IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 37 of 65
Posted Sep 13, 2009 · 16:03 UTC#901
ok thank you for all these answers, your work is really great.
For mobile cam spoken alert, I suspected that the warning had been simplified due to the problem of speed management.
Once this problem is resolved your mod is really on top ;-)
why I can not change the color of the hour ?
you hava to check the navigatemap.ui as it is also being changed in there
Posted Sep 13, 2009 · 16:12 UTC#902
is this the lane info? and if it is i cannot get this to turn on. i added your coding to the nav file but do i also have to add your ini file as well?
Hey IDT,
i need some help. been working on it for 2 days and just dont know what i am doing. i still cant get the lane guidance to work like yours. i put the 2 bmps from the common folder and the ini file and added the script to the nav file, still no luck. Am i missing something?
i also have an elevation on my map but i wanted it to be a little larger like the one u had and my text displays in feet but i cant get the text to fit right, can you give me some suggestions please? i would appreciate it. this is driving me crazy.
thanks
Posted Sep 13, 2009 · 16:17 UTC#903
ok thank you I had not looked into this file. I really like your mod.
Posted Sep 13, 2009 · 16:59 UTC#904
Hey IDT,
thanks
did you also add the code in the setting_800_480.ui?
Posted Sep 13, 2009 · 17:09 UTC#905
thanks for the donation
Posted Sep 13, 2009 · 19:04 UTC#906
eldeep
thanks for the donation bro
Posted Sep 13, 2009 · 20:07 UTC#907
I found "ui_NavigateMapSINGpost
in navigatemap.ui
I made the change to Sign
Thanks for the heads up,
Since both " navigatemap.ui" and "navigatemap_800_480.ui" had the word SING would the typo have made a big difference? :?:
Posted Sep 13, 2009 · 20:22 UTC#908
in navigatemap.ui
you just have to be cautious when changing something as it might be called by a script or a layer and if it doesn't find it it'll either throw an error or reboot, so if you change it just be sure you have everything else changed
Posted Sep 13, 2009 · 21:26 UTC#909
IDT,
Quick question for you. I decided to change my font, using the "Rename any font to Tahoma.ttf" method. It works great for the system, and in your Data.zip as well, except for when I go to search for a POI. I touch the keyboard and it begins the reboot process. Is there some file I can edit to allow me to change the font of the IGO user interface to match my system interface? If not, no big deal... Tahoma is a cool font, but the "Space Age" font I am using really looks killer and works well in your mod, except for that one instance.
Any thoughts or am I stuck?
Thanks bro!
Frank
Posted Sep 13, 2009 · 21:45 UTC#910
IDT,
Thanks bro!
Frank
sorry i don't have any clue regarding that
Posted Sep 13, 2009 · 21:48 UTC#911
FOR USERS HAVING THE SPEEDCAM REBOOT PROBLEM
could you try using the speedcam.txt file from this database http://speedcamerapoi.com/download.php, download in ig0 8 format and copy text to notepad and as speedcam.txt or whatever you want it named, i was looking throught the ones for canada and it seems that it has all the right info, please report back ASAP, i want to get this issue fixed right away
Posted Sep 14, 2009 · 00:17 UTC#912
i added the code into the settings file but the location was already taken by something, can i add a scroll?
Posted Sep 14, 2009 · 00:20 UTC#913
just change the x and y values for it
Posted Sep 14, 2009 · 00:38 UTC#914
i changed them based on the numbers i had but i need to add a scroll because the lane guidance is cut off and when i tap the on or off button they both stay highlighted. i just haven't been able to get anything to work lately.
Posted Sep 14, 2009 · 01:25 UTC#915
i combined the clock and icon display and set it up so everything fits. the only problem is that when i hit the on off buttons for the signpost and lane info, they both light up and stay on. did i miss something else?
Posted Sep 14, 2009 · 01:39 UTC#916
i haven't worked with scrolls before so ican't help you with that,
one possible reason both options are being highlighted is that they are not being set properly
Posted Sep 14, 2009 · 02:27 UTC#917
well i figured out why the buttons weren't doing anything, i forgot to add the var to the beginning of the settings file but now i cant get past the startup message. is there any chance you can take a look at these files and tell me what is wrong. the 3 items i added to the common folder were the lane_div.bmp, lane_bg.bmp and the laneinfo.ini files. other than missing a file i cant figure this out. please help
ui files.zip
Posted Sep 14, 2009 · 02:33 UTC#918
i'll take a look at it later when i get home
Posted Sep 14, 2009 · 02:42 UTC#919
if those two files are just the ones you edited you have to search a little bit more, whenever your trying to incorporate a mod yo uhave to go through all the ui files until you find all necessary variable/bmp/script/state to make it work, you can't just edit two ui files and expect it to work, i suggest you download examdiff pro or beyond compare as these are helpfull tools when comparing files
Posted Sep 14, 2009 · 04:16 UTC#920
i just exam diffed all your files. the only file i noticed that was different and could possibly mean something was the template file. could this be causing the problem. i noticed you had added this line
any help would be great even willing to paypal some more. please help
Posted Sep 14, 2009 · 06:16 UTC#921
send me your last working data.zip without the mods prior to this and i'll take a look t it
Posted Sep 14, 2009 · 08:08 UTC#922
Great mod,
Looks very good.
this weekend tested your mod the EU version and i Like it.
There are 2 things wich doesn't match the EU standard :
-The elevation value is given in FT and not in meters because the value seems to be 3 times to high.
-The NEEDLE in the DASHBOARD gives MPH and not KPH while the center image will show KPH.
IS this easy to fix ?
Regards,
Navigarie.
Posted Sep 14, 2009 · 14:34 UTC#923
Great mod,
Looks very good.
Regards,
Navigarie.
i will take a look at it
Posted Sep 14, 2009 · 16:09 UTC#924
IDT
on one of your updates you put TMC shorcuts onmap, is TMC works for F700bt how turn this on?
Posted Sep 14, 2009 · 16:21 UTC#925
IDT
try using the EU version
Page 37 of 65
