Fresh 3.0 Install on F90BT With Pictures
By dragon24 · Jul 20, 2009in Hacks/Mods💬 344 posts👁️ 186,585 views
Page 8 of 14
Posted Nov 09, 2009 · 16:43 UTC#176
Yes, it's the same for all of them I think.
Posted Nov 10, 2009 · 18:38 UTC#177
When I use WinRAR and open the Test Mode download, it complains about it being an incomplete file. Then when I extract the folder, it says the CRC check failed and the file might be corrupted, but then it does actually give me a testmode folder. Is that normal? It says the size of this unrar'd folder is 124kb, that doesn't seem to match up.
Posted Nov 10, 2009 · 18:57 UTC#178
I've attached Testmode_v2.3.
Testmode_v2.3.rar
Posted Nov 10, 2009 · 21:32 UTC#179
This worked great, thanks very much for the guide! 3.0 is much better.
Posted Nov 23, 2009 · 17:48 UTC#180
I have the 2.006 version and the hardware bypass(moved the mute wire to a different location) so that I can do the nav while driving. If I install the 3.0 will the hardware bypass work the same as before?
Posted Nov 23, 2009 · 17:51 UTC#181
The hardware bypass works no matter what version you are on. At least that has been my experience with the past 4 updates I've done.
Posted Nov 23, 2009 · 17:59 UTC#182
I appreciate the fast response. If I brick my unit but have backed it up before hand is it an easy process fixing it?
Posted Nov 23, 2009 · 18:21 UTC#183
I think it's pretty easy. I requires patience, mostly. Just don't rush it. Don't try doing this right before needing to take a long road trip, having to go to work, etc. I have played around with my AVIC a lot, and I have yet to kill it to the point that it's needed to go back to Pioneer.
Posted Nov 24, 2009 · 22:54 UTC#184
So I noticed that a few people had the problem I am having and there has been no solution posted so I would like to request it again.
When updating the WinCE files, my read progress reaches 100% and nothing happens after that.
I have tried the procedure over 20 times and waited different lenghts of time yet still no luck.
Does anybody know how to get past that damn step?
I can't get into testmode either because I can't update the WinCE files.
I have tried different wince files, different sd cards, different computers to copy files on the sd cards, basically everything but it just keeps getting stuck at that point.
Any help would be greatly appreciated since the only option would be to send this unit away to pioneer which I really don't want to do.
Posted Nov 25, 2009 · 00:51 UTC#185
Did you try the four finger salute? Have the SD card with the WINCE files on it. Then turn on the car, press and hold the Menu, Map, Eject & Reset button at the same time for about 15 seconds. Release Reset, wait a few seconds, then release the others. I believe that is a hard reboot. When I did that with mine, it came up okay.
Also, how big is the SD card you are using, and what brand is it?
Posted Nov 25, 2009 · 02:02 UTC#186
Yup 4 finger salute, everything according to the instructions, it just stalls at the 100% read progress.
Tried 3 SD Cards, can't remember the 3rd one but the other 2 are a 2gb and a 4gb both Kingston brands.
Tried the same thing over 20 times, different computers, different ways of formatting cards, everything i could think of haha.
Posted Nov 25, 2009 · 03:05 UTC#187
What about downloading from a different source? What files are on the flash disk you are working with?
Posted Nov 25, 2009 · 04:05 UTC#188
Tried different sources as well as different versions. I haven't even made it to the part of the flash disk so that's not of concern at the moment. I was originally just using version 2.0 files but someone in another thread suggested that I use the 3.0 files and upgrade at the same time.
So in summary I have used 2 sets of version 2.0 files (2 different sources) and 1 set of version 3.0 files all with no success.
I don't think it's the files as many people have downloaded them and used them from the same source. I even tried downloading multiple times as well as unzipping multiple times AND doing both of those on another computer with no luck so there is something royally screwed with the deck or I'm still not doing something right.
I'll try and post a video tomorrow of what im doing exactly and whats happening which might help clear the air as the what my problem is.
If anyone has any other suggestions or solutions it would be great to hear :D
Posted Nov 25, 2009 · 18:22 UTC#189
Another successful install confirmed on the F90BT. Now on to the next mod!
Posted Nov 25, 2009 · 21:37 UTC#190
Successfully installed 3.0. Thanks everybody
Posted Nov 30, 2009 · 03:36 UTC#191
After many hours, a successful 3.01 install on my F700. Don't make my mistake and use WinCE files from 2.0. It will kill the upgrade.
Posted Nov 30, 2009 · 18:19 UTC#192
Thanks for the great write up. Do you need a specific size or brand SD card?
Posted Dec 01, 2009 · 01:02 UTC#193
Ok I've gone through all 13 pages of this thread looking for a link that works and no dice. I've installed BitTorrent and tried both the initial url as well as one on like page 11 or 12 and nothing.
Can someone repost or PM with a link on where I can dowloand 3.0?
Thanks so much!
Posted Dec 01, 2009 · 22:43 UTC#194
Links to all the files are in the Official 3.0 upgrade thread. Last page.
Still having the "System Loading" problem with the 5 minute reboot after trying to upgrade. Anyone have any success with fixing this?
Posted Dec 08, 2009 · 02:29 UTC#195
thanks for the post. Ran into a couple of problems but was able to get it going. Looking forward to the next upgrade now.
I noticed the street names dont display in 3D mode.
Posted Dec 08, 2009 · 21:44 UTC#196
problem i am having is with the 3rd sd card
everytime i insert the card with the files the navi system shows 0 files.
then i put the sd card back into the computer shows sd card invalid reformat
so i try over and over again two different cards from 2 different companies anyone else having this problem also
Posted Dec 09, 2009 · 01:23 UTC#197
when you insert the card and view the folder in your Avic the card is empty?
Did you unzip the files before putting them on the card??
Posted Dec 10, 2009 · 15:43 UTC#198
yes unzipped from torrent downloaded. folder called my flash disk which has apn, apn2 etc....
for some reason everytime i flash my sd cards tried 3 different companies 3 different sizes varying from 2gb to 8gb
then insert them into unit in testmode says sd card has 0 files in it.
but i checked and rechecked the card on the computer before putting it into the unit. and the files where there before.
Posted Dec 12, 2009 · 14:11 UTC#199
As the torrent for the x910bt is not working. Any one know of a working torrent? On another note, My friend has a F910BT with 3.0 and I have a F900BT. Can I make a backup of his firmware and use it on my? By follwing the steps on page 1?.
Posted Dec 14, 2009 · 21:45 UTC#200
Like D-Boy said... the torrent just ain't happenin anymore :cry: so getting the X910bt.zip file might be a challenge.
It looks like the file may be available from a link in another post on a different thread. I grabbed what may be the correct file, but need a bit of help understanding the contents of what should be in the x910bt.zip file that used to be avaialble.
What were the contents of the x910bt.zip file when it was available? Was it just a data.zip file for the x910bt?
If the answer to the above question is yes, is there a way to look at the contents of one or more files in data.zip to see if they are in fact for the x910bt?
Page 8 of 14
