [R4]
.text:0005A73C 01 00 A0 E3                 MOV     R0, #1
.text:0005A740 00 80 BD E8                 LDMFD   SP!, {PC}
.text:0005A740             ; End of function press_map
.text:0005A740             ; ---------------------------------------------------------------------------
.text:0005A744             ; DWORD dwMilliseconds
.text:0005A744 D0 07 00 00 dwMilliseconds  DCD 0x7D0
.text:0005A748 00 10 C3 00 dword_5A748     DCD 0xC31000
.text:0005A74C B8 B2 06 00 off_5A74C       DCD HMILib_SendMessage
delay here: .text:0005A744 D0 07 00 00 dwMilliseconds DCD 0x7D0
0x7D0 = 2000 Ms = 2 Sec.
so, like for 1 ms delay, in WinHex - you can change at file offset 0x49B44 (not 0x0005A744),
from D0 07 00 00 to 01 00 00 00.
Posted Dec 19, 2009 · 16:36 UTC#116
Carver thank you, it's nice of you to tell me the values to change.
I tested your version 2s 3020200 and frankly the execution is fast, I'll test the version 1s (as you say, 0s version may be just too short)
Posted Dec 19, 2009 · 19:42 UTC#117
what hex editor program are you using?
Thanx,
Bud
Posted Dec 19, 2009 · 21:06 UTC#118
Thanx,
Bud
He mentioned it at the end of his last post: WinHex
Posted Dec 20, 2009 · 18:26 UTC#119
O
Posted Dec 24, 2009 · 07:35 UTC#120
I got this working just fine! Thank you Carver!!!
One question, is it hard to make an update to your code to skip warning screen when you want to switch to AV1 or AV2?
Posted Dec 26, 2009 · 02:59 UTC#121
thank you for all the work that was put into this. i am having a hard time understanding though if i can make this work (probably because of language barriers between us). i have the hacked 3.0 (not 3.1) installed on my 700 with idt's 2nd, latest modifications. will this work?
Posted Jan 10, 2010 · 09:56 UTC#122
Can someone please tell me if this is stable and if it has any issues at all? thanks
Posted Jan 11, 2010 · 16:57 UTC#123
It is stable for me.
Posted Jan 11, 2010 · 19:21 UTC#124
cool, thanks for the reply. How do I install it?
Posted Jan 14, 2010 · 17:27 UTC#125
I will confirm it is working great as well. I am new to modding and this one was great to implement.
Page 5 of 11
