skip warning and nag for AVIC F900BT 4.001000 update
By carver · Jun 18, 2009in Hacks/Mods💬 251 posts👁️ 162,920 views
Page 4 of 11
Posted Aug 17, 2009 · 19:29 UTC#76
Hi,
I am on the F700 with firmware 2.x installed. Is anyone on this FW tried it? Where can I get the file? Does it use both the .dll and .exe? Can someone post the files, thank you.
Posted Aug 17, 2009 · 21:23 UTC#77
Don't know what Pwnin O'brien is talking about as I have IDT's mod on the X series 3.01 update and I have full functionality.
touche, are you using carvers latest release? Have you replaced both your CommonLib.dll and MainMenu.exe? I don't really have many mods on my unit and the ones I do only deal with the DATA.zip files, I don't understand why I wouldn't have 100% functionality.
I have played around with my unit a bit and have found that leaving the unit on the map will lock up the front panel buttons as well as the problems I described before. If you reset the unit you can access all parts of the unit. If the unit is shut down in a menu like the AV section or main menu you can go to the map and all buttons work.
Posted Aug 20, 2009 · 03:20 UTC#78
I have no clue if my current problem is related to this mod but has anyone had a problem with the touch screen not responding after putting this mod in? Front panel buttons work but my unit is also much slower in loading the menu or map. I got the touchscreen to work earlier today but it stopped working again. Could it be a defective unit?
Posted Aug 20, 2009 · 03:39 UTC#79
I decided to pull off the new CommonLib.dll and MainMenu.exe and replace the old ones. Back to the bootup warning screen. :cry:
Posted Aug 22, 2009 · 21:27 UTC#80
can someone post me the commonlib.dll and the mainmenu.exe for the 2.x firmware, thank you.
Posted Aug 23, 2009 · 15:14 UTC#81
Did you guys ever find a way to remove the nav warning? I use my F500bt strictly for navigation, and every time I startup the system it displays the warning. I would like for it to start up straight to navigation with no warnings. Any help would be appreciated...
Posted Aug 26, 2009 · 02:57 UTC#82
I have upgraded to Version 3.01 and downloaded the new CommonLib.dll file from 6/2/2009, is this the updated CommonLib file for version 3.01 or is there a new one that I can't seem to find.
If there is a new file, please send me link.
Thanks Carver for all your help, Upgrade to Ver 3 as per your direction went extremely smooth.
Tx
Posted Aug 29, 2009 · 23:53 UTC#83
Carver,
Have you had any success with that bootup warning screen yet? Just gettin a little anxious. :P
Thanks again for all your hard work!!!
Posted Sep 09, 2009 · 15:24 UTC#84
Any progress? :mrgreen:
Posted Sep 15, 2009 · 18:37 UTC#85
If I'm reading this correctly, 3.01 is still buggy and the hacks to date won't work with it, yes?
Posted Sep 15, 2009 · 23:12 UTC#86
Still in progress.. :mrgreen:
Posted Sep 20, 2009 · 18:24 UTC#87
If we can't remove the warning screen for now can we at least make the button much much bigger so at least it will be easier to find and press while driving, because I'm always moving by the time that screen pops up.
Posted Sep 24, 2009 · 02:28 UTC#88
I used this mod on F900bt FW 3.010100 and I lost sound on iPhone incoming of outgoing no sound. I returned to my back up files and added video.exe and av.exe back and I got my sound back.
Any help?
I added commonlib.dll and I still get navigator warning back. Play DVD while driving warning is there obviously.
Posted Sep 25, 2009 · 16:39 UTC#89
I have just learned to live with the nag screen. Just one more screen tap to contend with and is not near as much of an issue with me as losing functionality :x
Someday this will get resolved.
Just stay tuned and keep your system stock for now.
Bud
Posted Oct 08, 2009 · 17:58 UTC#90
any progress?
Posted Oct 11, 2009 · 23:06 UTC#91
any progress?
upd 12.10.2009, just comments
mainmenu.exe v3.1 use this code for make PowerUp warning
.text:0002FF0C             loc_2FF0C
.text:0002FF0C B0 30 9F E5                 LDR     R3, =_Instance_AL_MenuControl__SAPAV1_XZ
.text:0002FF10 0F E0 A0 E1                 MOV     LR, PC
.text:0002FF14 00 F0 93 E5                 LDR     PC, [R3]
.text:0002FF18 00 30 90 E5                 LDR     R3, [R0]
.text:0002FF1C AC 20 9F E5                 LDR     R2, =186A7
.text:0002FF20 01 10 A0 E3                 MOV     R1, #1
.text:0002FF24 0F E0 A0 E1                 MOV     LR, PC
.text:0002FF28 04 F0 93 E5                 LDR     PC, [R3,#4] ;ForwardScreenChange(UIN_WIN_PLCaution)
so, i try write few additional bytes, for automaticaly press OK.
.text:0002FF2C DB A9 00 EA                 B       sub_5A6A0
.text:0005A6A0             sub_5A6A0
.text:0005A6A0 0F 00 2D E9                 STMFD   SP!, {R0-R3}
.text:0005A6A4 08 D0 4D E2                 SUB     SP, SP, #8
.text:0005A6A8 24 20 9F E5                 LDR     R2, =sub_5A6E0
.text:0005A6AC 00 30 A0 E3                 MOV     R3, #0
.text:0005A6B0 00 10 A0 E3                 MOV     R1, #0
.text:0005A6B4 00 00 A0 E3                 MOV     R0, #0
.text:0005A6B8 04 30 8D E5                 STR     R3, [sP,#0x18+var_14]
.text:0005A6BC 00 30 8D E5                 STR     R3, [sP,#0x18+var_18]
.text:0005A6C0 CF 30 FF EB                 BL      CreateThread
.text:0005A6C4 AE 30 FF EB                 BL      CloseHandle
.text:0005A6C8 08 D0 8D E2                 ADD     SP, SP, #8
.text:0005A6CC 0F 00 BD E8                 LDMFD   SP!, {R0-R3}
.text:0005A6D0 3A 56 FF EA                 B       nullsub_3
.text:0005A6D4 E0 A6 05 00 off_5A6D4       DCD sub_5A6E0
.text:0005A6E0             sub_5A6E0
.text:0005A6E0 00 40 2D E9                 STMFD   SP!, {LR}
.text:0005A6E4 44 00 9F E5                 LDR     R0, =0x7D0
.text:0005A6E8 0D 31 FF EB                 BL      Sleep
.text:0005A6EC 40 40 9F E5                 LDR     R4, =HMILib_SendMessage
.text:0005A6F0 00 30 A0 E3                 MOV     R3, #0
.text:0005A6F4 00 20 A0 E3                 MOV     R2, #0
.text:0005A6F8 0F 10 A0 E3                 MOV     R1, #0xF
.text:0005A6FC 01 00 A0 E3                 MOV     R0, #1
.text:0005A700 0F E0 A0 E1                 MOV     LR, PC
.text:0005A704 00 F0 94 E5                 LDR     PC, [R4]
.text:0005A708 24 40 9F E5                 LDR     R4, =HMILib_SendMessage
.text:0005A70C 24 30 9F E5                 LDR     R3, =0x1900190
.text:0005A710 01 20 A0 E3                 MOV     R2, #1
.text:0005A714 02 1C A0 E3+                MOVL    R1, 0x201
.text:0005A71C 01 00 A0 E3                 MOV     R0, #1
.text:0005A720 0F E0 A0 E1                 MOV     LR, PC
.text:0005A724 00 F0 94 E5                 LDR     PC, [R4]
.text:0005A728 01 00 A0 E3                 MOV     R0, #1
.text:0005A72C 00 80 BD E8                 LDMFD   SP!, {PC}
.text:0005A730 D0 07 00 00 dword_5A730     DCD 0x7D0
.text:0005A734 B8 B2 06 00 off_5A734       DCD HMILib_SendMessage
.text:0005A738 90 01 90 01 dword_5A738     DCD 0x1900190
but i found other problem, "maps and delay".
in this case - i wait two seconds for press OK.
for my locations(my maps just 20MB) - 0 seconds - also good waiting time,
but for my frends - 2 seconds waiting - so small time, and solutions don't working.
so, need additional testing. for US maps size.
i prepare archive with mainmenu with different delay, from 2 to 15 seconds,
this time need for load maps.
if you can find lover delay from archive -
in good case you see maps,
in bad case you see TopMenu with dest/phone/av icons.
so, write you seconds, and we add two seconds and post good file in first post.
archive for testing:
/// link removed
no need test all, just start for 02s seconds, if ok - no need additional step.
if wrong, try like 05s folder ....
UPD. looking new version
viewtopic.php?p=193564#p193564
Posted Oct 11, 2009 · 23:41 UTC#92
Carver, you're awesome. I'm glad to see you're still trying to crack this really annoying warning message. I will try out the new files (starting at 2 seconds) and let you know what works best.
Posted Oct 12, 2009 · 18:06 UTC#93
Carver:
I tested the first MainMenu file (2 seconds) and it worked flawlessly for me. I had absolutely no lag and it loaded the map screen without any issues.
Thanks!!!
Posted Oct 12, 2009 · 19:11 UTC#94
Pwnin, where are you located? In the US or elsewhere?
Posted Oct 12, 2009 · 19:31 UTC#95
I tried tow versions...2-sec and 5-sec..both worked fine and all other functions work as normal!
Now if we can get you to look at the Trip Computer/Track Logs issue
http://www.avic411.com/forum/viewtopic.php?f=34&t=27350we would be indebted to you.
Posted Oct 12, 2009 · 20:09 UTC#96
I'm in the US
Posted Oct 12, 2009 · 20:27 UTC#97
I just tried the 2 sec version and it seems to work fine for me. :mrgreen:
Posted Oct 12, 2009 · 22:34 UTC#98
I copied the 2 sec MainMenu.exe from carver's dl to my unit but nothing happened. Just wanted to make sure I put it in the right place I put it in the APL folder is that all I had to do or am I missing something?
Posted Oct 13, 2009 · 05:03 UTC#99
Ok, well my unit just crashed. I don't know if this was mod was the cause though. The screen just hard locked and would not respond to button presses but my Ipod kept on playing and I could control volume.
------------------ Crash Log Begin -------------------
Current System time: "2009-10-13 04:22:32"
Build: 8.3.2.90139 Built @ May 15 2009 - 07:58:15
Memory Stats:
FreeMemory: 102 MB, 256 KB, 0 B
TotalUseableMemory: 122 MB, 4 KB, 0 B
MaxMemory: 128 MB, 0 KB, 0 B
ReservedMemory: 3 MB, 0 KB, 0 B
ActualCacheSize: 1 MB, 77 KB, 877 B
GarbageSize: 0 MB, 0 KB, 0 B
Process Name PID BaseAddr ParentPID PrioBase
ezrider 0xd960d666 0x1a000000 0x00000000 0x00000003
Modules Name BaseAddr BaseSize
synth_83swf11.dll 0x01300000 0x00021000
domain_mngr.dll 0x01330000 0x00010000
edct.dll 0x013a0000 0x00014000
xlit_1252.dll 0x013c0000 0x00009000
vf_samantha_red.dll 0x013f0000 0x00036000
g2p_enu.dll 0x01430000 0x000fc000
stdpp_enu.dll 0x01530000 0x0003c000
rettt.dll 0x01570000 0x00014000
xcoder.dll 0x01590000 0x0000a000
dcteg.dll 0x015a0000 0x0000a000
ttsengine.dll 0x015b0000 0x0001e000
combrk.dll 0x01b40000 0x0000d000
comrsrc.dll 0x01b50000 0x00012000
rssoloapi.dll 0x01b70000 0x00016000
oleaut32.dll 0x03960000 0x0002f000
toolhelp.dll 0x03fe0000 0x00005000
ole32.dll 0x03990000 0x0002e000
coredll.dll 0x02b80000 0x0008d000
Threads TID BasePrio DeltaPrio
0xd7c89fd6 250 0
0xf7ddd962 251 0
0x77ddd986 251 0
0x77de2fb6 251 0
0x77de8926 251 0
0x77de8242 251 0
0x77de8e72 251 0
0x77de8f8e 251 0
0x77de8fc2 251 0
0x77e1ab52 251 0
0x77e1a6ae 251 0
0x77e1a59a 251 0
0x77e1a416 251 0
0x77e1a2a2 251 0
0x38f36fce 252 1
0xdb298642 251 0
WinCE CallStack snapshot (function names unknown - map file \My Flash Disk\APL\..\APL2\iGo\ezrider.map not found):
0x1a4adb9c (A)
0x1a4adab8 (A)
0x1a4acf08 (A)
0x1a4ad004 (A)
0x1a095c30 (A)
0x1a095ffc (A)
0x1a0955d8 (A)
0x1a032978 (A)
0x1a032814 (A)
0x1a3def34 (A)
0x1a450f34 (A)
0x1a369b18 (A)
0x1a03ad44 (A)
0x02b9df80 (A)
Global status:
bInFocus: 0
bMouseDown: 0
bInLogic: 0
bInRender: 0
CurrentState[128]: st_NavigateMap
GPS Pos: (-84.263953,30.474598)
Camera: pos:(-84.262572,30.476148) rot:2481 persp:0 zoom:170.000000 eng=0)
State queue:
0. st_NavigateMap
Waypoints:
Maps:
map\Basemap.fbl ver:0x02bd time:0x48a189b2
map\Basemap.fbl ver:0x02bd time:0x48a189a8
map\Basemap.fbl ver:0x02bd time:0x48a189a0
map\Basemap.fbl ver:0x02bd time:0x48a189a2
map\Basemap.fbl ver:0x02bd time:0x48a189a1
map\Basemap.fbl ver:0x02bd time:0x48a189b3
map\Basemap.fbl ver:0x02bd time:0x48a18995
map\Basemap.fbl ver:0x02bd time:0x48a189b8
map\Basemap.fbl ver:0x02bd time:0x48a18994
map\Basemap.fbl ver:0x02bd time:0x48a18997
map\Basemap.fbl ver:0x02bd time:0x48a1899f
map\Basemap.fbl ver:0x02bd time:0x48a189ac
map\Basemap.fbl ver:0x02bd time:0x48a189ab
map\Basemap.fbl ver:0x02bd time:0x48a189b1
map\Basemap.fbl ver:0x02bd time:0x48a18998
map\Basemap.fbl ver:0x02bd time:0x48a1899e
map\Basemap.fbl ver:0x02bd time:0x48a189a7
map\Basemap.fbl ver:0x02bd time:0x48a189b4
map\Basemap.fbl ver:0x02bd time:0x48a189b9
map\Basemap.fbl ver:0x02bd time:0x48a189af
map\Basemap.fbl ver:0x02bd time:0x48a18996
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a685761
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a68575e
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a68576e
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a68576a
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a68575f
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a685768
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a68576b
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a685767
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a685760
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a685765
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a685769
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a68575b
map\Canada83TA_2009.06_090723.fbl ver:0x02d0 time:0x4a68575c
map\USA_Alabama83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e1b
map\USA_Alaska83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e1a
map\USA_Arizona83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e1c
map\USA_Arkansas83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e1b
map\USA_California83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e1d
map\USA_California83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e22
map\USA_California83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e25
map\USA_California83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e21
map\USA_California83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e1e
map\USA_California83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e23
map\USA_Colorado83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e26
map\USA_Connecticut83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e26
map\USA_Delaware83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e27
map\USA_District_Of_Columbia83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e69
map\USA_Florida.fbl ver:0x02d0 time:0x4a310a6b
map\USA_Florida.fbl ver:0x02d0 time:0x4a310a72
map\USA_Georgia83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e2e
map\USA_Georgia83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e2f
map\USA_Hawaii83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e30
map\USA_Idaho83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e3c
map\USA_Illinois83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e31
map\USA_Illinois83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e32
map\USA_Indiana83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e3d
map\USA_Iowa83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e3b
map\USA_Kansas83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e3e
map\USA_Kentucky83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e3f
map\USA_Louisiana83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e42
map\USA_Maine83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e4c
map\USA_Maryland83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e49
map\USA_Massachusetts83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e48
map\USA_Michigan83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e43
map\USA_Michigan83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e44
map\USA_Minnesota83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e4d
map\USA_Mississippi83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e4e
map\USA_Missouri83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e46
map\USA_Missouri83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e47
map\USA_Montana83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e50
map\USA_Nebraska83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e57
map\USA_Nevada83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e5e
map\USA_New_Hampshire83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e5a
map\USA_New_Jersey83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e5d
map\USA_New_Mexico83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e5d
map\USA_New_York83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e51
map\USA_New_York83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e52
map\USA_North_Carolina83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e53
map\USA_North_Dakota83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e56
map\USA_Ohio83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e5f
map\USA_Ohio83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e62
map\USA_Oklahoma83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e63
map\USA_Oregon83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e63
map\USA_Pennsylvania83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e64
map\USA_Pennsylvania83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e66
map\USA_Rhode_Island83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e68
map\USA_South_Carolina83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e6c
map\USA_South_Dakota83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e6d
map\USA_Tennessee83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e76
map\USA_Texas83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e70
map\USA_Texas83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e72
map\USA_Texas83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e71
map\USA_Texas83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e73
map\USA_Utah83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e77
map\USA_Vermont83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e7b
map\USA_Virgin_Islands83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e7b
map\USA_Virginia83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e78
map\USA_Washington83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e7c
map\USA_Waters83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e19
map\USA_Waters83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e18
map\USA_West_Virginia83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e84
map\USA_Wisconsin83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e7d
map\USA_Wyoming83TA_2009.06_090710.fbl ver:0x02d0 time:0x4a574e85
------------------- Crash Log End --------------------
Posted Oct 13, 2009 · 07:44 UTC#100
Mine worked fine :) thank you.
Page 4 of 11
