looks like we have a problem... i hope i didnt brick it.
i only have a 2GB sd card and i was going back and forth between the pc and the car to update and when i go back inside to load it with the 1.59GB sd3 data load, for some reason, it runs out of space at around 995MB. its a 2GB card and i formatted it! i tried a few times and it still thinks it only has about 1GB space on it.
can i start all over again once i have a new SD card or is the system bricked? i get a blank screen after the pioneer logo screen.
any help will be greatly appreciated...
um you should be able to fit all required files onto ONE 2GB SD card... be sure you disable hidden files... maybe there is a hidden file in there thats taking up the space?
This is what I did:
I had the WINCE files on the root of the SD card
And the TestMode folder containing the small files required for testmode to work.
then I made a folder called "My flash Disk" so I know which files to copy and then I dropped the torrent files into this folder... be sure you're only copying these files into the avic's "my flash disk"..... make sense?
all the files total are just under 2GB so everything fits just fine... not sure how you have managed to fill it up...
i may have bad sectors on that card. ill get a new card and try again. do i have to start at step 1 though?
