IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 36 of 65
Posted Sep 12, 2009 · 21:49 UTC#876
IDT. Awsome work again. Thanks, makes my F90bt way more user friendly
Posted Sep 12, 2009 · 23:41 UTC#877
IDT,
How did you get the clear backgroud on the Cruise computer?
Thanks,
Bryan
could you post the script you're using and i'll help you out
is this what you are looking for? thanks fir your help!
Posted Sep 13, 2009 · 00:12 UTC#878
The other cruise that you are using is one that uses a different screen/state rather than being a layer in the navigate 800_480 ui file (which IDT is using).
Then - if you have it as a layer - you can set the z value for transparency/etc...
Thanks,
Ben
Posted Sep 13, 2009 · 00:33 UTC#879
Thanks,
Ben
I set the z to 500 and I got the foreground transparent but the backgroud is still there. Do I need to remove the BMP file? What should I set the z value to?
Thanks,
Bryan
Posted Sep 13, 2009 · 00:37 UTC#880
is this the lane info? and if it is i cannot get this to turn on. i added your coding to the nav file but do i also have to add your ini file as well?
Posted Sep 13, 2009 · 00:39 UTC#881
Thanks,
Ben
Thanks,
Bryan
Did you try to set the z value for the image (or if you don't want the image there at all - removing it)?
Thx,
Ben
Posted Sep 13, 2009 · 02:03 UTC#882
Thanks,
Ben
Thanks,
Bryan
Thx,
Ben
I tried to remove the file and it gave me a black background. I changed the z valie next to the BMP file and the foregroud dissapeared. I also tried to change the first z value to 500 but nothing happened. Here is the code I am workong with . I highlighted the numbers I've changed.
Posted Sep 13, 2009 · 03:29 UTC#883
Thanks man for making this an incredible system! Pioneer...you should hire this guy! ;)
PS: Donation sent!
Frank
Posted Sep 13, 2009 · 03:51 UTC#884
PS: Donation sent!
Frank
I Have to agree with Frank on this one Pioneer!!
Posted Sep 13, 2009 · 04:23 UTC#885
PS: Donation sent!
Frank
X2
Posted Sep 13, 2009 · 05:58 UTC#886
Look at this code in th Navmap_800_480.ui file:
;SIGNPOST
It says "Singpost" and not Signpost"
Is this typo affecting the operation of the signposts?
I just noticed this when making some changes.
Thanx,
Bud
Posted Sep 13, 2009 · 08:51 UTC#887
Wow this is amazing...Takes some times to remember everything and where its at but once you do its so much easier to use. everything is on the map without having to exit. Thanks IDT, im gonna paypal you some cash tomorrow
one quesiton i have is,
You know when you dont touch the map for a while the top icons dim a little bit until you touch the screen again....is there a way to make them totally disapear so you can have a cleaner map look until you need them again. and then just touch the screen and they pop back up and then you can press which one you need?
Thanks again
Posted Sep 13, 2009 · 11:51 UTC#888
Hello IDT
Yes I did copy the schemes, I will copy them again from your newest mod. But where should I go to see that. When I click on multi-route I only get a screen where it tells me how many time it will take for each option. If I understand correctly I should see the map with different colors and the possibility to choose the one I want. I never saw a screen of what it should look like.
Greetings
you have to press and hold the multi route button instead of just tapping it
Excellent
I did not know that. It works. Great
One thing I notice is that when you click on the time, you get to the navigation screen (cool feature). But even if you are in km, the center bitmap where you see the speed, the scale stays in miles.
not a big thing but just in case you did not notice that.
Paypal today.
Greetings
Labgate
Posted Sep 13, 2009 · 12:07 UTC#889
ill.die.trying thanks for this v4.3. I tryed to send paypal and I get some kind of error. I will try again later.
Posted Sep 13, 2009 · 14:35 UTC#890
IDT thank you that version 4.3 euro is really very accomplished.
- I regret that the problem of param speed the addition of mobile cameras are still not fixed. I already read the setting.ui not find where the problem is coming? !
- I can not change the color of the clock and date ?
- big problem with "spoken alert" for mobile camera, the speed is not announced ?!!! it's ok for fixed camera speed.
(it's ok ?)
- mini popup speedwarnig don't show ?!
have a solutions ?
until i find something out regarding the mobile cameras the spoken alert will stay as it is, I INTENDED THE MOBILE CAMERA WARNING TO JUST SAY SAY "MOBILE CAMERA" as no one was able to make it work, , this is not a bug, it's just the way it is
i didn't have the time to paly with the mini pop up and i'm still trying to figure it out
Posted Sep 13, 2009 · 14:47 UTC#891
Julius; I like it in feet. Mine's ok. I just thought I'd put the thought forward for those that are getting decimal miles. I don't know the problem or fix, just advising my situation. Thanks.
no prob
Posted Sep 13, 2009 · 14:50 UTC#892
thanks for the donation bro
Posted Sep 13, 2009 · 14:50 UTC#893
PS: Donation sent!
Frank
Posted Sep 13, 2009 · 14:51 UTC#894
Fantastic work IDT.Best yet.Just one question if you could help me please.The speed camereas aren't showing up although i have set them up tp.could this be a map thing rather than anything else?I have recently installed V3.00 from a link on here along with the latedst maps.Thanks again for your mod .PP to follow when i get home next week.
do you have the speedcamtxt?
Sorry IDT,where should speedcamtxt be?I do have the speedcam folder in my apl2/igo/contents folder.Thanks again for your help.
Posted Sep 13, 2009 · 14:51 UTC#895
;SIGNPOST
Thanx,
Bud
it really doesn't matter as long as whatever is calling it has the same exact spelling
Posted Sep 13, 2009 · 14:52 UTC#896
Thanks again
i will have a settings for it on the next update
Posted Sep 13, 2009 · 14:52 UTC#897
Hello IDT
Greetings
Excellent
Paypal today.
Greetings
Labgate
i'll take a look at it
Posted Sep 13, 2009 · 14:55 UTC#898
Hi IDT,,
Cleaned save folder,, copied 4.3 data zip, schemes and fonts fresh into their place,,
When passing fixed speedcam, system reboots,, no voice warning on mobile cams,, when disabling voice warning, no reboot,, if system reboots for other reason,, disabled setting for speedcam is not saved,,
One weird thing that maybe can be of some help,, I parked today 10mts before a speedcam and left slowly passing the camera,, result with visual and audible fixed speedcam warning,,
For the rest,, very nice skin,,
will look for pp account an send some beermoney,,
Kind regards,,
IDT and Eldeep
I have the same problem as Eldeep with the Red Camera Audible warning. Could it be a corrupt or missing audio file somewhere? Just curious.
Other than that it works flawlessly.
Regards,
M
i'm currently looking at it, so far the problem is that the speedcam.txt has the camera type being set as 7
X,Y,TYPE,SPEED,DIRTYPE,DIRECTION
-87.9594217,41.9931969,7,66,0,0
-87.8846644,41.9303592,7,66,0,0
-87.9601737,42.0225062,7,66,0,0
-106.6016003,35.112338,7,66,0,0
we don't have an advanced camera setting that's why it should only be from 1-5
i will investigate further on this as i know for sure that this is the main problem regarding the rebbots
Posted Sep 13, 2009 · 14:57 UTC#899
SORRY FOR ALL THE LATE REPLY'S, I JUST TOOK A WEEKEND OFF FROM MODDING AS I HAVEN'T HAD ENOUGH SLEEP THE PAST WEEK, I WILL LOOK AT ALL THE BUG/REQUEST TOMORROW ESPECIALLY THE SPEED CAMERA,
Posted Sep 13, 2009 · 15:42 UTC#900
(it's ok ?)
have a solutions ?
ok thank you for all these answers, your work is really great.
For mobile cam spoken alert, I suspected that the warning had been simplified due to the problem of speed management.
Once this problem is resolved your mod is really on top ;-)
why I can not change the color of the hour ?
Page 36 of 65
