New european version 3.010100 available for download
By krisvw · Jul 07, 2009in Hacks/Mods💬 99 posts👁️ 18,788 views
Page 4 of 4
Posted Jul 14, 2009 · 14:17 UTC#76
It really is like a whole new unit with the update. Still a little laggy right at bootup, but once booted it is very speedy.
Posted Jul 14, 2009 · 14:32 UTC#77
@brandon7gr
did you install something special for steering wheel function?
No. I didn't install anything else. Before the update ... it didn't work ... and after the update .. it works! (i am always talking about changing the preset stations from the left up button of the wheel)
As for the speed ... i think it is really in a good stage. Since it doesn't bother me ... i think it is quick enough.
Posted Jul 14, 2009 · 16:39 UTC#79
since i hate servers like rapid what ever share full of scripts and ads here http://www.bit4net.com/files/avic/newstuff/ on my own server paul his stuff
Great work. Hope to find ezrider2009 hacked soon!!
Posted Jul 15, 2009 · 15:54 UTC#80
Why is the licence file so importent for you?
Because it identifies me, and I don't want half of Europe driving around with my license file.
Are you willing to share your [windows/office/whatever] key on a public site?
Paul
does that really? i don't think so. the license file is only to get it working and is licensed to pioneer and not to your radio head...
Posted Jul 15, 2009 · 15:57 UTC#81
I updated my 900bt to 3.00000 and then to 3.00500 at the Pioneer head office and can now use 910bt FW. The pioneer sales rep told me to download 3.010100 and there was no problem installing it. So there must be some kind of test that checks if the unit already has 3.0, or programed to report as 910BT.
hi akke,
can you upload your full image for us?
or pm me if you need storage space.
thx,
bt
Posted Jul 15, 2009 · 16:08 UTC#82
I have uploaded my F700BT with the 3.01010O, it's a new unit,! speed bootup, the control panel ok during the bootup, quick reactivity with the boutons reponses, speed IGO display, change presets with a button in the left side of the wheel..... a qood update .
Posted Jul 16, 2009 · 07:33 UTC#83
Hello, i have a F900BT and i'm interrested by this mod. I'm not very easy with english, somebody can translate the method for install this in french, please
Thank and sorry for english
Posted Jul 16, 2009 · 16:42 UTC#84
bonjour,
Pour le mise a jour, tu doit telecharger la nouvelle image de windows ici WINCEIMG.zip http://www.bit4net.com/files/avic/newstuff/, decompresse le tous sur une carte SD.
ensuite tu dois passer en mode testmode ton autoradio avec la procedure ici
et la mettre sur ta machine : avec la procedure suivante : http://avic411.com/forum/viewtopic.php?f=33&t=25424&p=172862&hilit=service+menu#p172862
resumé : passage en testmode, debrance tous SD, USB de ton poste, demarre le poste... au logo, appuyer sur menu, map, eject en meme temps et le bouton reset, relâche le reset ... attends le bip dans les ancientes... relache juste la touche eject (appuis toujous sur les touche menu et map).... tu arrive sur un ecran blue, relache tous,maintenant entre la combinaison de touche pour acceder au menu suivante : haut, haut, bas, menu, gauche, droite .
tu arrive au menu : (click c'est pousser sur la molette)
tu click de memoire sur update, puis update wince par SD.... ( tu en a 2 tu ne prends pas avec la format surtout) tu insert la carte SD et tu click... attends 2 minutes max (tu as des info a l'ecran) et le system te propose de redemarrer (enleve la SD et eteint/rallume de poste)
ensuite tu dois telecharger et decompresser toujours sur un SD le fichier : Testmode_v23.zip qui te permet de booter sous windows .
sur une autre SD ou USB telecharge et decompresse le fichier : APL3000300EW.zip ...
mets la SD avec Testmodev23 dans le lecteur SD, demarre le poste, tu arrive sous windows... dans my flash disque tu a un repertoire APL, tu le renomme en APL.bak ou autre, puis copie a cette endroit le repertoire APL venant de l'autre SD ou USB (APL3000300EW).
Je ne pense pas que tu sois obliger de mettre le ezrider si tu n'utilise pas d'autre map que celle de l'europe pour IGO.
voila j'espere que c'est claire.
Posted Jul 16, 2009 · 19:04 UTC#85
Merci beaucoup ( en francais) Thank you, all is ok :D
Posted Jul 17, 2009 · 15:03 UTC#86
So.. sorry for me being thick but are you guys using the F910 V3 firmware on the F900? If so did you just update the F900 as normal with the V3 on a SD card etc..?
Or.. do you need to get into testmode to do it?
Please can someone do an idiots guide to this please? I'm happy doing the testmode stuff but need to know what i'm copying!
Andy
Posted Jul 17, 2009 · 15:12 UTC#87
Just read read and read the forum. Dont be lazy and look around the hints are there.....
Andy
Posted Jul 17, 2009 · 15:19 UTC#88
Oh do me a favour, it's idiots like you that cause people to brick their units.
If you cant be arsed to help someone else then dont reply here.
Posted Jul 17, 2009 · 15:21 UTC#89
HEY...... the ass is up to you......
You have to learn and read to get things done..... That a standard life lesson.....
I am not that bad......I will give you a hint: search on author m moogle
Posted Jul 17, 2009 · 15:40 UTC#90
I dont wanna start a flamewar here but when I read this I guess its people like YOU who brick their units.
Really, if someone isnt interested in reading up its far better to just wait for the official updates. They are idiot-proof.
-C
Posted Jul 17, 2009 · 16:15 UTC#91
thanks :wink:
Posted Jul 17, 2009 · 19:21 UTC#92
for me the same i read everiting but the problem is that my englis is not so good so it is diffecult to do
i first what to do the wince update but it wont working wen i put my f900 on than pres map.eject menu and reset (small pen) then you must here e piep on speakers but i dont what do i wrong?.
can sombody help?. it s difficult
Posted Jul 17, 2009 · 19:33 UTC#93
I didnt hear anything either.
The important part is you should see a blue screen that say "press reset". Here you enter the pass-combination. (you see a * for each button you press)
If you do it correctly you get into the service menu and there you can flash the winCE image.
-C
Posted Jul 17, 2009 · 20:09 UTC#94
Sorry I was rude. Bad time for me to have posted. Thanks for the hint, it has told me everything I needed to know :)
BTW for any UK'ers in here, I phoned Pioneer Uk earlier and they were aware of the update and said it would be out soon, cost in the uk..... £200!!!!!!!!!!!! LOL
Posted Jul 17, 2009 · 20:48 UTC#95
so than my f900 will have cost me over £1000.00 :!:
even more reason to create our own hack.
Posted Jul 18, 2009 · 12:10 UTC#96
OK heres what happened to me today.
So first off I backed up my F900.
Updated with the latest V3 WinCE, all went well.
Then as per instructions from here, I booted using testmode 2.3, worked fine and copied the new APC folder across.
Result - stuck on Startup in Progress. I could access the ipod/Fm etc.. but once I pressed Map, I couldn't ok the saftey screen and then it wouldnt go back to the main menu!
So i've not reflashed back to the original winCE and put my backup back into it.
All is working as it should now. So where did I go wrong? This is UK F900 btw, which is probably the cause of the problems?
Any ideas?
Posted Jul 18, 2009 · 12:39 UTC#97
Any ideas?
You need to replace yor easyrider file with the 2.007 hacked easy rider, same thing happened to me and others, hacked easy rider fixes the problem you described..
Posted Jul 18, 2009 · 16:43 UTC#98
Where can I get the easyrider hacked file?
Page 4 of 4
