3.0 Modding: Thoughts & Ideas
By bdogzzz · Jul 21, 2009in Hacks/Mods💬 104 posts👁️ 15,959 views
Page 4 of 5
Posted Jul 25, 2009 · 08:47 UTC#76
Is there someone willing to help me with the infoboxes?
Posted Jul 25, 2009 · 12:49 UTC#77
IDT,
I think we should, I can put in some time for this, but right now im in between building a couple new computers, and remodeling my whole house, so my time is limited ATM. And Euro, this is one of my favorite mods by far again thanx :D
Pete, what scheme are u using that you have the green terrain in? I cant find a scheme that gives me green terrain.
This is a great mod, but i can't take credit for it. I only implemented it. CMH is the one that paved the path and told me how to do it!
Posted Jul 25, 2009 · 15:09 UTC#78
IDT,
Euro,
Im using Riks day and Monopoly day
Posted Jul 26, 2009 · 01:01 UTC#79
I want to apply some v2.0 mods to v3.0. Is it safe to say I can copy the mods from the old data.zip to the new 3.0 data.zip? I want to add the address mod, quick loanch buttons, stop navi button on compus and mute navi button.
Posted Jul 26, 2009 · 03:07 UTC#80
Sheesh... Next thing you'll be putting ThemeChanger on AVIC's... :D
Posted Jul 26, 2009 · 16:58 UTC#81
Ok if you guys want skies on your 3.0 unit here is how: Copy and replace the attached sys file in my flash disk/apl2/igo.
Then go into your data.zip file and replace the gfx file with the one also provided in the zip file attached.
Then you have to modify each scheme color.ini and color3d.ini. Copy and paste this code below, under [other] all the way at the bottom in the color.ini files.
background_picture_0="gfx/day/cs.bmp"
sun_picture_0 = "gfx/day/sp.bmp"
This code just shows where the files are for the background to be displayed so you can actually pick other bmp's to use. The one above is for a day background, so you would have to use "gfx/night/whatever bmp for night you want to use"
Have fun modding! :D
So I did aqll this and the sky looks great. Is there a reason I would not have the moon or sun showing though?
Posted Jul 26, 2009 · 22:02 UTC#82
I beleive it depends what position your in. I havent seen the sun but definately have seen the moon while driving around.
Posted Jul 26, 2009 · 23:15 UTC#83
@eurotuner
I've completed every step of your guide and YES!!! is can the blue sky....
The only thing what wont work is TMC. Something to do with sys.txt?
It could be. We dont have TMC in the US. Take a look in your original SYS and see if anything about TMC is referenced.
Does your SYS.TXT point to the European Versionn?
Try this in the first line:
[device]
type="PIONEER746EW"
or whatever is in your original SYS.txt
Had this Problem before when using US Mods
Hope this fixes it
Jörg
Posted Jul 27, 2009 · 08:44 UTC#84
Having the multiplan-screen back would be nice, i believe idt made this?
Do you still know the code idt and where to put it?
What would be great is to have this option on the next screen after typing in the addres...
Posted Jul 27, 2009 · 15:06 UTC#85
I made some changes and started a thread here.
Posted Jul 27, 2009 · 18:27 UTC#86
Question...
I want to hide the AV title bar (song title bar) at the bottom of the map screen at all times but keep the street name bar. Where can I find the code for the AV title bar? What is the script/layer name for the AV title bar?
Posted Jul 27, 2009 · 18:32 UTC#87
Question...
No one has been able to hack the AV side of the unit yet. It is different from the ui files of the navigation. I too would like to get rid of that bar , but it's just not possible yet.
Posted Jul 27, 2009 · 18:40 UTC#88
That's annoying. I'll see if I can disassemble some of the .exe's and comb through some assembly code and see if I can find anything useful. Does anybody know where I can obtain a copy of IDA Pro 5.5? The 5.4 demo is extremely annoying and the 4.9 free version can't disassemble the ARM executables/DLL's (PM me).
Also, what's the easiest way to make my map icons (2D/3D/NorthUp and the other button under that one) semi-transparent (about 50% transparent)? Can I just change the alpha levels in navigatemap_800_480.ui?
Posted Jul 27, 2009 · 18:48 UTC#89
For the map icons that's exactly what you do but in navigatemap.ui
Posted Jul 27, 2009 · 19:50 UTC#90
Question...
Have you tried clicking on the little arrow at the end of it? Or reading the owner's manual where it mentions it?
Posted Jul 27, 2009 · 20:05 UTC#91
Question...
No, I don't want to temporarily hide it. When you press the arrow, that only hides the bar until the next power cycle. The next time the unit turns on, the bar is right back where I don't want it. I am looking to remove the bar completely (like when the audio is OFF) and permanently.
Posted Jul 28, 2009 · 01:54 UTC#92
Would it be possible to increase the Z value of the street name label/background so that it covers the AV title bar but not the AV input and album cover art?
Maybe if I increase the road name background and icon to a much higher Z?
Also increase the fonts Z so it is higher than the background?
;route name and housenumber(next and the third road name)
I'll do some experimenting and report my findings.
Posted Jul 28, 2009 · 03:02 UTC#93
It was a no go. Even with z=4000.
Posted Jul 28, 2009 · 03:09 UTC#94
i think this would be handled in clip planes as that's what controls it in 8.0
Posted Jul 28, 2009 · 03:24 UTC#95
Very much doubt it. Song title is not output by iGO, it is overlayed by system software on top of anything iGO outputs, so I do not think it can be hacked by anything internal to the Navi part of the unit...
Posted Jul 28, 2009 · 03:55 UTC#96
ooohhh, AV input, i thought it was regarding the street names in 3d, hehehe, too much reading of bits and pieces got me confused,
Posted Jul 28, 2009 · 21:48 UTC#97
I have a question... Which line in the sys text do I need to edit to see more of the background? I put a modded sys text in, but alot of the sky mod is cut off. I would like to get it to tilt more foward, I have the max tilt level set at 10000 right now.
Posted Jul 29, 2009 · 01:28 UTC#98
here is my sys.txt
Also for the modders, I still can't figure out the sun thing. I have the moon on there at all times. I still think there is some code missing to get it to show. Anyone else see the sun? It isn't a big deal, but just bothersome when something doesn't work right
sys.txt
Posted Jul 29, 2009 · 02:27 UTC#99
Thanx Nissan,
Also I am using one of the sun bmp's that is in Euro's sky mod. I thought it was not working until I went for a drive then it showed up. It actually moves with the rest of the bmp while driving.
Posted Jul 29, 2009 · 02:48 UTC#100
Thanks, yeah, my moon moves all around as I make turns, but it never leaves the screen. In fact, even on the pictures on the first page of euros, the moon is there, the sun isn't. I even changed my sun picture to the one that is brightest, and I also turned on the day view at night to get a better look without the real sun glaring off the deck, and I still dont' see anything.
Page 4 of 5
