Here is a mirror for the 3.01 file:
I put the three file in my APL folder. No Nag screens but it automaticaly puts me to the AV screen and it seems like it takes a really long time to load. Am I missing something?
It's true, only if tou have usb flash drive connected to usb port with size more than 16 gigs (with full of music). I have SD card (16 gigs) and usb flash (32 gigs) and i see the difference in time of load...
By the way, I have sony wire remote control connected to my device and if I switch between sources using remote control (when the device is in navi screen) it takes more longer time than if I do it from the touch screen. Sometimes it's freeze for a long time...
Is this new CommonLib.dll the same as carvers, or does it remove the navi warning message on startup (when the unit was turned off on navi screen)?
Also, if I only need the navi message gone, will I just need to copy over the CommonLib.dll or will i need the other files also?
It's the same file with repares of some bytes. Warning screen not shows. Other files are for deleting warning messages in rear camera source.
Ok, so I tested this new CommonLib.dll on my unit...
On the first bootup I immediately realized what user bryvale was talking about. If the unit is left on the navigation screen and shut off, on bootup you will not get the nag screen but instead the unit will boot into the AV source screen which was last playing. So technically you do not get a nag screen, but you also do not get the navigation screen. This doesn't save me any button presses because now I must press the Map button to get to the map instead of pressing the Ok button on the navigation warning screen.
After restarting the unit, I also noticed that the unit became unstable. The unit becamse very confused going to a black screen, then going to some settings screen. When I finally got to the map screen it was in night mode (it's daytime when I did this all) and wouldn't change to day, then when I pressed on the map screen it too me to the AV source screen which was currently playing.
This new CommonLib.dll file is very unstable and does not produce the desired outcome, which is removing the navi warning screen on startup when the unit was left on the navigation screen at shutdown.
Which is why I am waiting for Carver to get his working again.
I've only had my unit restart on me once, I realized if I push MAP right after it boots up it seems to crash but if I wait a couple of seconds after it loads it has no problems.
Added the same for F500
Did you fix the other one 'cause it is not working.
upd 14.08.2009 update for 3.010100 version, UC or EW.update from 13.07.2009 with power-up fix also, but at this moment, only for testing📎 avic_x910_v301_no_warning1-02sec.rar
sorry, but at this moment, olly for testing. becouse i only used two times.
Thanks carver, hope yours is stable unlike the other guys files.
Carver, you are now my favorite person. You are amazing and you have made my unit complete. I can't even tell you how awesome this is.
I loaded it on my unit earlier today and have had no problems yet, but will definitely post here if anything comes up.
Once again, THANK YOU!
works great carver. you 'da man.
Carver:
I've been testing the new software since you uploaded it and I have run into a small problem. I notice that when on the map screen, the Menu, Map and Joystick (Up/Down/Left/Right) are all inoperable. I am unable to control the music unless on the AV source screen and I am unable to go to the main menu screen at all.
That probably wont be enough for me to switch out the files yet because I love not having the warning messages.
Carver:
Do you have any other mods done? What exact model/version/region unit do you have?
Mine work great (left/right doing audio controls and up/down for zooming) when I'm on the map screen.
Do you have any map modifications done?
Thanks,
Ben
I have a US F900BT with 3.01 (the X-series version)...
I have the hard bypass, I have modified my DATA.ZIP file (navigatemap.ui, navigatemap800_480.ui, start.ui) to hide the on-screen buttons, clock, and compass.
All of the buttons function normally with the original MainMenu.exe and CommonLib.dll.
Ok, after a little more testing.....
When the unit boots onto the map screen, the Menu, Map and Joystick (Up/Down/Left/Right) are all inoperable. When I go to the AV source screen the Menu and Map buttons are still inoperable but the Left/Right buttons work, so I am able to change songs.
When the unit boots onto the AV source screen, all buttons function normally. If I go to the map screen all buttons still function normally. Even when I switch back and forth between the main menu, AV source screen and map screen, all buttons retain functionality.
So the problem seems to be only when the unit boots directly onto the map screen.
Did you modify the mainmenu.exe (reason I ask is since you stated it works w/ original mainmenu and common lib)?
EDIT: Disregard. I am not running the new version w/ the mainmenu.exe hack. Though all my buttons work.
Thanks,
Ben
No, I copied the MainMenu.exe from Carvers zip file to my unit.
If I only want to eliminate the navigation warning message, do I even need that new MainMenu.exe?
I didn't realize he posted a new version that is to eliminate the startup warning. I am just using the one w/ the dll - (though it still shows warning when booting directly to the map...this is what the other update was to fix)
So does the elimination of the nag screen work or not work 100% yet? This thread is confusing. ![]()
It does just don't use the other guys files. Use Carver's files. Don't know what Pwnin O'brien is talking about as I have IDT's mod on the X series 3.01 update and I have full functionality.
touche, are you using carvers latest release? Have you replaced both your CommonLib.dll and MainMenu.exe? I don't really have many mods on my unit and the ones I do only deal with the DATA.zip files, I don't understand why I wouldn't have 100% functionality.
I have the same problem you have Pwnin O'brien......I have the 6_mod_combine hack on mine...
I take what I said back. I spoke too soon. On my way to six flags today the unit locked up on the map and was acting funny. I had no way to get to the AV part as the small button on the bottom right disappeared and the menu button no longer worked. I reset the unit and then it was working fine. I will have to try using it some more to say for sure that I have no problems. Sorry to doubt you and discount your problems.
