3.0 Modding: Thoughts & Ideas
By bdogzzz · Jul 21, 2009in Hacks/Mods💬 104 posts👁️ 15,959 views
Page 5 of 5
Posted Jul 29, 2009 · 16:33 UTC#101
is it possible to take phone(bluetooth) status info and place it into the nav screen?
i.e signal/battery/carrier...
Posted Jul 29, 2009 · 17:09 UTC#102
Thanks, yeah, my moon moves all around as I make turns, but it never leaves the screen. In fact, even on the pictures on the first page of euros, the moon is there, the sun isn't. I even changed my sun picture to the one that is brightest, and I also turned on the day view at night to get a better look without the real sun glaring off the deck, and I still dont' see anything.
Ya i'm not really sure what the bmp's for the sun really do. It's my impression that whatever the bmp picture has in it is what will show. Thats why the moon shows and just rotates directions.
Posted Aug 10, 2009 · 04:00 UTC#103
I have a question... Which line in the sys text do I need to edit to see more of the background? I put a modded sys text in, but alot of the sky mod is cut off. I would like to get it to tilt more foward, I have the max tilt level set at 10000 right now.
here is my sys.txt
Also for the modders, I still can't figure out the sun thing. I have the moon on there at all times. I still think there is some code missing to get it to show. Anyone else see the sun? It isn't a big deal, but just bothersome when something doesn't work right
Well, I saw the sun on my GPS for the first time today, for about 1 second. So I know it is there.
Funny too though, I had two moons when I switched over to night. One was a low full moon that appeared as the sun did, quickly and shortly, and that same time, the moon that si always present (quarter moon high in the sky) was there too.
Any ideas on how this may be the case?
Running IDT data and pioneer blue day and night
Posted Aug 18, 2009 · 02:10 UTC#104
That's annoying. I'll see if I can disassemble some of the .exe's and comb through some assembly code and see if I can find anything useful. Does anybody know where I can obtain a copy of IDA Pro 5.5? The 5.4 demo is extremely annoying and the 4.9 free version can't disassemble the ARM executables/DLL's (PM me).
Also, what's the easiest way to make my map icons (2D/3D/NorthUp and the other button under that one) semi-transparent (about 50% transparent)? Can I just change the alpha levels in navigatemap_800_480.ui?
For the map icons that's exactly what you do but in navigatemap.ui
eurotuner29 - I'm trying to figure out how to make the buttons on the navigatemap_800_480.ui switch between opaque and semi-transparent. I came accross a mod for version 2.0 that did this (I think it was another users twist on Stanislavovich's mod). i.e. the buttons are semi-transparent until you touch the screen and then they turn opaque for 5 seconds or so. Is this what you were making reference to in the above post? I came across
Page 5 of 5
