Complete 3.0 Install Guide
By Retell · Jul 18, 2009in Hacks/Mods💬 968 posts👁️ 380,894 views
Page 6 of 39
Posted Jul 21, 2009 · 03:00 UTC#126
My tip for everyone is use winrar not winzip! :evil:
I had problems unzipping on my MacBook Pro. I would do the update and get the perpetual system loading message. Unzipped on the Windows side and it worked fine.
Posted Jul 21, 2009 · 05:09 UTC#127
hey the torrent wont work for me the link just opens a page full of symbols
Posted Jul 21, 2009 · 05:14 UTC#128
After walking through all the steps, everything looks to be ok but the system constantly reboots every 5 minutes. I hear the new button sounds, and can check the system info and it shows I am running 3.0 firmware. But the "System Startup" message never goes away, and the whole unit reboots after 5 minutes.
I am thinking it is the WinCE update. When booting into testmode, and checking the WinCE version, it shows that it is 5.0. I thought I read here (somewhere??) that it should be 6.x. I grabbed all the files from page one in this thread, and didn't get any errors at any stage. I am running a F900BT. Any help would be much appriciated!
I had 2.0 firmware and recently update it to 2.006. The wince on it was 6.1.70 and was updated to 6.1.7.2. See the attached picture.
Posted Jul 21, 2009 · 06:19 UTC#129
Just finished updating an F90BT. Instructions worked like a charm.
Posted Jul 21, 2009 · 08:31 UTC#130
Ok i dit the update and thanks going ok finaly the system reset and starts up but there is standing SYSTEM STARTUP IN PROGRESS PLEAS WAIT and then whit one min. it is reseting and starts up whit te same
is there somting rong?. i have F900bt EU (From holland)
als there is no dutch on it
pleas can sombody help?.
Map version 02.000300
version 3.000300
is now on it i can see that
Nobody this problem?. if a want back to V 2.07 i put back my backup of my flash disk is that oke?.
or must i downgreat win ce? olso
Posted Jul 21, 2009 · 09:40 UTC#131
version 3.000300
Wat heb je precies gedaan Bas?
Heb je een amerikaanse backup (met amerikaanse kaarten) op je nederlandse systeem gezet?
Hier heb je dus helemaal niets aan, en het lijkt ook niet te werken.
Heb je een backup gemaakt? Zo ja, => terugzetten, zo nee, backup(eu versie) ophalen van www.turboss.com en terugzetten.
Dan alleen de wince en apl folder installeren uit de 3.0 update van de x-serie en een gehackte ezrider 2.007 gebruiken, anders werkt ook dit niet(heb ik me laten vertellen).
Posted Jul 21, 2009 · 09:51 UTC#132
version 3.000300
Heb je een backup gemaakt? Zo ja, => terugzetten, zo nee, backup(eu versie) ophalen van http://www.turboss.com en terugzetten.
Hey!
pff in het nederlands das handig me engels is niet zogoed! ja stom wou het toch proberen maar gaat niet helemaal goed! dus wil nu weer alles terug zetten. ik had in het begin een kopie gemaalkt van me flash disk is dat genoeg?.
ik zal voor alle zekerheid wel ff die backup downloaden ook! thanks man!
heb je zelf veel gehackt?. kan ikje niet ff mailen of msn?.
Posted Jul 21, 2009 · 10:01 UTC#133
Just send me a pm if you have some more questions.
But am no real expert to, i just try to read the forum carefully and only try something if i am sure i understand what to do!
Posted Jul 21, 2009 · 13:48 UTC#134
When it says copy the 2 WinCeimg files to a sd, is this both win images from the X910bt and the 3.0 instal files? Or just the 3.0 install folder?
Posted Jul 21, 2009 · 13:57 UTC#135
Just the two files from the 3.0 install folder. You should be able to copy everything to the disk at once, but those two in the root are what you need for the first section of the instructions.
Posted Jul 21, 2009 · 14:17 UTC#136
Somebody may want to check my sanity on this, but I stripped down the previous set of instructions for this to a simple version that should accomplish the same thing. I can't test it now because I updated my wife's car last night and she's out of town for the rest of the week. I moved the modified Data.zip file into the My Flash Disk/iGo/Apl2 folder prior to where step 1 starts below.
Step 1: On the root of the SD card, place the WinCE files, the Testmode folder, and the 'My Flash Disk' folder extracted from the X910 zip file.
Step 2: Turn unit on. When the Pioneer logo comes up, press and hold the menu, map, eject and the reset button at the same time. Release the reset button, then when you hear a pop sound from your speakers, let go of the eject button but continue to hold menu and map buttons until you see a blue screen. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
Step 3: Insert SD card.
Step 4: Select Update CE
Step 5: Select Update SD Format
Step 6: Wait till it says restart in the bottom center, then press the Reset button.
Step 7: Once testmode boots, open explorer and copy the contents of the 'My Flash Disk' folder to the "My Flash Disk" Drive. (Should take about 20min even though at first it says like 140min)
Step 8: Press and hold restart and eject for 5 seconds.
Anybody see a problem with this, or a reason not to torrent a zip containing the files laid out as in step 1?
Posted Jul 21, 2009 · 15:41 UTC#137
It's clear but
1. On the root of the flash disk, place...
For a generic Eu install you can't do this without some prior steps. Do you need to install testmode to a SD before starting? You mean the flash disk internal to the unit not the SD card (wich is also a flash disk).
This is a great summary though. I am looking for a complete walk through from stock to V3 with new maps for an EU unit. I've read nearly all the info but I'm still not confident to do it.
If anyone can write that they will be raved about on here!
The steps I got so far are
1. Update WinCE
2. ReplaceAPL folder from a V3 backup
3. repalce EXRIDER, add generic Lic file and new maps
I think that should do it but I've just tried to write bits down as I've read posts. Can someone confirm this is thr process for a V3 EU upgrade?
Cheers
Posted Jul 21, 2009 · 16:46 UTC#138
I did mean the SD card, not the internal flash storage. i'm not sure if there is an update that works for the eu unit with maps at this point.
Posted Jul 21, 2009 · 17:24 UTC#139
I would just like to know if this simplified version of instructions will work before i try it? Thanks
Posted Jul 21, 2009 · 17:32 UTC#140
Just updated my F700BT.
AWESOME!!!!! The Road Signs in map view are fantastic.
Anyone working on Speed Limit sign hacks yet?
Posted Jul 21, 2009 · 17:34 UTC#141
I have no phone connectivity/bluetooth after doing this on my F700BT. Suggestions? Touching the "phone" button on the screen does nothing but make a beep sound.
Posted Jul 21, 2009 · 18:11 UTC#142
Step 9: Delete all of the files off the SD card and put the testmode folder, DATA file, and the flash dump from torrent on.
where is or what is the flash dump file? Thanks
Posted Jul 21, 2009 · 18:43 UTC#143
Hey guys, I updated the DATA.zip with the following mods, and this works on 3.0 AND 3.01 AVIC F700BT/900BT etc.
The mods included:
1.) Software bypass for speed.
2.) Shortcut menu on top left of map (REALLY awesome) and only visible when not using the guidance
3.) Mute button for voice guidance
4.) Pressing compass button to cancel in-progress route.
Again, this is tested to be working on AVICs running 3.0 OR 3.1! Enjoy!
http://www.mediafire.com/?sharekey=7680 ... f6e8ebb871
To install:
1.) Put Test Mode and this DATA.zip onto your SD card.
2.) Boot into Test Mode, go into My Flash Disk/APL2/iGo and replace the DATA.zip already there with this one!
Let me know if you have any questions/comments. Thanks!
Posted Jul 21, 2009 · 18:59 UTC#144
I did not have this problem on mine. It retained my iphone settings/contacts, etc. The only thing I had to change was the home address for the Navi.
However, I did not format when I updated WINCE. I just left my flash disk as is, and then copied the new files over the old one. I also used a different x910 backup, one of the ones from the Turboss.com FTP site posted earlier this week.
I also had very few mods on my old system.
Posted Jul 21, 2009 · 19:05 UTC#145
Also, for people complaining about not being able to read street names in 3D mode, go into the Navi Settings and click the little wrench next to the "Smart Zoom" On/Off toggle, and change how far the Navi zooms out. I think I set mine to 600ft, so I can now read the road names all the time in town.
Posted Jul 21, 2009 · 19:23 UTC#146
The mods included:
http://rapidshare.com/files/258434389/DATA.ZIP.html
To install:
Can we get some screen shots?
Posted Jul 21, 2009 · 19:40 UTC#147
The contents of the 'My Flash Disk' folder in the zip file you download via torrent early in the instructions.
Posted Jul 21, 2009 · 19:41 UTC#148
I'll upload some screens later since I'm at work. Honestly, if you don't like it, put back your original DATA.zip or the one from the first page of this thread. I can't imagine ANYONE not liking it, to be honest. :) This is how it should have come from Pioneer.
Posted Jul 21, 2009 · 19:47 UTC#149
It's raining out so i'm being lazy to go outside. lol This is how it should have come from the factory
viewtopic.php?f=34&t=24444&start=210
Posted Jul 21, 2009 · 19:50 UTC#150
Maybe I missed something, but what's the difference between 3.0 (the version uploaded for this thread) and 3.1 (it's mentioned throughout this thread). I got the files, but I'm not sure if I should update to 3.0 or wait for 3.1
Page 6 of 39
