IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 34 of 65
Posted Sep 11, 2009 · 23:27 UTC#826
Hey IDT,
I want to switch over to yours from CMH's mod but the only thing holding me back are the custom settings he had. I wanted to see if you had the same and that would make up my mind. I attached a couple of pics.
Posted Sep 11, 2009 · 23:33 UTC#827
Hey IDT,
i have the warning settings for the speedcam, i personally don't like how his is set up as i don't find it organized,
Posted Sep 11, 2009 · 23:38 UTC#828
Hey IDT,
i dont really care about how his is organized i just wanted to know if you have those options included in yours and if they are organized better than excellent. like having the tilt zoom option or if you can turn off turn restriction elevation your speed and the custom camera alert setings are pretty cool.
Posted Sep 11, 2009 · 23:41 UTC#829
Hey IDT,
i pretty much have it except for the big clock, history/gps, for the tilt and zoom i don't mind it as it disappears after a while unlike in the 2.0 version
Posted Sep 11, 2009 · 23:48 UTC#830
the clock option is useless to me and i could change the icons on your navi file but the tilt zoom feature is a biggie, probably my favorite option
Posted Sep 11, 2009 · 23:49 UTC#831
haven't you noticed that it disappears at the same time when the buttons dim?
Posted Sep 11, 2009 · 23:51 UTC#832
it is very annoying
Posted Sep 11, 2009 · 23:52 UTC#833
Sent you a donation IDT. Thanks for the hard work.
Is there any documentation or wiki on this stuff yet? Seems overdue, what work has been done, how can I help?
thanks for the donation bro, i'll try to have a kinda quick guide included on the next one,
I am happy to help on documentation, please let me know how I can help.
Posted Sep 11, 2009 · 23:54 UTC#834
if you could create a txt file with all the mods you know and how to launch them that would be great, send the file to me after and i'll double check,
Posted Sep 12, 2009 · 00:15 UTC#835
IDT,
How did you get the clear backgroud on the Cruise computer?
Thanks,
Bryan
Posted Sep 12, 2009 · 01:04 UTC#836
Hey, Julius.
I love the new mod, bro!
I have a question thoughI was integrating my own mods into your lates and I notice now that I cannot comment out the date as it pulls up a error on startup so I am using the date (but at x=1000 so it is off the screen) and I had a quick launch for my MSN traffic via the compass but now when I click the compass it brings up the tripmeter background yet I cannot see the sprite command in the compass line.
How are you pulling this up?
Thanx,
Bud
Posted Sep 12, 2009 · 01:05 UTC#837
Hello
I have been trying to get to the multi-route display where we can see all the routes (econo, fast, etc) at the same time but with different colors but I just can't find how.
Greetings
By the way, great mod, I will send you a paypal. You make the F90Bt a great tool.
Posted Sep 12, 2009 · 02:08 UTC#838
IDT,
Thanks,
Bryan
could you post the script you're using and i'll help you out
Posted Sep 12, 2009 · 02:12 UTC#839
Hey, Julius.
Thanx,
Bud
the date is being called in the navigatemap.ui, just check the text name of the date and search for it in the navigatemap.ui, regarding the msn shortcut that you have, there is a transparent button on top of the compass, date and time area that i used for the trip cruise shortcut, locate that and then just move it to your desired location
Posted Sep 12, 2009 · 02:15 UTC#840
Hello
Greetings
are you using the schemes attached to the download? i edited those schemes to change the color for the multi-route
Posted Sep 12, 2009 · 03:02 UTC#841
is the tilt zoom feature difficult to put in. do you know how many files it affects and where the script is?
Posted Sep 12, 2009 · 03:12 UTC#842
Hey, Julius.
Thanx,
Bud
Got it..it is "Dial Button". Don't know how I missed that.
Thanx!
Posted Sep 12, 2009 · 03:25 UTC#843
IDT,
Thanks,
Bryan
I just copied the directions from this post:
viewtopic.php?f=34&t=27030
Thanks for your help
Posted Sep 12, 2009 · 03:27 UTC#844
i am trying to add my onmap buttons and was wondering why you have your onmap buttons with 2 images 1 smaller than the other and should i do that with my onmap buttons as well?
Posted Sep 12, 2009 · 03:40 UTC#845
Hey, IDT,
I like the little elevation sign (I had one long ago) but I am using my own altimeter:
;Altimeter
..and in this version it shows the current elevation in feet whereas yours displays in "mi". I am at 1093 ft here in so. Cal and the little sign will show ".2 mi" which is the same just as well. It will also correspond in the tripmeter as miles as well.
I had played with the code in the tripmeter long ago to try and get it in feet but had no luck. By changing the code in the little elevation sign to "gps.elevation" would it read in feet perhaps?
I am gonna try right after I write this.
Thanx!
Bud
Posted Sep 12, 2009 · 04:07 UTC#846
Ok, I did what you said and changed the daycar1.bmp and nightcar1.bmp to daycar.bmp and nightcar.bmp but I am still getting the arrow and not the car image. What else do I need to change? BTW...LOVE V4.3!!!! THANK YOU SO MUCH!
just a question, are you expecting the car to show up on 3D mode?
Yes, I thought that was possible. I could be wrong, and apologize for the question, if I am. Thanks again for your help.
Posted Sep 12, 2009 · 04:11 UTC#847
First IDT, I too Love your mod and really appriate all the hard work you have put into this!! I will donate as soon as I can, right now i'm kind of broke but promise I will in the future. But I am sad to say I found a bug at least with my F90. Whenever I go to trip computer (push on the clock) then come back to the map it switches to that day/night view it was previously in as the perminate view. i.e. if It was night it stays in night view. Day - day view. It is no longer in the previous mode - automatic. I hope I explained that clear enough. I too would like the elevation sign to be in feet if possible. ANyway, Thanks again for all the hard work!!
Posted Sep 12, 2009 · 05:45 UTC#848
not really, you just have to check where's it's being called, i'll put it on the next update
Posted Sep 12, 2009 · 05:47 UTC#849
Thanx!
no prob
Posted Sep 12, 2009 · 05:47 UTC#850
no prob
Page 34 of 65
